Yup dependent yan paps sa floater, floater lang naman ang sensor ng sasakyan sa tangke.
that's why, if you may notice, some gas boys will slow down the fuel delivery as the fuel level gets "near the top". they are slowing down, so's the remaining air in the tank can have the chance to exit thru the filler neck. if the air is not able to go out because it is being blocked by the onrush of incoming fuel, the neck gets filled up, with a large air bubble still in the tank. when you start the engine, nakakalog ang tangke at filler neck, baba si fuel at alis si air. then all of a sudden, you have space for 5-10 liters more!
the longer the filler neck, the more prone this can happen.
our PUJ drivers are even more intense... they shake the jeep to and fro, to get rid of the flat air bubble against their flat-topped gas tank. pag garahe kasi, ang usapan ay dapat full-to-the-brim ang tangke para sa susunod na mamamasada..
Sino na po ang recently naka pag pa PMS for 40,000 kms? specifically for VVTi models. pede po makita yung job order? need ko lang po malaman ung mga kailangan palitan at yung qualtity ng mga fluids na i replace during PMS.
Maraming salamat po
Yung pinto na pinagawa ko off yung color compared sa rest ng paint. Sobrang dark. Yung sa bumper naman, diniretso lang nila pinturahan kumbaga hindi man lang ineffort na tanggalin kaya yung gaps sa fender tska bumper may paint. (Pero medyo pinagbigyan ko na din sila sa door since 7 years na din yung paint ko during that time kaya medyo understandable na din na faded na yung ibang part ng paint)
Good day!
Tanong ko lang
have anyone experienced yung tumutunog paginopen and close yung
rear hatch
and how to remove the squeaking sound tapos ang bagal pa kumilos
you can try lubricating the pivot points at the roof.
but my suspicion is, it's your left and right springs.. and unfortunately, once they act up like what you are describing, there's no solution but to replace..
but hey! it's easy to replace, and they ain't expensive.
Mga sir, how's your rear wiper? Yung sa akin kasi may squeking sounds pa rin akala ko mawawala along the way but 2 years old na ganun pa rin. Meron bang remedy dito? Tnx.
yup! 2 years ago. i forgot exactly how much, but it probably didn't cost much. if it did, it would have etched itself into my hard heart.
i had it done along pedro gil, beside the paco market. medyo mahirap kung akumismosolo ang gagawa, dahil spring-loaded sila, parang shocks.
btw, Left and Right sila.. huwag ipagpalit..
Last Sunday I push our innova almost to its limit when we're on our way to Laguna 1st gear to 2nd gear and so on almost redline ako nag shift tapos pag dating namin sa resort napansin ko yung tailpipe nya may mga black parang carbon eh gas sya.bakit Kaya ganon?regular ko na kikita yung tailpipe nya walang ganon nung Sunday lang talaga nung almost ma redline sya.
