downshifter, to check intercooler kailangan mo irekta yung motor sa battery kung gagana intercooler motor (sa pic yung coconect sa no. 2). or ishort mo yung air temperature socket ( sa pic no 1), you can also use a multi meter to check the motor and sensor. if you want a simpler way idle mo lang kotse mo mga 15 minutes dapat marinig mo yung intercooler motor umandar, wag mo on aircon para hindi umandar aux fan, medyo similar sila ng sound, pag narinig mo motor pakiramdaman mo kung may humihigop sa intercooler.
higher resolution pic click link and zoom
http://tsikot.yehey.com/gallery/data...ooler_scan.jpg
pag ok motor and ayaw parin umandar try cleaning your air tempreture sensor (sa pic no. 18). nasa pic yung exploded view.
imho lang bro based sa pakiramdam ko. minimal ang effect ng intercooler sa bigat, wag lang mabutas. mabigat talaga pakiramdam dalhin pajero lalo na pag galing ka sa gas or mga crdi na diesel. airfilter ang una mong icheck baka clogged na, replace every 10k pag oem pag gamit replacement every change oil (dapat 20k palit oem pero feeling ko kahit linisin di na siya kasing gaan ng bagong airfilter). increasing your tire pressure to 38psi also helps. change oil din, in theory gamit ka thinner oil iwasan mo 50 weight oils , magiging mas sluggish pa lalo. 40 weight is better compromise between protection and power. Im currently using 15w- 40 na semi synthetic hindi ko rin masabi na bumilis nga, kung nagawa mo na lahat to and mabagal parin baka iba na problem.
