Page 117 of 371 FirstFirst ... 1767107113114115116117118119120121127167217 ... LastLast
Results 1,161 to 1,170 of 3710
    Feb 2005
    #1161
    Quote Originally Posted by silver114 View Post
    Hello Sirs,
    I need your help and inputs..our sporitvo a/t has a leak on the oil pan? ( Im not if the oil pan really has a plate?) what part should i replace? See pic below. How much would it cost to replace it?
    Thanks in advance!
    Photos you have posted do show the oilpan and part of the transmission. The neophyte in me says it's not a leak in the oil pan per se but the oil may just be "crawling" to it.
    Best to have your car lifted and have the underchassis thoroughly cleaned. That way, you'd be able to trace (and determine) where the oil leak is actually coming from.
    Jan 2011
    #1162
    Quote Originally Posted by Benzmizer View Post
    A cleaning (pressure wash) as recommended by Benzmizer, is mandatory before going any further.
    My guess (not good enough, though!) is that the rear engine oil seal is leaking.
    Check your engine oil level more often until you determine the source of the leak.
    Please let us know what you find, so that we can all benefit.
    Ciao!
    Uncle Nick.
    #1163
    Hello Sirs,
    Thanks in advance!
    If my assesement is right, thats in between rear part of engine block and the bell housing of the transmission case. If correct it can be the rear crank case Oil seal.
    Procedure: transmission housing will be taken down (might as well have your clutch pack checked or replaced to save you money if near replacement stage na) Lower part of crankcase will taken out and cleaned.
    Parts you will need.
    1 pc. Front collar gasket
    1 pc. rear collar gasket
    1 pc front crank case oil seal
    1 pc. rear crank case oil seal
    Most expensive will be the labor, parts are quite cheap but made in japan. You may as well be paying for labor of transmission pull-out and crankcase pull-out. Might as well replace the other seals involved. Get a very good mechanic or one with warranty. I deally the engine should be turned upside down for correct mounting, but since we are in the philippines it can be done without turning it over. IMHO
    #1164
    Quote Originally Posted by zalphyro View Post
    Nang inacquire ko XUVi last year, meron nang nakalagay na tulad nito:
    [SIZE=4]"SFVR"[/SIZE] ang nakalagay sa label......!!
    An Anti-Pollution, Fuel Saver-Engine Preserver device for all kinds of cars, gasoline-fed or diesel-fed combustion engines..... Merong nakalagay na adjustments na iniikot on how to minimize fuel consumption and so far under normal speed sa hi-way going city and our town(Speed from 80 - 100km/hr) nasa 16:1 liter ang ratio over distance and fuel.....
    Maganda ang acceleration and I could reach 120 to 130 km/hr(at may ibubuga pa) considering wala kaming NLEX o SLEX o ano mang super hi-way dito kaya din rin gaanong maka accelerate into higher speed..... Natatakot lang akong magpa bilis nang masyado kasi nga ang tinatahak ko na daan dito ay 2 lanes lang, maraming intersections at ang iba ay populated pa kaya di ko pa na try isagad.....
    Bro, saan makabili nito at magkano price?Thanks.
    May 2007
    #1165
    Thanks to all of you...i changed my engine oil and the mechanic noticed that the engine is overfilled with oil. Could this be the culprit?
    Feb 2005
    #1166
    Can be. That is the purpose of the dipstick. There is a minimum and maximum level of engine oil to put. As the saying goes, "Anything in excess is BAD".
    May 2007
    #1167
    Thanks sir Benz..i couldn't agree more
    I'll keep you posted!
    #1168
    great day po mga tsikoteers!
    any knowledge sir about tail light ng Sportivo Xmax, supposed to be as per manual LED Lights na yung Break Light ko, pero lately napansin ko di siya LED.
    haist ano po ba talaga nakakabit sa Sportivo? nag iiba po ba ito sa dealers?
    O.T
    nag leleak po yung hose for my P-Steering, upon inspection mukhang sa crimping between metal and plastic/rubber hose...
    Feb 2005
    #1169
    Quote Originally Posted by xmax2010 View Post
    Huh? It SHOULD be LED
    #1170
    Quote Originally Posted by Cee-Pat View Post
    My wife had our XTi handles installed with chrome garnish with the chrome garnish for the fuel cover at Isuzu Cavite.
    sir how much po yang chrome garnish for door handle?
Isuzu Crosswind Owners Thread [continued]
