Results 521 to 530 of 725
September 19th, 2022 06:56 PM #521
effective yan pumice stone, pwede din gamitin sa porcelain sink. tapos pwede din pang tanggal nun dead skin sa heel mo, puputi ulit yun hehe. na try ko na
- 51,387
September 19th, 2022 08:03 PM #522
September 20th, 2022 10:08 AM #523
September 20th, 2022 12:26 PM #524
I usually buy my footwear half-inch bigger than my actual size, but the past 2 years mostly WFH kaya naka spartan lang ako
parang same material eh. basta yung parang nadudurog. mas mahal yata yung sa watsons, sayang kung ipang linis lang ng toilet bowl hehe. sa shopee parang 25-40 pesos lang nabili ko dati.
September 20th, 2022 03:14 PM #525
Yes malamang mas mahal nga ung sa Watsons but it's already there, hanapin ko na lang at try kaskas sa labas muna
- Sep 2006
- 2,746
January 3rd, 2023 01:36 PM #526Advice nga po, which do you prefer for house roofing, Asphalt shingle, CPAC or Kawara if budget is not an issue? Any experience with these roofing?
January 3rd, 2023 03:01 PM #527
Only 1 brand/type of roofing somehow seemed to hold its own against Odette...The Belgian-made IKOtile stone-coated metal roof. The rest all saw damage. Priced right between tin & clay.
CPAC is concrete. Kawara, GCI are clay, better than concrete. These require pre-painted rib type longspan underlay. Clay is priciest amongst the common/conventional roofs.
Sent from my SM-S901E using Tsikot Forums mobile app
January 4th, 2023 12:26 AM #528
How many cars can fit sa 150 sq m area na pahaba. Width is 2 cars.
Sent from my SM-M127F using Tapatalk
January 4th, 2023 12:37 AM #529
Average car size is less than 2 x 5 meters ... 150 square meters ... assume 5 x 30 meters dimension ... 30 meters = 6 cars x 2 = 12 cars will fit in 150 square meters ...
- 51,387
January 4th, 2023 01:19 AM #530assuming each average car (let us assume it's an american family sedan or a caddy) measures 5 meters long x 2 meters wide,
it goes to assume that the 150 sqm lot is 4 meters wide x 37.5 meters long.
car capacity will depend on how the cars are packed.
if the cars will be packed in there like tiles in the bathroom,
that'd be 7 car lengths x 2 car widths = 14 cars only.
if the cars will be driven into the park,
that'd be only one car and not two abreast, as it's impractical to nigh-impossible to drive them into the park and parking them two abreast, without bumping into each other.
that would then make for only 7 cars parked in the lot.
errr,
why are you asking, po?
btw,
back in the day, american cars were moved across the continent in train flatcars.
to maximize the numbers and decrease freight expenses, designers would limit cars' dimensions.
Magkano ba ang bendix? Yung nabili kong brembo brake pads for Isuzu Mux ay nasa ~P9,000 (~P4,500...
Brake Pad Thread [Merged]
