Page 8 of 28 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 559
    #141
    if its still unavoidable even if the charcoal canister and gas tank is replaced, then the flaw is in the tank design - tank shouldn't warp easily even if in sustained pressure - wheter postive or negative.
    Aug 2006
    #142
    I would agree that there's a problem in gas tank design. Point of fuel leakage and metal breakage was consistent - it is always underneath the front gas tank support.
    Aug 2011
    #143
    Oct 2008 purchased innova (facelifted) gas variant
    Tanong ko lang kung kasali ba ito sa gas tank problem?
    Balak ko munang palitan yung fuel filler cap pero hindi ko alam kung ito yung revised (mas malalaking butas). Hindi ko kasi alam ang ichura nung luma o bago. Papost din ng picture ng old and new filler cap kung meron. Salamat ng madami mga boss
    #144
    so, ang solusyon for a brand new innova vvti is change to a lpg para wala na talagang problem sa gas tank? or nasolve na ang problemang ito by changing the gas tank design for the 2011 and up models? nalilito ako kung anu gagawin. hope someone can update the status of this problem.
    Dec 2007
    #145
    Quote Originally Posted by b3ndz View Post
    Note, it's not change to lpg but just a kit installation for you to be able to run on lpg. Installing an LPG kit is not a specific fix. When you're not using gasoline, there is no vacuum being developed for obvious reasons. It's just a positive effect of having the lpg kit. If you're experiencing the symptoms, popping of tank, significant vacuum when removing fuel filler cap, then it's probably time to go to the dealer for an inspection.
    Question for Mile2, what does a charcoal canister do? Are D4D fuel tanks equipped with it as well. TIA.
    Mar 2007
    #146
    Guys ask ko lang if theres a charcoal canister for D4D engines?If there is where can I find it?
    tia
    Aug 2006
    #147
    Quote Originally Posted by timo07 View Post
    Here's some reading articles of Charcola canister. The Purpose of a Charcoal Canister | eHow.com
    Not sure of D4d if it has charcoal canister.
    Aug 2006
    #148
    LPG conversion is NOT the solution for this problem.
    To make thing simpler:
    If you do not have this warping gas tank problem problem you will need not worry.
    If you experienced this problem: You should replace three parts strictly to correct the problem:
    1. Gas Tank Assembly
    2. Charcoal Canister
    3. Fuel Filler Cap
    And most importantly, don't fill your fuel up to the neck of your filler port most of the time.
    Hope this clears things and I think newer models don't experience this anymore as there are no more complainants in this board.
    Jan 2008
    #149
    pag diesel engine walang canister.. pero may one way valve yan to let air in.. sa gasoline engine kasi nag produce ng vapor ang gasoline kaya need yan to vent out.. but environment regulations don't allow venting of gasoline vapor hence for the use of canister to process the vapor back to the tank...
    Dec 2007
    #150
    Quote Originally Posted by Mile2 View Post
    Thanks Gents for the info on Charcoal Canister. Every now and then, I would remove my fuel filler cap and would not encounter any negative pressure. So I guess the problem is limited to gasoline variants.
    #151
    3. Fuel Filler Cap
    Oh well,- hope that ours doesn't manifest this.....
    14.6K:dj:
    Jan 2012
    #152
    Hmmm ma tsek ko nga rin sa kin, Dec ko lang binila VVTI ko Innova j. mas ok na yung aware sa mga ganitong problem para avoid hassle.
    #153
    Good day! I'm the latest victim of the leaking gas tank. my ride is 2006 innova G vvti.. Same spot of damage/dent sa gas tank kagaya nung mga nagpost. And as i've read the whole thread i assume the culprit is the defective charcoal canister? I'm here to ask for your opinion lalo na dun sa mga may first hand experience. Do you suggest na palitan yung 3 major parts? (gas tank assembly, charcoal canister and filler cap). I called toyota and it will cost me around 26k for the 3 parts, wala pa yun labor. Is it a must na palitan yung 3? im thinking if ipa-repair ko yun tank and bili na lang ako ng bagong charcoal canister and filler cap. But my problem is where can i have my gas tank assembly removed, and where can i have it repaired. I'm torned and thinking palitan na yung 3 parts kaso ang bigat talaga lalo na biglaan ang gastos. Hoping i could get some reply, lalo na kila sir miles. Im trying to send you a PM kaso puno na ata inbox mo. thanks mga ka tsikot! more power.
    Aug 2006
    #154
    Hi sir Cast_no_shadow,
    Yes, mabigat sa budget para palitan lahat pero kung may pera naman it is highly advisable. Gas tank assembly alone cost roughly more than 20K pesos. Ako noon sinubukan ko pa Epoxy steel pero 1 week lang tinatagal at nalulusaw din yung epoxy.
    Gas Tank puede ba irepair? Yes I saw and talked to one subconctractor at TMBC who happens to pull out a leaky gas tank. What he told me that he is from Paranaque but I really don't get exactly his location since I'm not very familiar with his area. He told me that the tank will be repaired using hot rod + lead (suplete sa tagalog), they would submerge the tank in water during the Lead soldering. All the warped and dents will be flatten back and aside from Lead soldering they will solder a large metal sheet plating with exact fit on the affected corners (I think this is the same procedure on assembling copper molded car radiators).
    I have talked to a friend welder and auto body rebuilder and he told me that the above procedure for the gas tank is okay.
    You can scout for talyer or auto body rebuilding shops (with decent lifter or ramp) that can pull down your tank and repair it, In my opinion, if they would charge P2-3K for the procedure it is much better considering replacement cost of P20K
    If you have succeeded in having your gas tank repaired, replace the Charcoal canister and Filler cap to be sure it will not reoccur.
    Good Luck sir.
    #155
    Thank you for the prompt reply sir mile2. Until now I'm confused and torned on what to do. Ang hirap nga humanap ng nagrerepair ng tank, yun talaga ang priority ko kaso hassle talaga. Sayang akala ko you tried na ipa-repair by the means nung suplete. Napapaisip nga ako safe ba na irepair yun tank? hindi kaya sumabog yun kahit alisin na yun gas sa loob?Kung meron lang sana shop na may lifter and at the same time dun na din irerepair yun tank ayos sana. Ang hirap kasi na sa magkaibang lugar aalisin yun gas tank assembly which means im oblige na dun ko iiwan yun sasakyan then ipapagawa ko naman sa ibang shop yun tank. As i observed my ride, nag uumpisa lang siya mag leak pag pinatay na yun engine pero as time passes by tumitigil din siya. Napansin ko din na after turning off the engine, pag binuksan ko yun filler cap may narerelease na hangin, parang sumisingaw siya. I'm thinking, since ginagamit ko pa din as everyday ride delikado ba yun? am i riding a walking timebomb?. Buti pa kayo naayos niyo na yung problema ng innova niyo.
    #156
    I think that is normal. Same with our ride. But, I am getting worried....
    Bros,- where is the exact spot where the leak is occurring? What are the tell-tale signs that there is an inherent problem? Can someone please share pictures of the tank and point out where the leak occurs (and if possible how it looks)?
    TIA.
    15.1K:bouncealt:
    #157
    May handwritten number ba ang gas tanks ninyo?
    Ours have it,- it looks like a chalk or a permanent white marker, and you can see it if you look underneath from the driver's side. It is written on the near-side of the tank and ours read 113xxx GAS 09....
    15.1K:bouncealt:
    Oct 2003
    #158
    i had experienced this on my 2006 innova gas. buti na lang warranty pa. that time around 30K ang palit ng gas tank, charcoal canister and filler cap. right now i have a 2011 innova gas (forever innova! haha), i noticed pinalitan na nila yung design ng filler cap. yung dati pag sinasara ang tunog eh..."krrrrrrrk". yung ngayon eh..."krik"
    #159
    ours is a 2005 G innova gas, ran 35k km and never had this problem. most of the time fill to the brim pa kami. knock on wood, hopefully hindi mangyari sa amin.
    #160
    TIA.
    15.1K:bouncealt:
    Bro ang tagal ko na sa tsikot forums kaso until now (nakakahiya man) i don't know how to attach a picture sa post.
    by the way have you checked you gas tank assembly kung may dent na ba siya? nakalubog papaloob? yung dent nung sakin is medyo malaki na, after siya nung brace that supports the gas tank. Tapos dun sa edge siya nag leleak. After turning off the engine it will leak for a while, patak patak then it will stop na din. I'll try to check later kung may handwritten number yun gas tank ko, ano kaya yun? parang identification number?
    By the way hindi ba advisable na magpa full tank? after ko kasi malaman na nagleleak yun gas tank ko iniwasan ko na muna magpakarga ng marami. siguro maximum ko na pinakarga is 10 liters.
Toyota Innova Gas Tank woes
