Page 47 of 330 FirstFirst ... 374344454647484950515797147 ... LastLast
Results 921 to 940 of 6591
    #921
    Quote Originally Posted by nugundam93
    pajerokid, saan ba yung transfercase support na yun? :D
    sa driver's side pare, look for the transfercase (its part of the tranny). Tapos may parang bushing doon. That's it.
    Better yet, go to Eldorado Cubao, buy the part and have it installed for P150
    Feb 2006
    #922
    pajerokid,
    san ba ang el dorado cubao? megamall lang iyong alam ko na el dorado e. ano iyong nearest landmark? pakituro naman how to get there coming from ateneo-katipunan-aurora route. maraming salamat.
    #923
    Its along aurora boulevard cor. 16th (I think) avenue. Mura na oem parts, may freelance mechanics pa.
    Feb 2006
    #924
    Quote Originally Posted by pajerokid
    flickserve, actually black smoke is common to most japanese diesel engines when subjected to hard accelleration. Key here is learing to drive smoothly. With mine, i rarely go upwards of 2500rpm. True mabagal, but walang smoke and fuel efficient pa hehe.
    Also, try changing your Air filter. a clogged filter means less oxygen for combustion.
    What is the cycle for the change in the air filter element?
    #925
    just got a 2nd hand 4M40 two weeks ago and enjoying it. just curious how the vehicle monitors the tire pressure and temperature. checked it out and looks accurate naman. tnx...
    May 2005
    #926
    Mga pips may alam ba kyo mabibilsn ng parts 6G72? Sira daw yong injector plug. Thanks
    #927
    el dorado o motorix sa banawe meron malamang yan.
    #928
    ispufi: hmmm, ako medo di ako tiwala sa tpms, iba kasi reading niya compared to the tire gauge na mechanical. then again, dipende rin kasi minsan it actually reads ok.
    atty: take aurora from katipunan. starting from the stoplight with the mcdo on your right, wait for the next stoplight and turn left. nasa opposite side yung el dorado, so u-turn ka after you turn left (di pwede u-turn kasi dun). :D
    larshell: aside from motorix and el dorado, try sp international na rin sa banawe.
    #929
    Quote Originally Posted by flickserve
    air fliter element change is every 12months or 25,000km based sa haynes manual
    #930
    Quote Originally Posted by ispufi
    Uhm, does your 4M40 come with a Pajero? If it does, congrats on your V46!!!
    #931
    pajero kid, surprisingly, it did come with a pajero
    i'm not too much into cars and this forum is truly a learning experience for me. had to read from the start of the thread and i'm not even halfway. a lot of the terms you use here are totally new to me and hopefully i can catch up ..tnx..
    #932
    ispufi, pajerokid: natawa ako sa hiritan niyo ah. hehehehe!
    May 2005
    #933
    Thanks sa reply nyo mga pips. Baka may Tel.# kayo ng Motorix and SP International.
    Aug 2003
    #934
    guys with gen2.5, do you know where the engine number is located? need to stencil. checked the manual, but it seems it is not where it should be. thanks.
    Dec 2002
    #935
    Quote Originally Posted by ek2jayvee
    You will need to remove the intercooler then you can see the engine number its a bit below the glow plugs
    #936
    Just stencil the headlamp or taillamp. Baka kung ano pa masira kapag kinalas ng stencil boy 'yung intercooler.
    That's what I do.
    Jun 2004
    #937
    Quote Originally Posted by larshell
    paj4x4, Thanks sa tel. no. ng Motorcraft i will call them bukas. I notice yong Gen1 pajero mo sa sig. mo naka ralliart web design sya, hindi ba labas ang tires sa front at rear?Sino nga pala ang suki mong mekaniko sa Motorcraft?
    May nakagamit naba sainyo ng injector cleaner? Ok ba? What brand? Where can get it?
    It lips out slightly in my Gen 1. On the Gen 2.5 sakto lang sya. 16x8" with negative offset kasi ang ralliarts na web design.
    #938
    larshell: MMC Motorix - 7121071
    #939
    No probs bossing, we're always here to help! By the way, i'm glad you're doing a backread, as opposed to some posters who just type away.... ang daming stock knowledge diyan and i hope the stuff comes in useful.
    Anyways, 4M40 is the default engine of the Gen2.5 Pajero (blister fender; local). Yung model code po is V46. Basta 4M40-engined ang pajero v46 po iyon, kahit na plastic fender (Gen2). Just a bit of trivia
    Jul 2004
    #940
    Quote Originally Posted by OTEP
    That's what I do.
    DOC OTEP: Is this for real?
