Results 2,321 to 2,330 of 3575
June 30th, 2014 05:11 PM #2321
Guys,
Here's a bit of an odd request, perhaps.
How do you lift a Gen 10 Corolla?
Doing some research for my Mom. Who loves her Gen 9 to bits, and who has a Gen 10 but is having difficulty with the lower stance.
Medyo mababa kasi ang stance ng Gen 10, which is perfect IMO for bigger wheels and skinnier tires. Nga lang since it's my Mom's ride, we need the opposite of lowered.
Any ideas on how to increase the ride height? By about half an inch? Has anyone tried spacers perhaps?
TIA
July 4th, 2014 02:11 AM #2322
What are good replacement tires for out 10th gen? My car turned 4 yrs old na and I need to have the tires replaced na. Do I really need to replace all 4
July 4th, 2014 07:04 AM #2323
^Cat, kumho ecsta. Bang for the buck tire. From the reviews i get, it has good grip.
Sent from my Nexus 7 using Tapatalk 2
- Oct 2006
- 261
July 4th, 2014 07:26 AM #2324We chose the Bridgestone Turanza for reduced noise and comfort. Huge difference from the stock Dunlops, specially in SLEX. A little expensive at P 6k+ each. Had to replace all 4 because we rotated tires so the wear was even on all 4, used it for 35k+ kms. First time to ride in the highway already made the purchase worth it!
July 4th, 2014 10:02 AM #2325
Hi Guys, it's good to be back and I will be needing your help as well. I still have this clunking sound on the front end of the car and it's getting worse. I already replaced ball joints, stabilizer link, and the tie rod ends but the noise remains.. I can hear it from both sides. Then nowadays, I can already feel bump steers. For example in edsa,when I go over bumpy portions, the steering wheel veers left. What could be the culprit of this? I've done my research, and my suspects are sway bar bushings and control arm bushings.. Then maybe I might need good alignment. Any ideas??
Btw, I can notice from afar that my altis seems "lowered" on the driver side (maybe because most of the time, I drive alone and all the weight is on my side). How can I get this back to normal height? Replace coil springs?Last edited by kafph2000; July 4th, 2014 at 10:09 AM.
July 4th, 2014 12:50 PM #2326
- Mar 2008
- 54,246
July 4th, 2014 09:54 PM #2327
- Mar 2008
- 54,246
July 4th, 2014 09:58 PM #2328
July 5th, 2014 10:20 PM #2329
- Mar 2008
- 54,246
July 6th, 2014 09:51 AM #2330
Coolant...
