Results 111 to 120 of 560
- Dec 2010
- 2
December 13th, 2010 10:04 PM #111For all Innova owners better start checking our tanks....mahirap na baka sa huli ang pagsisisi....
- Nov 2007
- 2
December 14th, 2010 07:09 PM #112hayy yung sakin tumagas na naman. Yung una na remedyuhan namin sa talyer, after 2 weeks tumagas na naman. Ngayon ko lang nabasa itong thread na ito meron pala talagang ganitong problema. Try ko muna maghanap nang 2nd hand na gas tank na walang sign of warping, then bili ako nang charcoal canister and new filler cup. Meron na bang nakabili nang charcoal canister sa banawe? sana me makita ako mas mura. Kung wala sa casa talaga.
- 54,247
December 14th, 2010 08:11 PM #113a few years ago, we put E-10 gasoline in our car and didn't use it for some time. a few weeks later, we tried starting it, but it refused to. finally, after looking at everything else, we found out that the fuel inside the tube and tank had solidified! we replaced the victimized parts.
i am thinking now, that, is it possible the innovas being mentioned in this gas tank deformation mystery, are a victim of their breather tubes being clogged by alcohol-gasoline fuel mixture? has anyone examined the breather tubes of these tanks?
btw, we had since sold this car...
- Nov 2007
- 2
December 15th, 2010 09:30 AM #114hindi kaya sa vacuum valve ang problema? i got this from toyota otis website:
Fuel Tank Cap
What is a fuel tank cap?
It is a cap for the fuel tank.
Importance of inspecting the fuel tank cap
If the gasket is damaged, gas evaporates into the air.
If the vacuum valve malfunctions, air cannot be drawn into the tank to replace the fuel used. Then, a partial vacuum occurs in the tank causing an indentation
Evaporated gas
In the fuel tank, some fuel vaporizes, containing a large volume of poisonous HCs (Hydrocarbons).
Gasket
Vacuum valve
December 17th, 2010 07:37 AM #115
update lang sa innova namin. i-cover na daw ng casa under warranty sabi ng SA palit tank (daw) and cap kahit almost 4 years old na yun car. di daw sila aware na may defect ang tank ng innova
e bakit pati yun cap papalitan nila?
guilty haha. kaya yun may mga out of warranty na sa inyo try nyo na din muna sa casa sayang e
- Dec 2010
- 3
December 27th, 2010 01:55 PM #116
December 29th, 2010 03:23 PM #117
January 5th, 2011 11:30 AM #118
our 2005 vvti innova, with 28,000km doesnt have the gas tank problem. laging full tank yung innova namin kahit hindi namin gamit.
- Jun 2010
- 31
January 5th, 2011 11:34 AM #119Na-gawa na Innova namin thru casa kahit out of warranty. I'll post the story later. Don't pay out of pocket.
January 5th, 2011 04:22 PM #120
Kindly post your story.
Ako 2 months ko pinaglaban yung 2nd gas tank ko sa casa..
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
