Page 215 of 729 FirstFirst ... 115165205211212213214215216217218219225265315 ... LastLast
Results 4,281 to 4,300 of 14580
    #4281
    Quote Originally Posted by KCboy View Post
    meron ba twinpines ng turbo timer, yung pasok sa slot sa dash, oem look??? qalam ko miggyboy meron panf fortuner and strada, but last i heard, they dont install....pag nakaset po ng 1minute, may pipindotin ka nalang, auto na ba yun, or everytime iseset mo yung time?
    dont know abt winterpine but miggyboy have 2 options for fortuner auto matic and manual turbo timer, all fit in the dash. difference bet auto & manual, is the allotmnt of time, for auto the board box auto select the duration of the timer base on the engine temp., but for manual it is in ur choice to set duration from 1 to 9 min., auto have .5 min interval and can be set manually, too bad they dont hve this for stradas. If u set it to 1 min, it stays on 1 min everytime u start and shut of the engine unless you reset it to 0 min.
    #4282
    on my turbo timer, i usually leave it on 1 minute. once set, every time you turn off your vehicles, the timer would start...no need to activate it all the time..as long as it is set for 1-9...automatic yung turbo timer. but once set to "0", turbo timer is off. hope that clarifies it.
    boybit: ah tlga..ganun pla yun..i was informed differently...for manual..its just a timer and you have turn it off pa...automatic was explained to me that onced set to specific timer (minute) just turn off and close the car and arm the alarm.thats it. thanks for the clarification.
    well timer is suppose to be changing of state between on & off , or off & on.for most of the mechanical and electrical eqpmnt regardless of manual or auto. it will change the state. the question is who will calculate the time. "manually" u calculate the time base on ur understanding for its purpose. "automatically engine" gives the data for the timer to calculate the time, besides i asked leira abt this as they offered me the timer to be auto but its not, i think thay havent seen the auto yet.
    #4283
    the power is more that enough.... at least 5 times ko na nareach ang 180kph sa skyway and nlex... yun nga lang tumaas FC ko hehehe
    pag nag palit ka na ng alteast 245/70 r 16 mahihirapan na yan. btw my next project is to make the ride more stable. I'm planning to put in stabilizer bar on the rear suspension to minimized the sway of the truck on un even surface. since i hve a canopy it tends to sway harder than w/o. coz the back of the truck is heavier and tall. I hve already change the shocks to old man emu. the ride nawala yun tagtag but mas malikot kasi malambot yun shocks thats where the stabilizer comes. pre inform me nalang kung kailan makakarating yun map light. pahahanap narin me sa thailand nxtweek ng ibang accesories
    Dec 2007
    #4284
    sure sir boybit... tawagan ko ulit eldorado bukas for the maplight
    Aug 2007
    #4285
    Quote Originally Posted by ericsiomai View Post
    i'm planning on towing 2 jetskis but hindi ko pa alam kung papano ko ikakabit ang tow ball and hinges kasi i got it before for my old pathfinder... since pick up naman sila pareho and molye ang rear suspension i bet kasya naman siguro. but in any case, sir arvin and wakeboarder, what are your equipments of choice for the towing? and...
    to everyone out there, any suggestions on how i can strengthen the support of my tailgate? apat kami nakaupo dun and we are roughly about 200lbs each and napansin ko na mejo stressed na nga siya. how can i strengthen this?
    salamat po!
    hi ericsiomai, check in ride banawe for the hitch receiver. i doubt if your pathfinder receiver will fit in the strada since it probably has a different mount. if you modify your old hitch to adapt to the strada, it might compromise the safety of your vehicle and your tow.
    Dec 2007
    #4286
    Quote Originally Posted by boybit View Post
    maybe,but that only deals with the wiring, hahanapan ka nila ng butas if something happen, but I know better how to preserve my own things , install in personally and make sure everything is in capacity, u know what umaasa lang cla sa mga workers nila which is a trainee, once pinagawa ko sa kanila yun malfunction ng door actuator sa driver side, nasira pa nila yun door lock na plastic, kaya nireklamo ko sa mitsu. then nag install cla tpms, nag loose naman.bara bara,palibasa d nila personal. pero sabi ng kasa tungkol sa turbo timer na ininstall void daw no matter where, by then if ur not installing turbo timer, masira turbo mo after warranty. mahal ang turbo. naka tie up ang winterpine sa original accesories na kasama sa car but beyond that la din cla pananagutan.
    ganun pala sa casa, mga trainees pala..kala ko talagang mga trained yung mga tao nila..sirugo yung mga head lang..
    oo nga mas mahal turbo kesa sa timer,hehe pa install na ako after my 1000k m check..thanks sir
    Jan 2008
    #4287
    Quote Originally Posted by wakeboarder View Post
    thanks wakeboarder. i did check sa ride and sabi nila kaya daw nila gawan ng paraan. thanks
    Jan 2008
    #4288
    sir boybit, ano model ng OME shocks kinabit mo? did you change all 4? did you also add a steering stabilizer? how much did it cost you? sorry sir kung ang daming tanong......
    Dec 2007
    #4289
    i installed stebel magnum in my strada, ok naman for me. PhP600.00 per pair ko nakuha kaya value for money yung product
    pa dinig ako sir sa linggo nung stebel ah
    Dec 2007
    #4290
    Quote Originally Posted by eslonblue View Post
    sure bro...
    Dec 2007
    #4291
    got my new motolite gold maintenance free battery from the casa. when i inquired kung how much ang difference ng synthetic and mineral oil, the service advisor told me that they have a new circular recommending synthetic oil for 'high-end' crdi motors with turbo intercooler. how true is this?
    for the 5k pms here is the supposed breakdown:
    PhP 4,080 = 8 liters of synthetic oil
    995 = oil filter
    223 = OWS (what is this?)
    63 = Varsol (again what is this?)
    8 = rags
    PhP 5,369 ++ Total
    Need clarification BOSBs....
    Jan 2008
    #4292
    995 = oil filer
    8 = rags
    PhP 5,369 ++ Total
    sir if i remember correctly, the varsol is various solutions, in short mga panglinis kuno ng dumi nila sa sasakyan at makina(or tubig? hehehehe) the OWS, yan ang hindi ko naitatanong, i'll ask tom when i call the service manager, need to ask sme stuff anyway.. as for the memo regarding the use of synth on CRDI engines, last year pa yan sir, mga june o july pa pinaikot daw ng mitsubishi sa lahat ng dealers nila
    Dec 2007
    #4293
    Thanks sir arvin! ambigat pala sa bulsa, then kasama pala dun sa memo na every 5K din ang palit ng synthetic oil sa engine natin instead of every 10K, nasabi din ba sa iyo yun?
    Jan 2008
    #4294
    yupyup, but at least you change filters after 2 change oils!!! doesn't make a lot of sense, but that's how i've been doing it.... yun kasi sabi sa akin ng service manager ng diamond motors....
    mga sir, found this site regarding tires...http://www.offroaders.com/tech/AT-MT-Tires/
    check it out if you have a particular tire in mind and see it's ratings and comments from users.
    Dec 2007
    #4295
    ang mhal nga..
    yung battery sir choice nyo na mag palit?o casa nag palit kasi hndi maintenance free yung kasama?
    #4296
    Sir Patriarch,
    That's what I mean na maintenance wise, better ang 2.5L. hehehe...
    iam3739.com
    Dec 2007
    #4297
    Quote Originally Posted by Arvin Cristi View Post
    huh? i thought every 5K din ang palit ng oil filters? naguguluhan na ako ah
    Jan 2008
    #4298
    sir, yung standard change oil procedure would require you to change oil and filters every 5K kms, pero and sabi nila since i was using the fully synth oil, just change oil every 5K and the filter every 10K, this actually goes against everything i know regarding engine maintenance pero yung ang sabi nila na sabi daw ng mitsubishi.... really weird when some oils brands would make it the other way around, every 5K ang filter and 10K ang oil
    Dec 2007
    #4299
    ang mhal nga..
    ganito yun bro... gusto ko kasi maintenance free battery kasi tamad ako magcheck and hassle magtop-up nung GS... and sanay na ako sa quality nang motolite... kaya when i bought my unit, i demanded na dapat maintenance free ilagay nila na designed for philippine roads (syempre motolite ang nasa isip ko, hehehe)... pumayag naman sila. pero ngayon lang ako nagka-time pumunta ulit kasi out of stock ang motolite sa casa nung 1k pms ko... actually if you want, you can ask your dealer to change your battery to motolite... pauland also changed his battery free of charge sa diamond motors marcos hiway
    Jan 2008
    #4300
    hmmmmmm buti sir nabangit mo yan, pupuntahan ko bukas yung salesman ko din sa Diamond marcos hiway para mangulit na palitan yung battery ko!!!
