Results 2,041 to 2,050 of 5002
August 4th, 2011 05:33 PM #2041
August 4th, 2011 05:41 PM #2042
Actually, pwedeng isang tipid sachet of any liquid dishwashing soap ang gamitin sa cleaning. Ibabad lang (totally submerged) for 1 hour, rinse with slow running water tapos air dry away from sunlight. Pero yung recharger kailangan yung K&N talaga. Di pwede penetrating oil as substitute.
August 4th, 2011 06:23 PM #2044
sir Doy,
Seems you are using KNN filter for a quiet sometime , may I ask kung pinatong mo yung filter direct sa housing without seating sa filter pad like the OEM na filter then fastened pa sa filter pad . Parang yung pad is acting like a secondary filter din kasi when I cut the pad puno rin soot deposit.
Thanks-RTS
- Dec 2005
- 57
August 5th, 2011 12:50 AM #2046anyone had experience na pag inikot yun manibela may maririnig na parang whistling sound? sa initial andar ng truck wala pero pag nakatagal na bigla na lang lalabas yun whistling sound.
Tsikot Member Rank 3
- Aug 2003
- 1,251
August 5th, 2011 09:35 AM #2047Yes. At 1K mileage, pinalitan ng casa yung steering assembly. Pero pagdating ko sa 12k, bumalik. Meron silang nilubricate, pero bumalik pa rin. Pagmedyo umuulan, nawawala, pero paghindi, lumalabas ang problema. Hindi ko pa binalik sa casa, busy kasi.
PLUS yung ingay pag apak sa clutch, bumabalik ang problema. PLUS yung left rear suspension, maingay pa rin, maski nilagyan na ng silencer, at ilang beses na nila nalubricate.
August 5th, 2011 01:04 PM #2048
Yes, sir. Pinatong ko lang yung K&N filter in the same manner as the OEM filter, with the "front" mark facing top and front as per instruction manual. Aftermarket wet-type filters, like K&N, use the charging oil to trap and hold the dust and other pollutants. That's why it can do its function even if it's thinner than the OEM. The thin design is also the reason why more clean air can pass through making it efficient.
- Dec 2005
- 57
August 5th, 2011 04:28 PM #2049salamat sa input niyo sir.... lumabas yun tunog even before 1k so pag punta ko sa casa sinabi ko may tunog and check nila.... mukhang wala sila ginawa at may tunog pa rin... San casa kayo sir nag pacheck at sabi kailangan palitan yun steering assembly para dun ko din dalhin. At least sa inyo after 11k bumalik... sa akin kasi in less than 2 hours after the 1k bumalik agad.
Thank you!
