Results 151 to 160 of 560
November 10th, 2011 10:11 PM #151
January 10th, 2012 09:53 AM #152
January 13th, 2012 10:45 AM #153
Hmmm ma tsek ko nga rin sa kin, Dec ko lang binila VVTI ko Innova j. mas ok na yung aware sa mga ganitong problem para avoid hassle.
March 3rd, 2012 11:42 PM #154
Good day! I'm the latest victim of the leaking gas tank. my ride is 2006 innova G vvti.. Same spot of damage/dent sa gas tank kagaya nung mga nagpost. And as i've read the whole thread i assume the culprit is the defective charcoal canister? I'm here to ask for your opinion lalo na dun sa mga may first hand experience. Do you suggest na palitan yung 3 major parts? (gas tank assembly, charcoal canister and filler cap). I called toyota and it will cost me around 26k for the 3 parts, wala pa yun labor. Is it a must na palitan yung 3? im thinking if ipa-repair ko yun tank and bili na lang ako ng bagong charcoal canister and filler cap. But my problem is where can i have my gas tank assembly removed, and where can i have it repaired. I'm torned and thinking palitan na yung 3 parts kaso ang bigat talaga lalo na biglaan ang gastos. Hoping i could get some reply, lalo na kila sir miles. Im trying to send you a PM kaso puno na ata inbox mo. thanks mga ka tsikot! more power.
March 4th, 2012 10:34 AM #155
Hi sir Cast_no_shadow,
Yes, mabigat sa budget para palitan lahat pero kung may pera naman it is highly advisable. Gas tank assembly alone cost roughly more than 20K pesos. Ako noon sinubukan ko pa Epoxy steel pero 1 week lang tinatagal at nalulusaw din yung epoxy.
Gas Tank puede ba irepair? Yes I saw and talked to one subconctractor at TMBC who happens to pull out a leaky gas tank. What he told me that he is from Paranaque but I really don't get exactly his location since I'm not very familiar with his area. He told me that the tank will be repaired using hot rod + lead (suplete sa tagalog), they would submerge the tank in water during the Lead soldering. All the warped and dents will be flatten back and aside from Lead soldering they will solder a large metal sheet plating with exact fit on the affected corners (I think this is the same procedure on assembling copper molded car radiators).
I have talked to a friend welder and auto body rebuilder and he told me that the above procedure for the gas tank is okay.
You can scout for talyer or auto body rebuilding shops (with decent lifter or ramp) that can pull down your tank and repair it, In my opinion, if they would charge P2-3K for the procedure it is much better considering replacement cost of P20K
If you have succeeded in having your gas tank repaired, replace the Charcoal canister and Filler cap to be sure it will not reoccur.
Good Luck sir.
March 5th, 2012 11:31 PM #156
Thank you for the prompt reply sir mile2. Until now I'm confused and torned on what to do. Ang hirap nga humanap ng nagrerepair ng tank, yun talaga ang priority ko kaso hassle talaga. Sayang akala ko you tried na ipa-repair by the means nung suplete. Napapaisip nga ako safe ba na irepair yun tank? hindi kaya sumabog yun kahit alisin na yun gas sa loob?Kung meron lang sana shop na may lifter and at the same time dun na din irerepair yun tank ayos sana. Ang hirap kasi na sa magkaibang lugar aalisin yun gas tank assembly which means im oblige na dun ko iiwan yun sasakyan then ipapagawa ko naman sa ibang shop yun tank. As i observed my ride, nag uumpisa lang siya mag leak pag pinatay na yun engine pero as time passes by tumitigil din siya. Napansin ko din na after turning off the engine, pag binuksan ko yun filler cap may narerelease na hangin, parang sumisingaw siya. I'm thinking, since ginagamit ko pa din as everyday ride delikado ba yun? am i riding a walking timebomb?. Buti pa kayo naayos niyo na yung problema ng innova niyo.
March 6th, 2012 09:15 AM #157
I think that is normal. Same with our ride. But, I am getting worried....
Bros,- where is the exact spot where the leak is occurring? What are the tell-tale signs that there is an inherent problem? Can someone please share pictures of the tank and point out where the leak occurs (and if possible how it looks)?
TIA.
15.1K:bouncealt:
March 6th, 2012 09:37 AM #158
May handwritten number ba ang gas tanks ninyo?
Ours have it,- it looks like a chalk or a permanent white marker, and you can see it if you look underneath from the driver's side. It is written on the near-side of the tank and ours read 113xxx GAS 09....
15.1K:bouncealt:
March 6th, 2012 11:16 AM #159
i had experienced this on my 2006 innova gas. buti na lang warranty pa. that time around 30K ang palit ng gas tank, charcoal canister and filler cap. right now i have a 2011 innova gas (forever innova! haha), i noticed pinalitan na nila yung design ng filler cap. yung dati pag sinasara ang tunog eh..."krrrrrrrk". yung ngayon eh..."krik"
March 6th, 2012 11:34 AM #160
ours is a 2005 G innova gas, ran 35k km and never had this problem. most of the time fill to the brim pa kami. knock on wood, hopefully hindi mangyari sa amin.
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
