Starting the engine (diesel-powered vehicles)
1. Insert the ignition key and fasten the seat belt.
2. Apply the parking brake.
3. Depress and hold the brake pedal.
4. Fully depress the clutch pedal (with manual transmission(.
5. On vehicles with manual transmission, place the gearshift lever in the "N" (Neutral) position. On vehicles with automatic transmission, make sure the selector lever is in the "P" (Park) position.
6. Turn the ignition key to the "ON" position.
The diesel preheat indicator lamp will first illuminate, and then after a short time go out, indicating that preheating is completed.
7. Operate the accelerator pedal as described below in accordance with the atmospheric temperature and or engine condition and then start the engine.
- When the atmospheric temperature is moderate or the engine is warm, start the engine without depressing the accelerator pedal
- When the atmospheric termperature is low and the engine is cold, start the engine while depressing the accelerator pedal
Note:
- if the engine is cold, the diesel preheat indicator lamp is on for a longer time.
-When the engine has not been started within about 5 seconds after the diesel preheat indicator lamp went out return the ignition key to the lock position. Then turn the key to the on position to preheat the engine again.
-When the engine is warm, the diesel preheat indicator lamp does not ocme on even if the ignition key is placed in the on position. Start the engine by turning the ignition key right to the start position.
