guys may nakapagPMS na ba senyo ng 15,000kms..magkano lahat?pati anu ginawa?TIA
Hi All,
I just got my Innova J today. Ask ko lang po sana kung ma vo-void ang warranty ko should I get the back sensor done outside?
Salamat po.
Tanong ko lang...kasya ba yung bagong grill at ilaw sa likod ng bagong innova (facelifted) sa atin?
Hi Guys,
I just want to know if its advisable to put turbo timer in the Innova? Makatulong po ba cya?
Pinalitan na yung drive belt ng unit ko last week. Saturday ko nakuha. Kaso nung monday, umulit uli yung noise. though, ndi ganun katagal o kalakas gaya ng dati. binalik ko sa casa for observation ulit. 30-day nman yung warranty ng job/work ng casa kaya walang fee. Kaso, I'm afraid na baka alternator or compressor na ang mapalitan or other parts na mahal. 15K yung alternator asembly sa casa.
Original ba talaga yung toyota parts dun sa store na 'gant' sa pasay? Magkano kaya ang alternator at compressor dun? Pwede kayang bumili ako dito sa store na ito tas dalhin ko sa casa yung part? Labor na lang babayaran ko sa casa pagnagkataon?
Has anyone here already had these parts replaced or repaired in casa or elsewhere?
Before they think it's the compressor or alternator, they should look at the "pulley bearing". They would need to have the mechanic stethoscope to rule out the source of squeaky noise.
Pulley bearing outside casa cost no more than 200 petot.
For alternator, you can have the alternator "ball bearing" replaced outside if that is really the source of the noise. It should cost you less than 1K for parts and labor, you can try SpeedyFix at Shaw Blvd.
hello gud morning
just wanna ask will a 5x114pdc 18x7.5 offset +48 with tires 235/50/r18
would fit on innova?
wala bang rubbing sa fenders ? thanks![]()
Thanks Mile2. As per SA, they used that stethoscope. I am not just sure how thoroughly they investigated the problem. Basta nung nakitang may consumer plastic o supot na nakapulupot sa idler nung tinanggal yung drive belt, the SA gave me a ring to advise na yun yung root cause and mas okay na palitan na rin yung drive belt. Since sa tuwa ko na hindi alternator, I gave him the go signal to replace the belt. Kaso umulit naman. 3500 yung belt tas 1400 yung checkup at labor ng pagpapalit ng belt.
Can anyone refer someone from speedyfix? kaya ba ng isang araw ang repair? Sa Makati, saang shop ang kayang mag diagnose at magrepair ng agnitong problem? Thanks.
