Page 228 of 330 FirstFirst ... 128178218224225226227228229230231232238278328 ... LastLast
Results 4,541 to 4,560 of 6591
    #4541
    Quote Originally Posted by janrye26 View Post
    what do you call this black plastic sa plate number banda?
    plate stage ata ang tawag diyan.
    #4542
    sir RLX..
    had my steering wheel wrapped at leather interia.. for 1500 pesos
    pag faded lang leather mo.. but not yet cracked pwede din nila re-dye.. which was done on my unit..
    http://www.lederinteria.com/ look for jenny
    very accomodating.. although.. di yata kaya antayin.. kelangan talaga iwan sasakyan.. sa timog lang...
    Mar 2003
    #4543
    peterson, yes mabilis lang din mawala yung ilaw saakin, mga 2 seconds lang, pag hindi mo na naririnig yung TIK sound after mawala yung ilaw. probable na relay na problem, I here the TIK sound 3 seconds after mawala yung ilaw ng glowplug tsaka ko start. and mga 2 minutes after cold engine start naririnig ko uli yung GP relay TIK. pag checkng GP continuity lang using mutimeter.
    junerski, yes pwede lagyan ng switch power antenna, look for the antenna wire ng HU mo tap kalang ng switch para di na siya umangat everytime on mo HU. dati binalak ko to, but instead got an Alpine HU, compared to pioneer ang alpine tumataas lang sa tuner mode.
    sa mga may ayaw umagat na na antenna but gumagana yung motor, si taz13 naka discover na pwede ang starex antenna and its dirt cheap at 350 pesos.
    Sa glowplugs experience ko sa oem di rin tumatagal, I used 2 sets aside from my stock nung bnew, tumagal siya ng 2 years, yung gamit ko ngayon na HTK replacement mas tumagal.
    Jun 2009
    #4544
    *RLX555
    Re- Glow Plugs,I have change my glow plugs for the 2nd time in the span of less than a month. The electrician na tumingin ngayon went thoroughly to the system. Whether it is the high end brand or opposite glow plugs kung may problema ang system mo sisirain pa rin iyan. I just bought the cheaper brand (P180/ea.)USA kuno. This is my 2nd day after repair & I tried starting this morning w/ still a cup of coffee on the other hand, presto one click , of course w/ the help of the chocker.Let your favorite electrician check it extensively, dahil sayang lang kung hindi matutumbok ang root cause.
    RTS
    #4545
    Quote Originally Posted by peterson View Post
    Bro Junerski,
    puwede imodify yan. yung sa antenna ko, ganon ang pinagawa ko. hindi na kasi orig ang pinakabit ko. bumili na lang ako ng replacement antenna sa isang car accessories dealer dito malapit sa amin. pinakabit ko na rin dito sa kanila. sinabi ko sa electrician na gusto ko na sa mast switch niya ikabit yung remote wire ng antenna para pag gusto ko lang itaas ang antenna, doon ko lang sa mast switch icontrol. additional labor cost P150 ang singil niya sa akin.
    Bro Promdiboy,
    thanks for the advice. susubukan ko tiktikan yung yung tik sound ng glowplug relay.
    ok peterson, salamat! nakakainis kasi, kahit naka cd/aux tumataas pa rin, dagdag pa yun sa wear and tear ng antenna, eh lagi naman kami naka cd
    #4546
    ilang inches max pwede ilagay sa front speaker mountings ng paj na 3 door? pati sa likod (rear passenger sidings)? balak ko kasi mag-upgrade.
    #4547
    Quote Originally Posted by junerski View Post
    guys,
    pwede ba or meron na nakagawa sa inyo ng mod na may "on/off" switch ang power antenna natin, yung switch na gagamitin yung mast switch?
    nagpalit lang kasi friend ko ng power antenna assembly niya eh ayaw na niya lagi tumataas yun kahit naka cd/aux mode yung HU.... para gagamitin lang kapag naka tuner. pioneer kasi HU niya kaya kahit naka cd/aux nakataas pa rin antenna. (or may mali lang na connection?!? i heard ganun talaga raw mga pioneer?!?)
    btw, out of curiosity lang tumawag kami sa casa nasa 13k plus ang power antenna assembly (motor with rod etc) kaya dun na lang kami sa replacement 1200k pati labor na.hehe thanks
    ginawa ko eto. series mo dapat ang switch mo sa hot wire (positive line) ng power antenna mo. kasi pag sa negative side, pwede mo lang siya control, say pwede na i-timing mo kung gaano kataas ang kelangan mo. pero pag gusto mo na siya ibaba, kelanangan paangatin mo ulit ng buo ang antenna mast mo, then tsaka mo ibaba.
    #4548
    I tried a simple DIY sa upuan ng driver side, pag lubog na outer part ng seat.
    pinasukan ko lang ng maraming bulak,
    pag upo mo mas comfy na kasi naka angat na both sides. it feel s kinda weird pag bumababa ka, di na pwede yung slide method, bubuhatin mo na pwet mo kasi naka angat na,
    took the carpet out for washing
    hanggang matuyo carpet ko, this is what my daily driver pajero looks like, mga pasahero ko, sa sahig muna uupo.
    ok to ah, gano katagal ka inabot tanggalin 'yung carpet? parang gusto ko rin kalasin 'yung akin
    Nov 2006
    #4549
    Quote Originally Posted by RTS View Post
    *RLX555
    RTS
    ano pa ba pwede na problem pag nasisira yung heater plugs? sang shop kayo usually nagpapagawa?
    regarding power antenna, any power antenna ba will do? sang shop din kayo nagpapagawa?
    salamat po...
    Nov 2006
    #4550
    gamit ko na heater plugs ngayun is federal-mogul (165/each). after one day, busted lahat...pinapalitan ko yesterday sa auto supply. ok pa naman ngayun. ewan ko lang kung tatagal. Howto check kung electronics ng heater plug ang sira?
    and ano anong brand ng heater plugs gamit nyo ngayun na okay naman?
    napansin ko mabilis mawala yung ilaw ng glow plug ko sa panel after mag switch on eh. ganon ba talaga?
    Jun 2009
    #4551
    *Peterson
    The findings are that the cut off or timer that serves the glow plugs are constantly on, so they fixed the timing, the relay sa starter is defective due to prolong starting, they change it, as Im saying also the sensor nadamay so they change it plus new glow plugs( cheaper version), at present still under observation so far okey naman for 2 days early morning start. According to the elect. na hindi basta basta ma ba busted sabay sabay ang glow plugs if the system is workin.
    RTS
    #4552
    gents, tanong lang ako meron na ba sa inyo na nagpapalit ng torsion bar bushing ng pajero. 4x4 kasi sa akin at kumakalampag na yung bushing na nakahawak sa differential sa harap? magkano kaya ang piyesa? assembly ba ito o puede ba yung bushing lang palitan and magkano kaya?thanks for any information you can provide
    #4553
    gamit ko hkt pm-165 na glow plugs. just last 2 months lang ako nagpalit ng glow plugs kasi 2 oem glow plugs ko busted na. also available sa market is the hkt cp-05 glow plugs. mas mahal eto sa pm-165 pero hindi ko maisip kung ano ang difference niyan sa pm-165.
    kung titignan kasi maigi sa internet, ang cp-05 ang direct na replacement sa oem glow plugs ng 4m40 engine
    Nov 2006
    #4554
    Quote Originally Posted by AC View Post
    sir ar24458
    may nagturo po dito before...
    na pwede gamitin antenna ng starex...
    may stock sa apic parts.. nagbebenta po ng korean parts for 350 pesos
    telephone number 7129108
    wag niyo nalang sabihin sa pajero niyo gagamitin... para di nila taasan price.. 2t po kasi pag original pang pajero..
    then pakabit niyo nalang sa banawe.. around 300php pataas..
    btw apic is in banawe...
    mas mura sa hybrid and seiring kayalang wala sila stock eh.. hehe
    320 and 300 yata dun.. hope this helps
    yung tip lang difference from pajero after install.. but looks fine naman..
    boss,
    meaning to say talagang palit power antenna lng and retain ang motor?
    san sa banawe magaling mag-install ng ganito? yung alam na nila talaga....
    thanks
    Nov 2006
    #4555
    *Peterson
    RTS
    sang shop ka nagpapagawa boss?
    Mar 2003
    #4556
    pr462, Hindi ako sure, but sa pagkakaaalam ko bro walang bushing ang torsion bar, may plastic part na nakapaikot sa other end, but hindi siya nasisira. inaayos lang pagkaipit.
    ddrifte, mga 2 hours job kalasin carpet.
    Aug 2007
    #4557
    saan po makabili ng ganito?
    May 2008
    #4558
    Quote Originally Posted by igixxi View Post
    galing ako auto centro sa cubao kanina.. yung bosh na all weather na natungan ko is worth 700 pesos
    yung narva all weather 100/90 is 680
    yung osram all weather 100/80 is 450/pc
    I'm having a dilemma now. Should I go for high wattage bulbs (which means I will also upgrade my wiring harness) or go stock (Philips Xtreme Power/Osram Nightbreaker; I've tried the XP, waaaay brighter than regular 60/55w halogens)?
    Philips XP's are tagged around 1800 a pair.
    NB's around 1500.
    #4559
    ang mahal naman ng quote mo sa nb? i got mine last year, 600 per bulb. so 1.2k yun for both headlamps. mahal yan bro...
    get nb, magandang maganda...
    Jun 2009
    #4560
    Quote Originally Posted by ar24458 View Post
    Dito sa proj. 8, road 20 toward congressional, there is a small shop named " Celing" auto electrical shop, small one not a classy shop , suki namin matagal na ito, one thing you will like this Mang Celig is his dedication to do job w/ good result.
    RTS
