tnx testy ad sir PB sa reply.
testy, sa injection pump and injector banda ang difference natin, dapat may electronics na yung sa inyo. hanapin ko yung article na nabasa ko about specs ng inyo,
eto galing wikepedia 4m40
4M40
* Engine type — Inline 4 cylinder SOHC
* Displacement — 2835 cc
* Bore — 95 mm
* Stroke — 100 mm
* Fuel type — Diesel
Intercooled turbo
* Fuel system — Distributor type injection pump
* Compression ratio — 21:1
* Power — 92 kW (125 PS) at 4000 rpm
* Torque — 294 N·m (217 lb·ft) at 2000 rpm
Intercooled turbo
* Fuel system — Electronic control type distribution type jet pump
* Power — 103 kW (140 PS) at 4000 rpm
* Torque — 314 N·m (232 lb·ft) at 2000 rpm
yung 2nd ang local yung 3rd ang jdm.
Bro PB,
maraming salamat sa quick reply RE: LED lights. I checked page 260, the one you told me, lahat ba ng led lighys mo, galing pa abroad [states]?
Hindi ba available locally ito sir?
maraming salamat and more [horse] power...
to further lessen the road noise sa cabin, I placed a rubber mat na nabibili lang sa suking canvass stores, this will be sandwiched between the floor and the carpet. im just not sure kung effective.more material to block noise from coming in. mga 3/8 ang kapal ng mat.
rlx555, meron din leds available locally.![]()
Foggy Dashboard??
Hi, nagpalit ako ng several peanut bulbs sa dash board panel & all burning well, but the problem is since I boxed up the panels, every morning condensation is taking place on the plastic cover of the panel which blurring the face displays of the instruments. Wala naman akong natatandaan na tinangal na mga rubber or silicon sealant. During long run dahan dahan din na nawawala. Have you experienced this? & what corrective action ang ginawa ninyo. for sure this is cause by cooler air seeping in.
Thanks-RTS
rts, nangyari saakin dati yan. yung ducts ng aircon yan sa likod ng gauges, im guessing nasa upper right corner siya, either yung foams sa connection ng ducts napulbos na or natulak ng wires yung ducts nung binalik mo gauge kaya nabuka yung duct. kung saan banda yung moisture doon yung leak. i used aerotape(yung ginagamit sa aircon pang insulate) sa mga exposed ducts. and matagal ko na di nakita uli. remove the gauge and turn on your aircon to check.
I've finally changed my headlight bulbs to Philips Xtreme Power and visibility improved a lot. However, I still find night driving better with my CRV (also on XPs). Sa headlight reflectors na kaya to?![]()
good afternoon pajero owners.. i have question regarding automatic transmission. i have my gen 2 pajero changed its oil and filter yesterday, valve cover gasket was changed, fuel and air filter was replaced with a new one too. but after all the work was done and when im about to start the car, the "a/t" on the dashboard keeps on blinking until today. i just used the car a while ago and it seems everything is ok.
now my question is, what causes the "a/t" to blink? and does replacing the filters and oil has something to do with it?
btw, my engine was calibrated last saturday. they replaced all the nozzle tips with a brand new one and injection pump was calibrated as well. and automatic transmission fluid was changed last month.
need your inputs guys. any help would be much appreciated. tia!
btw, its a 2.8L pajero from subic (3 door) and the engine is 4m40.
mr. lucky023, try replacing your ATF first. check your atf kung pinkish pa ang kulay and hindi amoy sunog.![]()
Anyone here with a DIYed/aftermarket grounding kit? Could you post pictures where you exactly positioned the connectors (Just making sure not to mess up my system)? I'm planning to DIY one for my '99 FM. Heard it really improves electrical flow on aged vehicles.
Also, if my ride has grounding kit already, would I still need the big 3 upgrade?
reepicheep, page 169 may pics ako ng grounding kit ko, ang di ko lang nakunan diyan yung pinakamahaba pumunta sa auto tranny.
ang kulang nalang sa big 3 is alternator to battery, I used gauge 4 wire with fuse 125amps agu fuse near the battery.
yung dalawa kasama na sa grounding kit, negative to chassis and negative to engine.
Thank you very much sir. Also, could you sir post a picture of your gauge 4 wire and fuse? Where can i buy those?
My ride sir is bone stock. And this is my very very first car. Kaya i'm not sure pa to stick the wires. Heck, I don't even know what the alternator and turbo shielding looks like until i saw your picsCan i just pattern my with yours?
So basically. I need a kit with eight 8 gauge wires, better battery clamps to accommodate all the cables and a guage-4 cable.
From (-) terminal:
2 should go to: body (one to the stock grounding -- where is this?; one near to the fusebox -- is this the place where strut bars are usually bolted on? )
1 to the tranny
2 to the front bumper (grounding points of horn and headlights -- i only see one in the pictures, where should i bolt the other one to?)
1 to engine (valve cover)
From engine:
1 to body (can i just bolt this on the valve cover along with the cable coming from the battery?)
From alternator bracket:
1 to body (can i just bolt this to the same place where the engine-to-body cable is mounted?)
Thanks again for helping a newbie.
mga sir.. tanong lang po... pano malalaman kung busted na ang turbo ng 4d56? just curious.. dumaan kasi ako sa turbo shop.. dami nagpapagawa.. napaisip lang ako... 11 yrs na yung akin... ayos pa kaya? hehehe
finally, had my glow plugs replaced with KHT PM-165. It works nga..and my antenna replaced also...yipee!!
question, meron bang right side mirror (yung nilalagay sa may hood) for our FM? meron nabibili sa mga malls pero baka lang meron talaga JDM na para talaga sa FM nten. let me know.
thanks
reepicheep, heres my batt to alt positive connection,
yung wire na pataas ang papunta sa batt. wrapped in plastic moulding para oem look.
heto naman yung fuse, yung isa pumunta sa amps, then yung isa sa alt.
Nice sir. Thanks a lot. Btw, are your wires branded? Where did you buy them including the fuse holder? How much?![]()
reep, its scoche efx brand. 80 per feet dito probinsya, matbe alot cheaper sa manila. mga 15 feet siguro inabot saakin, yung fuse holder is 800 yata. efx din
