Page 221 of 330 FirstFirst ... 121171211217218219220221222223224225231271321 ... LastLast
Results 4,401 to 4,420 of 6591
    #4401
    Quote Originally Posted by freeloader View Post
    What's the cheapest solution for leaked sunroof?
    i heard some guys dealt with their leaking sunroof by using silicon gasket. pretty cheap remedy but your sunroof will be closed for good.
    #4402
    try to check first the drain outlets of the sunroof. many times barado lang yang butas sa drain.
    #4403
    Quote Originally Posted by Mitsu_Addict View Post
    Kapapalit ko pala kanina ng brake pads, bendix lang nkuha namin pero ngtaka ako kung tama lang ba ang presyo... like around 2k yung front set tapos mga 1k yung rear... Hassle kasi coz pudpod na masyado yung pads and it's making weird sounds na baka masira pa ang rotor so couldn't shop around for oems anymore.
    I remember yung nag papalit ako ng bendix break a couple of months ago ay wala pang 1K yung bili ko sa apat na gulong.
    Jun 2009
    #4404
    Treat for my PJRO
    After several weeks of busy w/ my strada, now time to give my PJRO a treat. One of the shop in Banawe cleaned my headlight & aligned , so no need to go for HID. I installed back up sensor with the display in the rear view mirror, bagay na bagay, hindi ko na ma ba bump iyung plastic drum sa garahe.Drilling a hole on my rear bumper is a pain on the neck of the shop dahil solid na stainless material, they used 4 circular saw before they can bore the two holes for the sensor.
    What remain for fixing is the stock fog lights, they can't recommend any bulb to improve the light intensity, gusto nila palitan na lang iyung old stock fog light in w/c I disagree. Any suggestion mga kaibigan sa FM mdl 2003 fog light.
    Thanks- RTS
    May 2008
    #4405
    Quote Originally Posted by RTS View Post
    Treat for my PJRO
    Magkano bro total gastos? Tutunog na ba yung sensor kapag malapit nang tumama yung spare tire cover? Yun kasi yung madalas kong naibubunggo eh.
    #4406
    The only problem sa back up sensor ay madali iton masira. Pag binutas no yung bumper mo at wala kang makitang kapareho ng size na sensor na gamit mo ay problema na. Gamit ko lang ay yung stick on sensor para pag defective na ay pwede tangalin na walang nasisira sa sasakyan mo.
    Aug 2009
    #4407
    Wow ang laki naman ng difference... Yung gamit ko ngayon Bendix Metal King for the fronts... I forgot the model yung sa rear.
    * Testy... ok po... will look into how i could add Highbeams. Kanina ngcheck ako ng sang delica with projectors parang maliit masyado yung unit eh... mukhang di bagay sa laki ng headlight housing ng pjero natin... Hahay... settle muna ako sa Halogens till magkabudget.
    * igixxi - i use mobil delvac 1 as preference lang... minsan kasi i go over 5k for oil changes since sobrang sikip ng schedule ko for work...hirap talaga callcenter...So it's sort of gift ko nalang sa pjero ko for the times na di ko sya napagtutuunan ng pansin. Baka magtampo Kung meron lang sana shop na open sa gabi para di hassle hahaha...
    #4408
    hehe sir promdi.. di naman expensive kabit namin.. dami diyan nakikita ko.. 20s 22s 24s.. kakatulo laway.. hehe
    at sir mitsuaddict..
    last time i changed my pads... it cost me 800 front and 800 rear.. bendix..
    sir igi sa gen2 ko regular oil lang... delo.. hehe
    mga sir.. may nakikipagtrade po sa akin.. sa benchtype 3rd row seats ng dad's gen2.5 ko trade to his front facing gen2... what should i look out for.. may problema po ba mga front facing seats? may nasisira or ano?
    mukha naman madali lang tangalin yung seats mismo.. but paano kaya matangal yung seatbelts(ng 3rd row)? hehe anyone who has tried?
    #4409
    as far as i can see, 4 na turnilyo lang ang 3rd row seats, 2 per seat. madali lang alisin ang mga upuan. yun seat belts naman, tingin ko kelangan baklasin ang side panels para mabaklas din ang seat belts. for me, mas gusto ang front facing 3rd row. kasi yun sideways, parang nagmukhang auv na malaki ang pajero, yun lang mas malaki ang space na meron ka
    Jun 2009
    #4410
    * Back up sensor*
    Unit including the installation is Php 3K, indicator at zero meroon ka pang 1 foot allowance , & the spare tire cover few inches away before it touch.
    I should have installed it way way back when it appears in the market para wala akong mga "tatsa" sa likod ng bumper, tire cover etc. Now im looking how to improve the intensity of my stock fog light, if no recourse, look out there model that will suit the original resting area, kasiI noticed in my strada I dont need the headlight & fog light is enought to illuminate the path.
    RTS
    Jun 2009
    #4411
    Anybody out there!!
    Lately I'm experiencing strange noise when I turn my steering wheel, hindi naman permanente iyung ingay, kaya lang there are instances if I turn slightly to the left, parang nag metal to metal noise tapos mawawala. I checked the power steering oil okey naman ang level, but down the motor itself a slight streak of oil is noticeable . any similar experience ? & what corrective action you have applied.
    Thanks. RTS
    Apr 2008
    #4412
    Quote Originally Posted by badongski View Post
    ito na yun pics. medyo natagalan
    I told you sir badongski, maganda nga sa fieldmaster! My ride is black, kaya maganda chrome... san nyo nabili and how much? thanks for the picture!
    #4413
    Anybody out there!!
    Thanks. RTS
    check mo ang steering gearbox. you said may nakikita kang streak of oil, it is possible may leak ang steering gearbox mo. solution dyan, o-ring replacement. replace all possible worn out o-rings. kami kasi before, nagpalit na ng lahat ng o-ring pero may nakita pa rin kami leak. last solution mo will be, you'll end up buying a repair kit consisting of o-rings and oil seals para sa gearbox mo.
    #4414
    measure mo ang diameter ng projector ng delica. yung sa akin kasi, 2.5" ang diameter niya. i was opting for a 3" projectors pero mas madugo ang price nun, 20k daw, projector palang daw yun.
    Aug 2007
    #4415
    VERY NICE SIR...........
    #4416
    Good day sa inyo fellow pajero owners, just new here, pero very much excited to know more about pajeros, seek lang ako ng assistance nyo po, meron akong fieldmaster gdi v6 engine, ayaw na tumuloy yun andar ng makina, para daw naghahalo yun gas at langis, may white smoke sya sa likod, can anyone help me find a tried expert fieldmaster mechanic...
    taga las pinas lang po ako
    Sep 2008
    #4417
    Quote Originally Posted by ebr View Post
    try searching for Joseph Autotubo in your search bar, If I remember correctly his shop is in multinational village.
    good luck!
    #4418
    Gotcha, thank you for the quick assistance, just texted Sir Joseph kaso he does not do home service daw, since d ko mapatakbo yun FM ko d ko madala ang FM ko to his shop/place... Sana maawa sa kin si sir Joseph...
    Any other tried and tested good FM mechanics you personally had dealt with?
    Aug 2009
    #4419
    mga sir need your expertise for gen 2 pajero manual.... medyo normal po ba yung tranny ko? kasi po sinubukan ko po shift yung 4x4 stick, up to the lowest gear which is 4L parang hirap sya tumakbo then matigas lumiko? medyo tumatakbo lng sya pag straight yung dadaanan, my problema po ba 4x4 tranny ko? have you experience this kind of situation? ..... tnx po
    #4420
    bro, wag kang gagamit ng 4L pag nasa patag ka. pwede pa ang 4H sa patag, wag lang ang 4L
