Ha ha ha! I can't afford your serviceSpeedyfix is the shop near Xavier ba? I bought liquimoly FS and baldwin oil filter nga. I can't use it in the casa
Just wanna ask. We just got our 2nd hand Altis 2008 1.6G last week. Can I play music through my phone? Is there an aux cord somewhere? Or USB?thanks!
Anong mas mura? 11.3k kay speedy fix kasama lahat ng parts or labor lang? Sakin kasi estimate sakin ng speedyfix 4.5k labor lang.
Parts and labor na. Parang mas complete pa nga sa casa. Kasi may nakalista sa quotation sa iyo na hindi ko maalala na ginawa sa speedyfix.
Hi Guys, is there any identifier for Gen 10 and Gen 10.5? We're eyeing for a 2010 1.6G or V for our coding car. Thanks!
madaming difference in terms of body, but features wise, its the same.
salient difference between the G-10 and the G-10.5 is yung reflector sa rear bumper. the G-10 has round reflectors, the G-10.5 has rectangular reflectors.
may difference din sa trunk garnishing and slight difference sa front bumper.
mga sir tanong lang po kung magkano ngayon bentahan ng 2011 1.6g matic?
Anyone who experience this?..rpm'drops when engaging clutch 1st gear usually and 2nd gear also.you have to put some'gas in order to get more rpm so that the body will not vibrate or the engine dies.clutch is still good coz acceleration is fast.the only prob is the rpm drops down when engaging usually in 1st gear n 2nd.i already clean the maf sensor and the throttle valve with the spray throttle cleaner.
Nakaka sludge ba pag hindi masyado nagagamit yung auto? Once a week lang?
Is top end RPM still good or hirap yung engine to hit redline as well? If that happens, one possibility is the MAF is off-soec already. Re dropping RPM, perhaps an engine scan can help if you tried the possible culprit. I have the same problem on our 9th gen and the issue is the MAF which we have to replace.
As long as you get an service every year, and use a good oil and oil filter, should not be a problem. Make sure to drive the car hard once in a while too. Perhaps, akyat mo sa Skyway and drive it at 100-110kph on 3rd gear if conditions allow.
Hi vinj, won't a defective MAF Sensor light up the engine fault indicator on the dash? If not, how did the scan reveal this?
Hi Guys,
Ok ba yung Tein H Tech sa Altis 10.5 Gen? From those who are experienced in lowering their rides.
I'm thinking if I should improve my handling and height. All stock suspension ko. Any other items
to consider to avoid mismatch sa lowering springs? Thanks!
