Page 26 of 28 FirstFirst ... 1622232425262728 LastLast
Results 501 to 520 of 559
    Jan 2013
    #501
    Quote Originally Posted by elmer_eleria View Post
    Salamat Sir.
    Magkano inabot ng sprint booster throttle controller? Yung delay ba both sa manual and automatic?
    12k yung sprint booster UK brand kse sya pero may mas mura 5k lang E-Shadow Taiwan brand. yes both manual and automatic yung delay.. pero mas ramdam sa AT.. d ka magsisisi dun sir.. para sakin value for money yun
    Jul 2006
    #502
    Thanks Sir. San nyo sya napa install? Or meron na rin sa casa?
    Jan 2013
    #503
    Di alam ng mga tao sa casa yan sir.. tinanong ko yan sa kanila bago ko pinakabit.. sabi lang sakin di na raw kelangan kse meron na raw nakakabit.. di na lang ako nakipagtalo..
    kay sny4x4 ko pinakabit.. sa Sgt. Rivera cor. A. Bonifacio shop nya.. free installation na yan.. wala pa 10 minutes kinabit yun..
    12k - 6 months installment * 0% interest.. imho..
    Jul 2006
    #504
    Ok salamat sa tip sir!
    Mar 2015
    #505
    Quote Originally Posted by shibby75 View Post
    Dont worry, vvti lang ang me problema sa gas tank.
    Iba ang problema ng diesel d4d. Injection failure and loss of power.
    Sir shibby75, does this still occur on the latest models? Planning to get a 2.5G Dsl AT before the month ends actually. If you could shed some light on this, I'd really appreciate it. Thanks!
    Jun 2006
    #506
    Injection failures eventually happens as the car ages, more like 200k mileage, maybe earlier if dirty fuels are used. At 200k, madami na din masisira sa kotse, gas or diesels. Its all on how you take care of your car.
    Mar 2015
    #507
    Thanks sir shibby75. I guess it would be wise to have this checked on the 100k maintenance then? Or earlier perhaps?
    Jul 2015
    #508
    Planning to get the 2014 E 2.0 gas variant hopefully within this month. Shall I really worry on the gas tank issue? By experience, ano earliest number of years from purchase usually lumalabas na yung defect?
    Big thanks.
    2006 model, leaked last month same spot where most owners experienced leaking. just bought new fuel lid cap fron TQA, will drive later to see if negative pressurization of the tank still persist. replaced gas tank.
    #509
    How about the leak? You have it repaired? Or replace gas tank assembly?
    Mga first gen ang may problema talaga.
    I'm still waiting for mine to warp again and leak. Huwag naman na sana.
    Replaced filler cap and charcoal canister already.
    #510
    Am always inspecting my gas tank.
    So far, no sign whatsoever..
    #511
    Sneaky yan boss parang mga katoto naten dito sa tsikot [emoji23]
    Hopefully hindi mo ma encounter.
    Oct 2013
    #512
    If you will ask me, it is the old filler cap lang dapat pinalitan mo.
    Jul 2015
    #513
    Quote Originally Posted by Mile2 View Post
    I would agree that there's a problem in gas tank design. Point of fuel leakage and metal breakage was consistent - it is always underneath the front gas tank support.
    Olus 1 here, replaced my fuel tank, replaced fuel tank lid cap, still popped, next i will drill a smll hole in my original lid cap so that negative pressure will not persist, problem is that i am not sure if it is safe.
    Oct 2013
    #514
    Can you post a pic of your new fuel tank lid cap?
    If it just the same as the old one, it will give no improvement.
    Dec 2014
    #515
    My cousin told me na advise sa kanya ng toyota after a long drive or paguwi sa bahay, buksan yung gas tank para sumingaw daw yung naipon na pressure then close it again. Parang nagbubukas ka lang ng bottle ng coke. Ganon din before you leave in the morning. Mejo hassle lang pero mas hassle kapag nagleak na yung gas tank. At kapag magfulltank wag daw yung sagad, automatic lang. Hope this helps.
    Oct 2013
    #516
    Yung unang gas tank lid cover ng innova na gas ang may issue, kasi di sya nagpapapasok ng hangin. Yung bago na lid ang gamit ko ngayun.
    #517
    Quote Originally Posted by vvti2.0 View Post
    Can you kindly post pictures of before and after bro for our common reference? TIA
    Jul 2015
    #518
    Cast no shadow,
    sir i did replace the gas tank assy 16k, fuel lid cover 1.5k, still negative pressure persisted, popping of gas tank everytime i twist open the cap lid, wooooshing sound after short drive. I need to replace the charcoal canister. Bnd aid solution - drilled a small hole into the cap and wala no more wooooshing sound , [popping is also gone.. Trying to post the pic but cn't do it. I drilled the original cp, i still use the new one when it rains or just after i parked.
    Oct 2013
    #519
    If you will notice sa toyodiy..
    77310A CAP ASSY, FUEL TANK
    77300-28010 (08/2004 - ) 1 $46.54
    77300-52030 (08/2008 - ) 1 $41.99
    OLD tank cap
    NEW tank cap
    Oct 2013
    #520
    Quote Originally Posted by nowitzki41 View Post
    Yung naipon na pressure that makes air na lumabas sa lid, yun ang dapat, pero kapag di sya humigop yan ng hangin, yan ang problema. Di mo dapat pasingawin yung hangin, venting yan, bawal yan kung iisipin sa environmental regulations.
    Ang trabaho ng fuel lid ay humigop ng hangin galing labas at di ito palabasin, kung di sya humigop ng hangin, ang tendency ng tangke ay mag vacuum yun ang cause nung nabubutas ang tangke sa weakest point nito.
Toyota Innova Gas Tank woes
