morning,ask ko lang anong ma susuggest ninyong 1.rearview and front camera (both) not sure kung dashcam pa din tawag dun that has 2.parking assistant.yung tipong makikita mo yung little screen sa rearview mirror,sorry another newbie question
I cannot see a thing..
Sent from my Lenovo PB2-670M using Tsikot Forums mobile app
Ooops, hindi yan, may nag offer sa akin 4.7k fullhd then split screen with parking assistant, ang l,problem is kelangan daw ng drilling, sabi ko pagisipan ko.mukhang heavy duty ehh..
Thanks Altuy...Pagisipqn ko pa ayaw ko kasi ng drilling pa bawat sensor daw ehh...
Hi, hindi ko alam kung tama un ginawa ko pero hindi ako makastart ng new message. Kaya pinili ko un reply with quote tapos dinelete ko un quote.
I just bought a 2011 1.6g A/T. I think I need to change the tires. In front, the manufactured year is 2013 while rear is 2011. I read that Ben’s Ok is good tire shop. Problem, anong brand and tire size un recommended sa altis? Ayaw ko ng china brand. Target price ko is below 4k per tire. Any suggestions?
Sorry po kung mali un style ko ng pag reply. Hindi ko alam paano mag start ng new message. Safari browser ang gamit ko. Thank you.
Try the ff:
Yokohama A.Drive
Yokohama A300
Bridgestone Ecopia
Bridgestone Turanza
For 16" mags, you will get tires at around 4k each.
Make sure you get tires that were manufactured recently lalo if you don't put a lot of kilometers on them. (Tires are considered worn after 10 years after manufacture or when the tires go bald).
Ok pa naman un 2 front tires. Makapal pa. Pero double check ko. But the 2 rear tires need to be changed. It is 2011 and i think nasa 70% thread pa.
Assuming the 2 front tires are still ok, should I buy the same tire dimension of the old tires? what should be the pattern of the new tires? Will I be putting it on front or rear?
Sorry for I have many questions. Un nabili ko na 2nd hand altis does not have casa maintainance records and I bought on buy and sell. So I need to have it change oil, oil filter and check all the necessary parts to be checked. With regards to change oil, san ok magpagawa or where to buy oil and oil filter? Un vios ko dati ginagamit ko ZIC oil and baldwin filter.
Also, may “tok” sound un steering wheel ko kapag ginagalaw ko pa right. Kahit pa left merun din pero mas malakas un pa right.
Nag back read ako ang sabi either rack & pinion, cv joint, ball joint or shock absorber. Saan din ok magpacheck? Sana po along QC. Sa fairview kasi ako nakatira. Thank you in advance.
Gano ba katagal ang dapat na palit ng tires kahit makapal pa? Some says 6 yrs. Some says 10 yrs. Ano ba talaga?
Sent from my SM-A9000 using Tapatalk
when my car's warranty ran out, i started changing oil w/ filter, at the gas station. the petron i go to, has an hecho derecho promo that includes the oil and the oil filter. pasok naman sa spec ang oil nila. less than 1.5K lahat-lahat, and i am done in under an hour. i do not use flush, engine or oil treatment, and even air. just gravity drain.
that "tok" sounds like CV joint. $$$!
Sakto magkakaroon ng sale ang s&r from sept 27 to oct 1. Baka may promo din sa gulong. Problema sobrang haba nanaman ng pila. So the price of the tire that I saw (kumho) worth 3.3k, that’s all i’m going to pay? May nakalagay kasi sa labas na fees. Baka siguro ineexplain lang nya un price pero free na sya. Sana meron promo na buy 3 get 1 para palitan ko na lahat ng tire. Salamat sir!
