Page 49 of 77 FirstFirst ... 3945464748495051525359 ... LastLast
Results 961 to 980 of 3575
    Aug 2013
    Quote Originally Posted by SkyFlakes88 View Post
    Ako po sa front sir. Put your best foot forward. Pag nag fail po yun tire sa front mas delikado lalo na during high speed runs kesa yun rear tire ang sumabog sir.
    Eto din logic na sinabi sa akin ng tatay ko.
    Anung logic jasonub bakit sa rear dapat?
    Thanks
    Quote Originally Posted by dos2 View Post
    Thanks
    ang sabi nila, pag sumabog daw o nawalan ng grip ang rear tire, mas mahirap i control.
    Thanks
    rear tires act like the feathers in darts or the fins of bombs and missiles. they keep the projectile (the car) pointed toward the direction of movement. this gives the driver some semblance of control.
    the tendency of drivers attempting to control their cars, is to put on the brakes. and if the front tires have good tread and the rear tires are bald, putting on the brakes may result in the rear skidding to the side and will then try to outrun the front end.
    remember that old adage...? "to regain control of the car, point the front tires in the direction of the skid." well, the assumption of that statement, is that the rear end will remain in the rear, and will not try to outrun the front.
    once the rear wheels start skidding (to the side), it is difficult to regain control of the car.
    remember also, that in today's cars, more of the car weight is on the front tires and less on the rear.. this makes the rear more likely to skid..
    i actually experienced this..
    driving down an underpass one rainy night, there was this stalled vehicle at the bottom. wala siya EWD.. when i saw it, i panic-braked. i got lucky, as my car stopped a yard before i hit it. (wala pa ABS noon..) but i noticed, after i had stopped, that my rear end was already about a foot or two, to the right of my long axis.. and all my tires were in good condition.. what if..
    bottomline... have all your tires in good condition.
    Mar 2015
    This true sir. Generally all 4 tires should be road worthy but that is not always the case in real life situations. Most owners will buy 2 tires at a time when that happens you have 2 of your tires new and the other 2 old. Question here is where should you best put your 2 new tires? To the front or at the rear?
    Aug 2015
    For me rear, follow the experts nalang lalo na rainy season. This advice covers all kinds of vehicles, whether front, rear, awd or 4x4 capable.
    Most likely scenarios:
    Front wheels are turned pero dumi direcho kasi madulas. Understeer.
    Rear wheels lumiliko kahit gusto dumirecho Oversteer. Sa sobrang liko pwede ka umikot.
    Mas madali i control ang understeer all day.
    Aug 2015
    Fyi michelin NA suggests you put the 2 new tyres sa rear.
    Ang harap macocontrol mo pa rin kahit papano pero pag nag skid ang likod.. well you do get the idea.
    Ideally 4 na bago, then rotate daw ng pa ekis front-rear left-right para pantay. Kung uni or bi directional ang tyres mo.
    Nov 2011
    Don't forget that the new tires should be used at the front sir. [emoji4] sa shocks po if you like try to search the no.of chuan lam. It's located sa bagac st. Tondo parallel lang po sa j.abad santos. They are the distributor of KYB shocks here.
    Okay sir. Will do. Malapit nadin ako mag PMS so I'll have it double check nalang din sa SA ng Casa.
    Quote Originally Posted by jasonub View Post
    Baligtad bro new tires dapat sa rear.
    it depends on the age of the literature that you read.
    Quote Originally Posted by unmarked View Post
    Sa harap ko siya pinalagay for now. I'll buy two more in a week or two para lahat palit na. Do you guys also include yun spare tire sa rotation since same lang naman sila ng stock?
    Mar 2015
    Quote Originally Posted by kiamoyman View Post
    Yes sir i include the spare in rotating my tires every 10k if possible or at the least sa 20k. Sayang kasi kung mag expire na lang yun spare nang halos hindi nagamit.
    Jul 2015
    Sirs, pansin ko na medyo matigas na yung clutch pedal ko. Nangangawit tuloy left leg ko kapag babad sa traffic. Paano po ba ma adjust o maayos yung clutch pedal?
    Quote Originally Posted by cocoy_g View Post
    wear and tear po.
    replacing "worn components" inside the transmission housing, will probably revert the lightness and smoothness of the pedal to as brand new.
    but it won't be cheap. labor alone, to open 'er up, is already expensive.
    but try to see if the pedal needs lubrication first, before thinking of the trans. it might do enough to soften up the pedal.
    if the car uses a clutch cable, replacing it with a new one may soften the pedal.
    but if the car uses hydraulics for the clutch, as i suspect toyota does, pedal lubrication and transmission components replacement lang ang choices, po.
    Mar 2015
    Most likely you have to replace your clutch set. If its still original. Worn out pressure plate,clutch disc and release bearing. But first try to bleed your system before going to the transmission.
    Usually that's the issue with Toyota Corollas and the Vios. In our case, we replaced the clutch to aftermarket AISIN (which is an OEM supplier for Jap brands), and the clutch would be much lighter than the original clutch.
    Jul 2015
    Sir vinj, saan po makakabili ng AISIN made parts? Salamat po.
    I buy ours from Toyorama in Banawe. My Gen 10.5 still has the original clutch, what i changed last was on our Gen 9.5 Altis and Gen 2 Vios.
    Aug 2012
    Mga bossing, just would like to ask regarding LUG NUTS of the 10.5 Gen Altis, do I need to change it if I were to replace my rims with the newer sets of rims from the current model (11th Gen)? TIA
    Jul 2015
    Sir, issue rin po ba ang oil sludge sa ZR engine tulad ng sa ZZ? Salamat po!
    Quote Originally Posted by Aleman View Post
    Possibly not. My OEM 17s on the Altis uses the stock lugnuts that came with the car.
    Apparently not but the issue on the ZZ came out on units that extended drain intervals to 10,000kms with FS oil (no oil filter changes inbetween). Otherwise, those who changed regularly at 5,000kms or swapped filters at the least, seem to have no issue on their ZZs.
    Aug 2012
    Thanks Vinj, sana nga hindi na, sayang din ang 4k petot....
    Aug 2012
    My tires needs replacement, I was actually looking at the 11th Gen rims and tires to replace it. Unfortunately, I wasn't lucky enough to find one that suits my budget, until I come across with this one, which I think is a good deal.
Toyota Corolla 10th Generation Altis Owners [continued]
