Page 487 of 662 FirstFirst ... 387437477483484485486487488489490491497537587 ... LastLast
Results 9,721 to 9,740 of 13229
    Dec 2008
    #9721
    Quote Originally Posted by lord View Post
    Thanks Mile2. As per SA, they used that stethoscope. I am not just sure how thoroughly they investigated the problem. Basta nung nakitang may consumer plastic o supot na nakapulupot sa idler nung tinanggal yung drive belt, the SA gave me a ring to advise na yun yung root cause and mas okay na palitan na rin yung drive belt. Since sa tuwa ko na hindi alternator, I gave him the go signal to replace the belt. Kaso umulit naman. 3500 yung belt tas 1400 yung checkup at labor ng pagpapalit ng belt.
    Can anyone refer someone from speedyfix? kaya ba ng isang araw ang repair? Sa Makati, saang shop ang kayang mag diagnose at magrepair ng agnitong problem? Thanks.
    if you are stil under warranty better to have it serviced sa casa. pls refer to my earlier post bka lang replace idler bearing and alternator bearing.
    #9722
    Please help...I have notice that some fluids (maybe water or gasoline) would fell from right rear portion of my innova practically near the right rear wheel. I noticed this when my aircon is on both front and back. I hope this is not gasoline...after reading some threads here that gas tanks of innova has leaks... please help....thanks in advance
    Aug 2006
    #9723
    Quote Originally Posted by attyallanlatras View Post
    It's coming from the rear condenser, condense water dripping from the outlet. It's practically normal!
    The rear aircon condenser unit is hidden behind the third row rear passenger side wall just before the the rear door. It's the opposite side of your tools compartment.
    Aug 2006
    #9724
    You can call Migs of SpeedyFix for inquiries, just search their contact info here. They would probably be closed this Holidays so better visit them so they can assess better your problems.
    Just like "reloaded_acer" says better also to have it checked back at casa or find another dealer's second opinion.
    #9725
    does it smell of gasoline or not? simple check. dip a finger into the liquid and then smell it. if it smells like gasoline then have your unit checked. if not, then it most probably is just water from the condenser.
    #9726
    the gas tank is located on the middle left side so masyado malayo yung sinasabi mo na rear right side. that's condensation alright from your aircon. also one should be infront the passenger portion.
    Sep 2008
    #9727
    hello mga fellow tsikoteers and mga kainnova!!! may problem ako.. nakabangga ako ng sentra sa may recto. at yung front bumper ko ay medyo bumagsak ng half inch at kita na lumuwang talaga,,, cover pa naman ng insurance.. advice naman po jan oh.. medyo paluwang ng paluwang yung bumper e. insurance ba o pagawa ko muna sa talyer? salamat sa mga reply in the future.
    #9728
    Quote Originally Posted by innovablaze View Post
    bro hope you're alright. meron ka bang police report? dalhin mo na sa casa yan para mapalitan na ng bago, sayang lang ang bayad mo sa insurance kung hindi sila ang gagastos niyan. dapat pati yung perwisyo sa sentra ay insurance ang magbabayad.
    Apr 2008
    #9729
    question lang guys.
    how do you fix the kalampag of the brake pedal pag nalulubak.
    thanks!
    Jan 2009
    #9730
    so ok lang ang ganito na may lumalabas na water? pareho kami ng nangyayari sa nagtanong din. bale ngayon lang sya dahil medyo naka full blast din a/c because too much heat ngayong summer.
    Aug 2006
    #9731
    Quote Originally Posted by wlc View Post
    question lang guys.
    thanks!
    Are you sure it was the brake pedal? if so that is seriously dangerous!
    Why don't you seek advice from a mechanic?
    You can also have it checked at Servitek, maybe you have a warped rotor disc or worn out disc pads, or a loosen brake pedal hinge/bearing or a worn out out brake switch assembly.
    Aug 2006
    #9732
    Quote Originally Posted by jlaw888 View Post
    Normal lang na may lumabas na condense water sa outlet ng condenser unit. There are 2 condenser unit. Pag sa loob ng cabin tumulo ang tubig yan ang di normal
    Oct 2005
    #9733
    Quote Originally Posted by Mile2 View Post
    Nacontact ko na si Migs. He would checked it and advised me of the problem. Should I prefer not it fixed by them, he would charge 800 for removing and installing the alternator again. Toyota p.tamo charge me 600 for checking the alternator. Anyways, baka sulit nman cguro sa speedyfix kasi recommended nyo. Sana nga diagnose at kung alternator man, sana mura lng magastos ko.
    Oct 2008
    #9734
    Just got my friends innova j... mileage is 3k kms.. so pwede na rin.. got it cheap.. anyways.. just thinking if i can have it installed with power windows.. thru casa sana.. any ideas how much it would cost? tia
    Aug 2006
    #9735
    It might not be the alternator, it might just be the pulley/tension bearing.
    As alternative to SpeedyFix, you can try Raymond Sarrol. (0920-9252290)
    Had the same problem before with my Lancer and Raymond Sarrol fixed the tension bearing at no labor cost when I did brake check up and tune up. He uses a long steel rod as stethoscope to detect the source of squeaky and grinding sound.
    Not sure if he can do Innova, but since your problem is external to engine then I guess he can manage that at a minimal cost. He instruct me to buy a specific brand of bearing at Shaw Blvd and he install and press the bearing to the pulley receiver manually in his shop.
    Raymond Sarrol is very popular in MyMitsu club as a very competent mechanic and I do admit that I am very impressed with his talent and dedication and honesty. I grew up in the midst of all sort of car and diesel mechanics in my younger years and I can say Raymond Sarrol is one of the best I ever met in terms of know how and skills.
    He has small shop in San Juan near Aquinas College and is somehow near SpeedyFix in Shaw blvd.
    Aug 2006
    #9736
    May 2005
    #9737
    question lang guys.
    thanks!
    Check this thread out. It could be the bushing holding the pedal.
    Apr 2008
    #9738
    *number001
    thanks very much for that link. i now know what to do for my brake pedal rattling. it seems na isa din pala ito sa mga sakit ng toyota kala sa akin lang may problem na ganun.
    thanks!
    Aug 2008
    #9739
    Hi to all innova owner, I just had my 15,000km PMS at toyota balintawak north, while talking to the SA he advised me to use X-1R additive since I'm only using mineral oil but I refused to use additive for my car. Ask ko lang po kayo kung maganda gumamit ng X-1R sa innova natin magiging mas ok ba performance nya especially kung diesel.tnx
    Oct 2005
    #9740
    Mga pips, reasonable price ba yung promo ng toyota ngayun? Example for an INNOVA DIESEL, it cost Php 11,794 (parts, labor, materials + VAT)?
Toyota Innova Owners & Discussions [ARCHIVED]
