Results 171 to 180 of 559
April 12th, 2012 02:24 PM #171
Just a precaution, I do monthly check on my under chassis parts. If I see gas tank floor warping then I think that's the signal to replace charcoal canister and filler cap.
- Feb 2011
- 3
April 13th, 2012 01:59 AM #172I also encountered this gas tank leak recently but observed coming from a dent under the tank which possibly hit by hard stone or object. I am puzzled only why the leak occurs only between 9-10am & by running the car for about 1 km, the leak stopped....
April 13th, 2012 08:52 AM #173
April 13th, 2012 09:26 AM #174
It was not hit by hard object. If the dent is located near the front strap support and the leak was located at the corner bends in the perimeter of the front strap support, it is the warping syndrome caused by negative pressure when you run the engine, in few more days your leak will get worse. Have your tank repaired immediately and replace the charcoal canister and filler cap. You need to act now or else your car might be part of statistic of burning Innova on the street.
- 11
April 13th, 2012 10:25 AM #175
April 14th, 2012 12:17 AM #176
welcome to the club bro! wag na hayaan lumala yan, ganyan din ako nung umpisa since tumitigil din ang leak i'll just let it pass until my nightmare came ang lakas na ng leak. obserbahan mo after shutting the engine off, buksan mo filler cap mo then look under your car mag start na leak niyan. Have the leak repaired, change the charcoal canister and filler cap. im about to buy my new charcoal canister and filler cap this week.
- Sep 2011
- 623
- Feb 2007
- 80
May 22nd, 2012 09:18 PM #179
May 24th, 2012 02:44 PM #180
Yepp. Hit or miss talaga Chinese-English translations.
Amaron battery
