Page 56 of 81 FirstFirst ... 64652535455565758596066 ... LastLast
Results 551 to 560 of 808
    #551
    What's the ideal position / orientation when buying a property for residential? ...
    ... feng shui it...?
    seriously,
    the first question in my mind would be the geologic stability of the area.
    the second would be the flood situation.
    third, how accessible is the property from major public roads and from utilities (meralco, nawasa)?
    the rest, the house designer can probably address it.
    #552
    What's the ideal position / orientation when buying a property for residential? ... East, West, North, South? ... Long side north/south, short side east/west? ... For efficient light and ventilation ...
    Make sure the part of the house where you will spend most of your time in is not facing the afternoon sun.
    Signature
    #553
    agree.
    by personal experience, afternoon sun can equate to hot night later that day.
    morning sun can equate to "rise and shine" atmosphere.
    Jan 2016
    #554
    If you could also position your T&Bs, kitchen and laundry area in the afternoon sun, that would be an ideal lay out, iwas molds.
    Nov 2017
    #555
    agree.
    My personal preference, house/lot is facing the morning sun.
    If its not, then your architect can always recommend on how to improve the design to make it more suited to improve the ventilation or air circulation. If you believe in feng sui or not, it will not hurt to look at those recommendations.
    Mar 2004
    #556
    If possible, buy the lot with the proper orientation so the house does not have to "compromise" with the design ... for proper lighting and ventilation ...
    #557
    old feng shui saying,
    "place your window facing the north, so's you can espy the hun as he approaches,
    and place your door at the rear, so's the hun may not see you leave or enter the house.
    Jan 2012
    #558
    West facing lots are nice because the front of the house facing the road can be mostly walls or louvers for privacy and the rear area which is the pool/lanai/garden will be shaded in the afternoon. The front of the house could also be used a breakfast nook with a garden.
    However there is also a benefit of having the pool on the west side of the house because the afternoon sun will heat up the pool for swimming at night.
    South is considered to be warmer than the north side.
    IMO the orientation doesnt matter much from a design standpoint. However Feng Shui says north facing lots arent ideal but the work around for that is to place the front door perpendicular to the front property line.
    Your architect can work around the orientation. You should also consult a Feng Shui early on if you intend to use such a service.
    I would only avoid odd shaped lots (for medium to small lot sizes) and tumbok lots. Perimeter lots are sometimes ok, sometimes bad depending on what the road, village, or structure is behind.
    Lot topography is another question, flat lots are cheaper to build on but wont offer much of a height limit advantage.
    Mar 2013
    #559
    Id avoid putting your living , dining and bedrooms facing the west only because the heat is unbearable. I grew up in a house that was west facing and believe me it was sweltering.
    Now if you have a resort with a view...sunset views are always preferred.
    Sent from my SM-S918B using Tsikot Forums mobile app
    Sep 2010
    #560
    agree.
    kaya balcony namin facing the morning sun.
    di na kami nagpalagay facing west kahit harapan namin yun.
House Construction
