when we got our innova less than 5 km ang odometer.
good luck on your up grades
http://www.cardomain.com/ride/2174324
http://www.cardomain.com/ride/2498716
hello everyone!
I'm newbie here. this is my first time to post in this website. I got my innova J d4d variant last year and so far satisfied naman ako sa performance nya.
May question lang ako. just recently we had our stock rims replaced dun sa Banados ata yun. Wala ako alam sa sasakyan so i don't know what usually comes with the package. Basta kinabit lang yung bagong mags tapos kinabitan nung para sa wheel alignment ata yun then sabi sakin di daw naka-align yung camber. tinanong nya ako kung di daw ba kumakabig sabi ko hindi naman. kung gusto ko daw ipa align 1.6k daw sabi ko wag na (nagmamadali na rin ako kasi may lakad pa ko nun at saka duda rin ako kasi di ko naman alam yung ginagawa nya.. malay ko ba kung talagang di naka align yung pagkakabit nya hehehe at isa pa wala naman akong nararamdaman na kakaiba sa sasakyan ko). Now, i noticed na everytime na aabot ako ng 120kph nag wiwiggle na yung wheel ko pero dati naman wala akong nanonotice na ganon kahit umabot pa ko ng 150kph with my stock rims. Ano kaya sa tingin nyo ang problema?
TIA
do you take note of the average speed based on the MID? my average speed is only 13km/hr pasig-makati-paranaque and back, rush hour both ways. my d4d a/t only gave me 6.66km/l last week. naka 2,500km pa lang ako and i used mineral oil for the 1T km pms, i'll try synthetic next pms.
kinda hard to believe the 10-11 km/l city driving FC of mile2 (2.0 vvti M/T}
with my G mt d4d, i only get 8.5-8.8 km/l city driving. bihira ako umabot ng 9 km/l even with semi synthetic oil and i also do neutral shift on downhills and even when nearing red light
mine is g m/t d4d i would probably get 10-11 km/l city driving coz travelling from lucena to quezon city to makati to laz pinaz to airport back to lucena got 13.1 km/l sa info display (computer read)...provincial trip when we reach to diff town is like stop and go sa manila but once pass to town proper mga slow moving vehicle naman ang ma eencounter... provincial road 60-100 km speed/SLEX 90-120kph with 8 people onboard to calculate it from actual millage to this formula total km run/fuel consumed it always more than the computer read...i could get 14-15 km/l...slight diff on consumption when we go to tagaytay/enchanted kingdom 6 people onboard computer read 13.3 km/l...
*surg
sir medyo malakas yata sa fuel yong ride mo or cguro galit
ka sa speed lagi hataw hehehe...sarap kasi minsan lalo na pag open road/highway and asphalt yong daan...
i think may nabasa na akong similar sa problema mo ndi ko lang matandaan meron pa dyan nag advice sa kabilang thread...in changing mags and tires compulsary yong wheel alignment check this is not just about the performance ng ride mo but for the safety as well...plan ko din mag palit ng mags and tires but i have a second thought na cgro to be practical ang purpose ko lang naman is to enlarge the tire kasi sa malayo the tires look tiny talaga so tires na lang ang baguhin ko with this config 215/70/15 yong stock mags pa din ng 'g' variant ang gamitin ko....sa mga tsikoteers na familiar sa tires ok ba yong "michelin energy xm 1" yan kasi yong recommended nong shop na napagtanungan ko...
I'm surprise too. During my 1st week I was disappointed getting 7.6 Km/l but gradually FC improves dramatically.
D4d and Vvti are two different engines with different technology and would really be hard to compare against each other. I tried reading the specifications but I'm not a guru on what factors to look for at http://www.toyota.com.ph/cars/new_cars/innova/specs.asp
All that I can say is D4d has a greater curb weight, and bigger bore and stroke. Needles to say D4d is a bigger engine than Vvti.
madali lang tangggalin ung center console. hilahin mo ung tatlong knobs (air direction, aircon, thermostat). then dun sa aircon knob meron philips screw dun. tanggalin mo lang ung screw then pull mo lang ung center console, tanggal na yun. naka clip lang naman yun e.
yung stereo meron 4 bolts yun, unscrew mo lang tanggal na.
hi saipeme
the computer read is not accurate. i always shift gears at 2000 rpm and alalay sa accelerator but i still get only 8.5-8.8 km/l city driving with lots of stop and go because of those tricycles na sobrang dami dito sa amin. hey guys, do you think something is wrong with my innova?
sir question lang po about revolution, during starting nasa 2000 rpm sya pero bumababa naman sa 750 rpm... maingay kapag nag-start... talaga bang ganoon o mataas sya (innova 2.0Vvti G)??? during idle naman at buhay aircon nasa 900 rpm sya... nasa 550 km pa lang odo...
yes i know its not accurate, to get the accurate fuel consumption is odo reading/fuel consumed... if i done this i always got 0.5-1.5km/l more millage,but don't think its 100% accurate too kasi fuel consumed is just assumed based from when you refilled to the next refill...i used the computer read as my reference to monitor ika nga kasi it varies from 12.3-13.3km/l...peace!
Bro, wala akong issue sa rattling sound sa dashboard.Gusto ko lang makapagkabit ng speakers sa rear trunk.
Normal yan, reaching 12K na ODO ko at same pa rin during cold-start na mataas ang RPM. Maingay talaga ang makina sa start up dahil sa lakas ng RPM pero kusa siyang bababa pag nakuha na yung desired temperature and oil pressure. I think this is really how the ECU was programmed.
Try mo gamitin and then patayin mo makina, then start again, notice mo na hindi na ganoong kalakas ang RPM kasi mainit na makina at mayroon ng build up pressure. Sa cold-start lang malakas ang RPM.
