Page 106 of 250 FirstFirst ... 65696102103104105106107108109110116156206 ... LastLast
Results 2,101 to 2,120 of 5000
    Dec 2008
    #2101
    anu ba mga common problems na sinasabi ng ibang tao dito about strada
    Dec 2008
    #2102
    Mga sir magkano ngayon ang magpakabit ng Tint na 3M sa Strada kasama windshield diyan sa Manila TIA
    Sep 2010
    #2103
    Sir yung last inquire nasa 5k pero ewan ko lang ngayon.
    Dec 2008
    #2104
    Quote Originally Posted by Spoileddux View Post
    Thanks Sir
    #2105
    guys ok ba yun hurricane air filter, hindi ba delikado sa engine ito kasi meron pa rin nakakalusot na particles at kahit at water pwed masipsip ng engine? nakabili po ako ok yun hatak niya at hindi na sakal, pero worried ako sa filtration niya especially sa water diretso agad sa engine. thanks
    Jan 2011
    #2106
    Quote Originally Posted by lordkups View Post
    http://tsikot.com/forums/mitsubishi-.../index438.html
    --292. Marco
    #2107
    guys im selling my hurrican air filter at 2,200 na lang, ok naman yun performance lumakas yun hatak pero bka yun water kasi pumasok, those who are interested PM ninyo ako. thanks
    Jan 2011
    #2108
    Mga Sirs, I need your help, hindi na nag function ang alarm system ng 2008 glx ko, I just noticed that the alarm indicator that is supposed to be an alternating red and green light, constant red na lang ngayon and then door locks does not automatically open when i turned off the engine, but my central lock system is still functioning. Hinahanap ko ang fuse but wala pala or baka located somewhere outside the fuse box. Me naka experience ba nito. Thanx in advance.
    Jun 2009
    #2109
    Quote Originally Posted by marktriton View Post
    It is almost a week since I switch to Hurricane air filter & its early to say about the filtration effect, even the KNN filter ,the filtration is ??? compared with the OEM , the two mentioned brand has no filter pads so the possibilities is not good as the original when it comes to filtration, yung nga lang parang sakal ang air intake , whereas the Hurricane & KNN malakas ang intake. What I did is a bought thin layer of air con filter inilagay ko sa ilalim, for the cost of Pesos 100+ you buy in any hardware stores & cut 6 sets of filter, in that way i have initial & secondary filters. Your worries goes same with other drop in filters without the pad filters.
    RTS
    Jan 2011
    #2110
    Quote Originally Posted by CoolSilver View Post
    i believe naka vallet mode? or some other alarm setting.
    try checking your alarm manual.
    try adjusting din. nasa on yung key position. then press yung red button ng alarm setting.
    see if that will work (change light pattern)
    --292.Marco
    Jan 2011
    #2111
    Quote Originally Posted by theparanoid View Post
    --292.Marco
    Sir,
    Yan din ang another problem ko, my unit kasi is pre-owned, when i bought it wala nang alarm manual. Pwede kaya akong humingi from Winterpine? How do we change the modes, is it with the remote control or the one inside the dash board
    thanx a lot for your reply
    Sep 2010
    #2112
    Sir,
    bro,try mong ilagay sa on positon ang susi,tapos press mo ang button doon sa ilalim ng dash board sa left side ng manibela,tapos saka mo testingin kung ok na;
    #2113
    [QUOTE=RTS;1801561]It is almost a week since I switch to Hurricane air filter & its early to say about the filtration effect, even the KNN filter ,the filtration is ??? compared with the OEM , the two mentioned brand has no filter pads so the possibilities is not good as the original when it comes to filtration, yung nga lang parang sakal ang air intake , whereas the Hurricane & KNN malakas ang intake. What I did is a bought thin layer of air con filter inilagay ko sa ilalim, for the cost of Pesos 100+ you buy in any hardware stores & cut 6 sets of filter, in that way i have initial & secondary filters. Your worries goes same with other drop in filters without the pad filters.
    sir RTS anu filter binili mo sa hardware, parang dishwashing foam ba ito, may pictures ka ba so i can see, Thanks
    Jun 2009
    #2114
    [quote=marktriton;1802012]
    Quote Originally Posted by RTS View Post
    sa ACE hardware ko binili , just tell them filter for air con(household) ,usually naka plastic na sila at precut na for window type aircon.maraming klase but I chose yung pina ka manipis, then with the old OEM sinukat ko lang ,then cut & I produced around six pads, matagal tagal na rin gamitan yun, It is not a special type of filter, commonly use sa aircon, there are thick, & thin around 5mm, kasi pag kinapalan mo it may cause again some restriction in air intake.
    RTS
    Jan 2011
    #2115
    Quote Originally Posted by atlantico View Post
    Bro, thanx! back to normal na alarm system ko, hirap talaga pag walng manual buti nalang maraming mababait dito!
    Sep 2010
    #2116
    no problem,bro.:-)
    Jul 2011
    #2117
    Good day!
    I heard from one of the S.A.s here in western Visayas that 2012 strada will be out either 1st or 2nd week of September.
    Manual Transmissions will have VGT. the other one told me that 2.5 gls and glx will have ABS-EBD. How true is this?
    Thanks!
    May 2007
    #2118
    ^^^ hmmm... no comment ako diyan sir... hehehe...
    Jul 2011
    #2119
    Bakit kaya sir?
    #2120
    hmmmm ganyan din sabi sa akin sa Citimotors makati, ABS daw saka integrated na yung alarm sa Key, while Valle Verde told me na minor modifications lang.
    It seems wala talaga clear specs sa changes.
    Pero nakapagtataka sa sulit may mga nagbebenta na ng 2012 version, tapos may mga pictures na. Some of the pictures galing dun sa mga concept designs yung may fullbox lid na color black.
    Kung VGT na engine ang change sulit na sulit yun for the 30K increase sana nga totoo yun :D
2010 Mitsubishi Strada [continued 2]
