Page 103 of 250 FirstFirst ... 3539399100101102103104105106107113153203 ... LastLast
Results 2,041 to 2,060 of 5000
    Jun 2007
    #2041
    ^Huling Huli mo sir doy! batang bata!
    Jun 2009
    #2042
    Quote Originally Posted by doy View Post
    Cleaning and recharging is every 70,000 kilometers under regular city driving. Kung may halong offroad, around 60,000 kilometers siguro. So it's economical for maintenance and for fuel consumption (less restrictive compared to the stock paper filter with same mileage).
    sir Doy,
    Seems you are using KNN filter for a quiet sometime , may I ask kung pinatong mo yung filter direct sa housing without seating sa filter pad like the OEM na filter then fastened pa sa filter pad . Parang yung pad is acting like a secondary filter din kasi when I cut the pad puno rin soot deposit.
    Thanks-RTS
    Feb 2006
    #2043
    triton fg hard bedcover(hard tanneu) now available
    #2044
    anyone had experience na pag inikot yun manibela may maririnig na parang whistling sound? sa initial andar ng truck wala pero pag nakatagal na bigla na lang lalabas yun whistling sound.
    Aug 2003
    #2045
    Quote Originally Posted by sphinx1228 View Post
    Yes. At 1K mileage, pinalitan ng casa yung steering assembly. Pero pagdating ko sa 12k, bumalik. Meron silang nilubricate, pero bumalik pa rin. Pagmedyo umuulan, nawawala, pero paghindi, lumalabas ang problema. Hindi ko pa binalik sa casa, busy kasi.
    PLUS yung ingay pag apak sa clutch, bumabalik ang problema. PLUS yung left rear suspension, maingay pa rin, maski nilagyan na ng silencer, at ilang beses na nila nalubricate.
    Oct 2004
    #2046
    Quote Originally Posted by RTS View Post
    sir Doy,
    Thanks-RTS
    Yes, sir. Pinatong ko lang yung K&N filter in the same manner as the OEM filter, with the "front" mark facing top and front as per instruction manual. Aftermarket wet-type filters, like K&N, use the charging oil to trap and hold the dust and other pollutants. That's why it can do its function even if it's thinner than the OEM. The thin design is also the reason why more clean air can pass through making it efficient.
    #2047
    Quote Originally Posted by altec View Post
    salamat sa input niyo sir.... lumabas yun tunog even before 1k so pag punta ko sa casa sinabi ko may tunog and check nila.... mukhang wala sila ginawa at may tunog pa rin... San casa kayo sir nag pacheck at sabi kailangan palitan yun steering assembly para dun ko din dalhin. At least sa inyo after 11k bumalik... sa akin kasi in less than 2 hours after the 1k bumalik agad.
    Actually, pwedeng isang tipid sachet of any liquid dishwashing soap ang gamitin sa cleaning. Ibabad lang (totally submerged) for 1 hour, rinse with slow running water tapos air dry away from sunlight. Pero yung recharger kailangan yung K&N talaga. Di pwede penetrating oil as substitute.
    Salamat! Will do that.
    Pabili na lang ako siguro ng recharger kit once andito na.
    Aug 2003
    #2049
    Sori, pareng sphinx, unless taga cebu ka rin, dito ko sa cebu casa pinaayos. Ang suggestion ko, ipatingin mo kung maiinit. Di ba ulan ng ulan sa maynila? Maski sa dito, pangit din ang panahon. Ngayon nga eh, nawala yung ingay sa steering column at sa suspension. Yung clutch lang ang maingay. Waiting for the next days of sun para lumabas ang problema...
    Feb 2007
    #2050
    Quote Originally Posted by gpb77 View Post
    O, Ayan mga taga paranaque. Mga Strada Owners members and non members nang Strada Club sa Paranaque area, baka pwede tayo kape kape. Munting EB. Sharing infos.
    Paranaque area din ako bros, malapit dampa. Got my White Strada GLX MT on June. Join ako for mini EB. Interested to join TSCP soon! - mark
    Feb 2007
    #2051
    x2.
    Kailangan talaga palitan ng malakas. Fiamm SFNL, Fiamm Gran Turismo, Stebel GP3 or GP2, Bosch Europa, Roots Megasonic, dalawang Hella Supertones, dalawang Mitsuba, dalawang Stebel Magnum, dalawang Seger horns, or isang tunay na train horn.
    boss, changing horns won't void our warranty ba?
    salamat!
    Dec 2008
    #2052
    hi I'm planning to get the 2.5 gls sport V strada is it really worth buying and ok ba after sales sa citimotors alabang ito kasi pinaka malapit sakin im from paranaque ive talked to one of the SA Vanessa name accomodating naman kaso siyempre baka pag nag ka
    problema in the future hindi nako ganu asikasuhin may mga recommended SA ba kayo at dealer na banda south thanks in advance sa mag rereply
    Oct 2004
    #2053
    Quote Originally Posted by MarkYmarK View Post
    salamat!
    Normally, it would void the electrical aspect. Pero depende sa install kung tama ang wire thickness, inline fuse rating, mounting, malinis ang tapping from oem horn wire, at sa casa. Warranty claim involving the electrical of the vehicle may be void if the SA claims that the aftermarket horn is the cause. So depende na sa convincing powers ng customer.
    Feb 2007
    #2054
    Quote Originally Posted by lordkups View Post
    bro, got my glx MT in citimotors alabang. you could try my SA - Em. Tell him you were refered by Mark Ortiz.
    Feb 2007
    #2055
    Feb 2007
    #2056
    that's my worry bro, ayaw ko mag-risk and ended up voiding my electrical warranty.. i'll wait for 3yrs nalang muna before ako upgrade ng horns and other accessories. maraming salamat sa reply Doy! cheers! - mark
    Oct 2004
    #2057
    Look at it this way, sir. Would you rather save up on the warranty and compromise the safety of your family/passengers by using just the OEM single tone mini disc horn for 3 years?
    It's the same size as the alarm horn of the hilux/fortuner and main horn of some scooters.
    #2058
    exaggerated man yata boss by not just upgrading the oem horns compromise na safety. i doubt it, it depends how you drive safely.
    Dec 2008
    #2059
    ok ba after sales nila dito sa citimotors alabang, tsong puwede pa pm alin mga freebies na binigay sayo para malaman ko kung good deal ba inooffer sakin
    Aug 2003
    #2060
    I have initially installed a pair of hella supertones last year. Then added another pair of supertones this month. So far walang problema. I added extra tweeter in that space at the front doors, plus an under seat sub to improve the sounds last year also. So far walang problema. And if there is, I run to the accessory store to fix it (so far wala), AND if talagang magkaproblema, I will tell the store to remove them, AND then send it back to the casa for any possible warranty. Fyi, I didn't remove the OEM horn.
2010 Mitsubishi Strada [continued 2]
