Sori mga MODS ha pero sagutin ko lang to.
SIR means you address me sir, and you repeat that again on your last post. FieldMaster na lang ha. Otherwise I will address you Kuya Johnart.
o.t. ako diyan sa sir, sa pagkakaalam ko pag mods may sir. parang sa office pag boss may sir.
para hindi ot just bought supplies pang maintenance going 60k. oil filter 1,600 fuel filter 1,800 and 1,100 air filter from motorix. nag stock narin ako in pag dating ng additional vat.
OT pa rin. Oooppss. Noted po, my apology to the MODS for not addressing them Sir here. Point well taken.
Promdiboy: lool like you missed to note your engine oil. What oil are you using? Are you following the 5K or 10K PM Sked. As for me I'm using Delo Sports for 5K PM.
No no no dudes. You dont need to address any of the moderating team as Sirs. Its not a requirement at all. Please.
Yung sa amin ni Sir Promdiboy medyo naging habit ko na kasi sir ng sir si sir Promdiboy e
PK would suffice. (Less typing; kesa pajerokid hehe)
ok na settled na yung mga sirs, wala nang sirs.
FM matagal tagal narin ako gumagamit ng petron all terrain 5w-30 synthetic oil 265 per liter, and every 5k ang change oil ko. napansin ko sa mga binigay na items saakin, MMC fuso trucks na yung brand ng oil filter, pero same part no. and yung fuel filter naman iba na yung box. white box na without the blue stripes puro japanese writing na, dati kamukha ng box ng orig oil filter yung orig fuel filter.
Thanks PD (Short for PromdiBoy), I haven't tried the all terrain 5W-30 as it seems that the 10W-40 viscosity of Delo Sports is still too thin for my engine. Actually I'm eyeing the 20W-50 of Mobil (Synthetic) but my pocket could not afford it. I used to top my engine with 1/2 liter Oil within 5K km. I really would like to switch to all terrain but have to check first if my engine could take it, planning to have compression test in 2 weeks time at Autotechnica (P400/cyclinder). Hope it will yield favorable results allowing me to switch to all terrain. For Filters (Oil, Fuel and air) all are purchased from Eldorado, just hoping they are all genuine.
FM if you switch to 5w-30, handa ka narin magpalit ng valve cover gasket and half moons, pati yung clamped rubber hose from turbo to oil pan. guaranteed mag kakaleaks.
pati pala yung orig na airfilter iba narin, mas maputi na yung plastic na may fins. as in puting puti na plastic. check niyo rin pala yung pag clamp ng intercooler hose above the valve cover, nagrub yung screw ng clamp sa valve cover near the mitsu logo on the valve cover, konti nalang butas na yung valve cover ko.
kakaemission testing ko lang kanina, passed kaya lang ang laki ng tinaas ko compared last year. I was expecting a better score kasi just changed my fuel and oil and air filter. For the past 2 years my score was .38 and .39 respectively ngayon 1.0 na. where do I start to fix this problem? napansin ko nung nirerev niya yung engine ko may konting konting smoke sa simula. dati wala talaga. My ride is 5 years and 10 months old with 61k on the odometer. saan ba ako magsisimula mag check?
You can have your rig's nozzle tips checked. It may just need some cleaning or replacement.
PD: was it for opacity?
nabadtrip ako nung friday, we had the pajero emissions tested somewhere sa v.luna road. opacity lang ang nilagay na value sa test printout, no CO or NOx or HC. oh well. pasado naman, mas mausok pa nga yung crosswind na katabi ko that had an later X-series plate (XPn-nnn), and it's due for a 65T km checkup.
question: pano tanggalin yung front corner bumpers (with headlight washer)?
any pics on how to do it? i need to paint it kasi and hassle imasking yung kotse, mas mabuti yung tanggalin na lang. :D
promdiboy,
sa denso they have 2 nozzle tips, one is orog the other xenzel something yung brand, i got th ereplacement since malaki ang diffrence, spent laess than 4 k, 2 years na, ok pa naman,
nugundam93,
why not just have the paint shop tape the front or let them take it off for painting?
kcboy: sinisipag kasi ako eh. hehehe. kung kelan umuulan. anyway, ganun na nga lang siguro, dalhin ko sa paint shop near sa amin if i'm not satisfied with the repair dun sa spraygun namin.
Si chieffy nagbaklas yung sakin. Pero madali lang alisin yun front corner. It will come out as an assembly (kasama yung metal reinforcements).
Baklasin mo na lang sa table after you take it off the vehicle.
*bump from the dead*
pajero peeps, ano brake pads gamit niyo? if not OEM, then which brand? where niyo nabili? how much?
