Results 531 to 540 of 808
- Sep 2010
- 3,021
January 4th, 2023 08:54 AM #531
- Sep 2021
- 898
January 4th, 2023 09:43 AM #532^^^
Hirap lang diyan for the vehicles in the back if you pack it to capacity.
It may be a better idea to just reduce the total number of vehicles, and park them perpendicularly (like sa mall) then have a single driveway para makalabas lahat without needing to "shuffle" them.
January 4th, 2023 12:10 PM #533
It's the parking in my Lola's house. She said the garage is exactly 150 sq m from the gate to the back wall (?) of the property. It's 2 cars wide. Tama computation niyo na 12 cars, so the parking is 2x6. Hindi nga lang pwede i swing wide open yung door ng car parked sa side ng wall. My cousin and I were discussing how many cars used to fit there when cars were still NORMAL SIZED. I recall 10 to 12 and he said less daw. I WIN
Anyway, it's kinda sad because there are discussions about selling my Lola's house
Yun lang talaga ang hassle, malas pag nasa dulo yung car, it's like tetrisSa family namin they always park inside when visiting lola, that's one reason why I prefer street parking
- 54,186
January 4th, 2023 12:21 PM #534our parking driveway is a smaller version of that: fully loaded, it can accomodate five cars bomper-to-bomper, and two cars to the side pockets. most of the time, however, there're only four cars parked.
i sometimes hop-and-drive seven times in-and-out, 'ala tetris, to get out the car i want to drive that day.
we are also particular about the brightness of the back-up lights. a foot inside the greenery, are a concrete wall on one side, and un-yielding kamiases on the other side.
imagine our driveway during fruiting time... "take all you want... please!"
heh heh.Last edited by dr. d; January 4th, 2023 at 12:26 PM.
January 4th, 2023 12:38 PM #535
Pano pala palitan yung mga roofing insulations na parang aluminum foil na may bubble? Nalulusaw na yung sa garahe namin, kapangit tignan.
Signature
January 4th, 2023 01:03 PM #536
You can ask either Metalink or Puyat Steel as they both have insulated long span roofing. You can contact metalink directly but you probably need to find a reseller for Puyat Steel
It can attached on the existing purlins. The insulation of the roof can be between 25-200mm in thickness. You can probably go on the thinner side since its a garage
January 4th, 2023 04:42 PM #538
The insulation is riveted between the purlins and the metal roof. A contractor can remove the roof, install the roof insulation, and reinstall the roof. We typically use 12mm PE foam with aluminum foil on both sides.
I misunderstood that you wanted to change the entire roof
January 4th, 2023 08:32 PM #539
January 5th, 2023 07:27 AM #540
yung ganyan namin sa garahe sinira nang ibon tapos binabahayan nila..
I do not have technical knowledge on cars. Since I am scouting for a new ride (I already have an...
BYD Sealion 6 DM-i
