Page 216 of 729 FirstFirst ... 116166206212213214215216217218219220226266316 ... LastLast
Results 4,301 to 4,320 of 14580
    Dec 2007
    #4301
    Quote Originally Posted by Arvin Cristi View Post
    hmmmmmm buti sir nabangit mo yan, pupuntahan ko bukas yung salesman ko din sa Diamond marcos hiway para mangulit na palitan yung battery ko!!!
    pasakalyehan mo muna na mukhang may hard starting sa umaga and di na one click, im sure papalitan nila agad yun, hehehe
    Jan 2008
    #4302
    actually sir, setting the battery thing aside, i noticed that if you leave the key at the ignition /start setting after the heater lights have turned off for a few seconds longer than usual, the vehicle does go through a hard start...pero if you start immediately after the heater lights are gone the engine starts good!!!! weird!!!!
    Jun 2007
    #4303
    *sir thepatriarch
    ang mahal naman ng synthetic sa casa, pumapatak 510 petot per liter. tsk!!!yung mga motul, royal purple, mobil, etc. nasa 400++ lang per liter.
    yung filter ba walang discount?? di ba may 30%-off promo ata sila sa parts ngayon??? 15000+++ kms. na yung akin...papa-change oil na ako anytime....inform kita kung makakakuha ako ng mas mura na package.....tanong ako bukas dito sa Mitsu Service sa Union Motors sa Paco.
    Jan 2008
    #4304
    Parang nabasa ko sa manual yan na if you have left the key in the ON position for a longer time at di ka nagSTART, you have to go back to ACC then ON again. Check ko uli manual.
    Jun 2007
    #4305
    * sir Arvin Cristi
    Confirm ko rin yang sinabi mo about the synthetic oil vis-a-vis oil filter change. kasi pareho tayo ng alam, parang baliktad ata yung sinabi ng service manager ng diamond.
    Dec 2007
    #4306
    Quote Originally Posted by moxxxs View Post
    *sir thepatriarch
    thanks tukayo... hanap tayo ng cheaper way to maintain our rides...
    #4307
    That's really weird.
    As per instruction by the chief mechanic here, one should start the engine after the engine check indicator light goes off which is around 10 secs after the heater indicator light disappears. Been doing that eversince, and still no starting problems.
    Atty,
    I checked the GS battery and it seems that it needs some topping up, although the fluid level is not that low, about midway from the plates to the cap. Not bad after using it for 16 mos. I forgot to have it changed to motolite. I'm quite happy with it, nonetheless.
    BTW, the GS brand is also in my '07 everest. It is, most likely, made in thailand, so it's tropicalized as well. Para siguro siyang motolite ng thailand.
    Sana nga lang, magtagal pa.
    Sa mga nagbabalak ng stebel magnum, di na kailangang pakinggan. Maganda ang tunog. Lalo na kung apat. Ano sa tingin mo, ThePatriarch. Dagdagan mo pa yan :evillaugh
    Jan 2008
    #4308
    sir, yung standard change oil procedure would require you to change oil and filters every 5K kms, pero and sabi nila since i was using the fully synth oil, just change oil every 5K and the filter every 10K, this actually goes against everything i know regarding engine maintenance pero yung ang sabi nila na sabi daw ng mitsubishi.... really weird when some oils brands would make it the other way around, every 5K ang filter and 10K ang oil
    Iba iba nga recommendation ng mga SA kahit sa Toyota. Some would say ok lang 10k palit ng fully synth oil, some would insist on 5k. Yesterday, nag 35k PMS ako sa Toyota Innova, tapos inquire ko yung medyo senior SA at mukhang matapat. Sabi nya na napapansin nya sa every 10k na palit ng fully synthetic, medyo maitim na ang oil. In the end, every 5k pa rin recommend nya. Mahal nga lang.
    Bakit di nabanggit ng SA sa Citimotors yung circular na yon?
    Jan 2008
    #4309
    * sir Arvin Cristi
    exactly sir moxxx!! kaya ang ginagawa nalang namin ng mekaniko ko is change oil at 10K and filters at 5K, pero when i was driving 3K a month we did 5K changes for both the oil and filter....
    as per sir thepatriarch, tama si sir tungkol sa price ng mitsu turboXp as compared to the other brands, MAHAL per liter!!!!! am planning on eventually changing to motul when the warranty lapses. i think sir boybit uses otul on his
    Jan 2008
    #4310
    sir boz, regarding the circular, you have to ask them about it before they say anything to you!!! really stupid way of doing business, were trusting them with our vehicles and they're too lazy to say anything about circulars or memos regarding maintenance!!!
    sir drave, i don't wait for teh check engine light to go out.... never have for any of my previous vehicles as well as my dads cars... considering his cars are GMC's and Ford's... the only thing really important with diesel engines kasi is the engine heater, as for teh check engine light, it's supposed to light up anyway if there is something wrong with your engine.... hopefully it'll never light up while the engine is running for the next few years!!!
    Dec 2007
    #4311
    Quote Originally Posted by Drave View Post
    Atty,
    Puede! sige na nga, puntahan ko bukas yung binilhan ko para dagdagan pa ng isang pair, hehehehe
    Jan 2008
    #4312
    i forgot to mention regarding the GS batteries, the brand used to be a really excellent one coming from japan, it was the only real competitor for FB batteries. but when GS decided to start making the batts at thailand things started getting bad.... actually most of the stuff that ended up being made in thailand somehow get messed up one way or the other!!!! my heavy equipments used to be made in japan( no problems!!) but when they started coming from thailand( a whole pile of s_____ started happening!!)
    i know our rides came from thailand, and sad to say they weren't exactly made the way that they could have been if they were made in japan....i.er. uneven doors, loose hinges, loose engine supports, uneven undercoating, purely RHD configuration for the transfer levers and sooo much more.
    but putting all this into perspective, i still love my ride and i wouldn't want to change it for anything else right now.... unless they came out with a 4th gen strada!!!!!
    Dec 2007
    #4313
    +1000 ako dito sir arvin
    Jan 2008
    #4314
    hehehehehe nakaka sama nga lang ng loob at parang naninira ako ng iba, pero hirap talaga kasi kung madaming masama ang experiences eh...
    Sep 2004
    #4315
    I posted this before. I still have the email coming from MMPC regarding synthetic oil. I am sure that some Service advisors are upselling their service to synthetic to gain more revenue for their dealer. Last statement from MMPC is every 10K change oil if using synthetic and 5K change oil filter.
    Remember, although most SA would try to do their best or give their customers best offers/opinions, they are still work for their dealership and not really MMPC. It's best if we get the word from MMPC. As per Diamond Valle Verde, they allow us to bring in parts bought from ElDorado and just pay for their labor.
    I guess that's why more and more people are giving Diamond Valle Verde better feedback on after sales because they are more equiped in handling our rides and better customer satisfaction. Again, this are feedback from people. I'll experience them on my 5K KM PMS.
    Jan 2008
    #4316
    sir av8or5, heads up lang sir regarding their service crew there, they are the reason why i decided to do the servicing of my unit at my own shop, medyo madami sila na o-over look when they are finishing up with their work, loose filters, messy engine(under the filter, hindi pinupunasan yung tumulo na lumang langis) loose hose clamps.... just give your engine a thorough visual check before you take it out... wala na yung dati nilang service manager dun kaya hindi kita mae-endorce para mas maganda ang trato sa sasakyan mo
    Sep 2004
    #4317
    Starting the engine (diesel-powered vehicles)
    1. Insert the ignition key and fasten the seat belt.
    2. Apply the parking brake.
    3. Depress and hold the brake pedal.
    4. Fully depress the clutch pedal (with manual transmission(.
    5. On vehicles with manual transmission, place the gearshift lever in the "N" (Neutral) position. On vehicles with automatic transmission, make sure the selector lever is in the "P" (Park) position.
    6. Turn the ignition key to the "ON" position. The diesel preheat indicator lamp will first illuminate, and then after a short time go out, indicating that preheating is completed.
    7. Operate the accelerator pedal as described below in accordance with the atmospheric temperature and or engine condition and then start the engine.
    • When the atmospheric temperature is moderate or the engine is warm, start the engine without depressing the accelerator pedal
    • When the atmospheric termperature is low and the engine is cold, start the engine while depressing the accelerator pedal
    Note:
    - if the engine is cold, the diesel preheat indicator lamp is on for a longer time.
    -When the engine has not been started within about 5 seconds after the diesel preheat indicator lamp went out return the ignition key to the lock position. Then turn the key to the on position to preheat the engine again.
    -When the engine is warm, the diesel preheat indicator lamp does not ocme on even if the ignition key is placed in the on position. Start the engine by turning the ignition key right to the start position.
    Jan 2008
    #4318
    Attachment 12205
    mga BOSB's here's a pic i took of my ride this afternon at one of my job sites.
    Dec 2007
    #4319
    Attachment 12205
    huwaw... astig talaga ng strada mo bro!
    Dec 2007
    #4320
    Note:
    Sipag talaga ni mr. president!!!
