Page 100 of 250 FirstFirst ... 509096979899100101102103104110150200 ... LastLast
Results 1,981 to 2,000 of 5000
    Oct 2004
    #1981
    Quote Originally Posted by Arvin Cristi View Post
    partner - i think the stock wheel set for stradas are 17's na
    16x6 with +46 offset pa rin ang GLX M/T, sir.
    Oct 2004
    #1982
    Quote Originally Posted by braddypampy View Post
    hi to everybody!
    i'm new in this thread. im planning to get a strada within the month. 4x2 m/t. any insights from strada lovers would be very much appreciated. thank you! and im also planning to change tires and rims to make it more manly. any suggestions? thanks again.
    Your choices are 16x8 with +25 offset (265/70r16 tires), 17x9 with +12 or +10 offset (265/65r17 tires), 18x8 with +25 offset (265/60r18 tires), 20x9 with +12 or +10 offset (265/50r20 tires). Or 15x8 with +25 offset (31x10.5r15 tires), 15x9 with +12 or +10 offset (31x10.5r15 tires). Eto ang mga common wheel sizes, wheel widths, and offsets. Offset of +/-5 variance is acceptable.
    #1983
    may iba pa ba nag bebenta ng mickey thompson tires besides auto options or sila lang ang nagbebenta nito?
    Jul 2011
    #1984
    Quote Originally Posted by doy View Post
    sir, thank you very much for your detailed suggestions..i'll look into it..im excited kasi this is my first time to own a pick-up. though its not 4x4.
    Oct 2004
    #1985
    Ok lang yan, sir. Mine's a 2010 GLX M/T only. I'm wearing 15x9 wheels with +12 offset and 31x10.5r15 all-terrains, a month after I got the unit. It's also my 1st pick-up truck. Chrome wheels are usually heavier and more expensive than polished, painted, or matte finish wheels.
    May 2008
    #1986
    Quote Originally Posted by uj1n View Post
    sirs, 1st time here ;) ... i'm planning to buy strada 2011 glx this Aug but accdg to my dealer may lalabas daw na 2012 model this Sept. question is any idea what was the diff of 2011 vs. 2012? thank so much in advance...
    best regards
    kamusta po sa lahat. bago po ako dito na mag post, pero for the last few months have been back reading the posts here on this thread and on the strada mods.
    nag order po ako ng strada for this august, pero sabi po ng SA eh antay ng konti at lalabas daw nga yung 2012 upgrade ng strada. wala daw kaibahan sa exterior meron daw bago sa interior at may 30K additional na bayad.
    hope to join the club once i get my unit.
    TIA.
    Jul 2011
    #1987
    thanks again sir...mag update nalang ako in case i have it na..thanks again. God bless you.
    Oct 2009
    #1988
    sir doy kung 16x8 0 offset tapos 245 75 mukhang papantay sa fender but not too noticeable impact on the take off? almost same height to ng 265 70 pero di sing lapad.
    di kaya panget tignan? btw sa offset 0 na 265 70 1 3/4 inch labas sa fender pero kung gls fender medyo sakto lang.
    parang hinahanap hanap ko kasi ngayon yung power ng stock tires
    Jun 2007
    #1989
    Quote Originally Posted by sphinx1228 View Post
    wala na sir sila lang hehe...dati nagbibigay sila sa mga ditributor....pero ngayun hindi na ....
    #1990
    salamat sir sayang wala kasi stock na gusto ko...
    Oct 2004
    #1991
    Quote Originally Posted by bigtrak View Post
    Medyo konti lang ang difference ng width ng 245 at 265, sir. Kung 235/85r16 siguro (265/75r16 diameter but thin), mas may pulling power ka.
    Jun 2009
    #1992
    Hi,
    I have 3.2 L strada & this weekend my skeds is to change oil, my first outside casa, my question is - Is it necessary to use engine flush for a currently using full synthetic ? what oil filter best to use, also for fuel filter?
    Presently I still have the unwanted guest the "Engine Warning Light" my forth encountered kaya medyo immune na ako beside wala akong na o-observed na pag babago ng thrust ng acceleration.
    Thanks for any input
    RTS
    May 2008
    #1993
    Guys im due na mag repaint, i'm thinking of painting it matte black, saw it sa mga sports car sa US ok din tingnan dont know lang sa pickup, also ive read somewhere that mahirap daw yung maintenance? also changing to matte black means changing tires din para bumagay... hmmmm..what do you think?
    Quote Originally Posted by RTS View Post
    Hi,
    RTS
    Engine flush not really needed especially if you are going to use the same kind of oil pa rin. Search mo yung oil filtration na thread to see that there are better and less expensive filters aside from OEM. VIC=OEM; while Bosch, Purolator, baldwin, fleetguard (as long as originals and not fake) are way better.
    #1995
    Quote Originally Posted by tancho_kuhaku View Post
    Sir you might also wanna consider a matte black carbon fiber sticker. I've seen it done on an Audi A4 and sobrang ganda. Yes it also had black rims. Only catch is that it cost the owner around 80k for the whole sticker lang.
    #1996
    Good days guys. Just want to ask, talamak pa rin ba ang SCV issues ng mitsu or did they come up with a solution already?
    Will the higher end deiesels (petron turbo and Shell v-power diesel) solve this problem?
    Thanks.
    Jun 2009
    #1997
    Hi,
    I had my oil changed last Sat. (full synthetic) 8.5 ltrs all in all plus oil filter (Vic C-109)last saturday, then I noticed the engine warning light disapear, mayroon bang connection ang sensor sa engine oil o nag kataon lang, strange he he he.
    RTS
    Jan 2011
    #1998
    Quote Originally Posted by Djerms View Post
    Thanks.
    Unfortunately sir, ive been reading posts here na V-Power Diesel na yung pinapakarga and yet they get the symptoms.
    (of course we must take with a grain of salt din naman yung mga pinopost dito, or opinions in general for that matter.)
    ang nababasa ko din dito, suggestions you can do regarding that issue:
    a. magpakarga sa stations na di binabaha
    b. stations na bago / 'new-ish' looking
    c. stations na madaming nagpapakarga
    d. and not having your tank go below 1/4 wont hurt either
    (and trying sticking with Petron or Shell lang, sabi ng iba)
    --292. Marco
    Jan 2011
    #1999
    Hi,
    RTS
    Hi sir...
    Im just surprised na 8.5 liters of oil ang ginamit sa inyong truck.
    Sabi nila 7L daw tlga ang limit. (while one 'reputable' casa uses 8L)
    But 8.5?
    --292. Marco
    Hi,
    RTS
    Dapat kapag low oil pressure na due to low oil iilaw yan eh. Baka kulang na nga rin engine oil mo before.
2010 Mitsubishi Strada [continued 2]
