Page 67 of 371 FirstFirst ... 175763646566676869707177117167 ... LastLast
Results 661 to 670 of 3710
    Feb 2005
    #661
    Quote Originally Posted by lucent View Post
    sir benz and the gurus - have you heard about ECU reset? is it really effective?
    Question is, WHAT FOR?
    Aug 2007
    #662
    I have a 2010 XUV Limited Edition AT, wala sya foglamps. How much kaya pa-install sa CASA? I'm very near Isuzu Alabang. Hindi ba mavovoid ang warranty if you install foglamps c/o casa?
    Dec 2010
    #663
    Quote Originally Posted by Benzmizer View Post
    Hi Sir Benz - I just saw this thread. Curious lang po.
    "ANYTIME you make a modification to your car -- intake, exhaust, etc. -- that modifies the performance you should reset your ECU. The ECU will calculate air to fuel ratios etc. and, if you have ever done some of these installs, you'll notice that your car will idle poorly as a result."
    Feb 2005
    #664
    Quote Originally Posted by homergp View Post
    Nope IF you are to use OEM foglamps used as standard for the Sportivo and it would be an authorized ISUZU dealer who would install them.
    Hmmm, makes sense but I would not vouch to confirm this is necessary. From my knowledge, the ECM (common terminology) automatically calibrates and need not have to be "reset".
    Dec 2010
    #665
    OK po. Noted with thanks Sir.
    Apr 2010
    #666
    Quote Originally Posted by Fargin View Post
    tsktsk yan din worry ko. sa gas station lang kse nagpachange oil dad ko eh. ano ba negative effects kapag sobra ang oil na nilagay? tsaka tama ba yung oil filter na nilagay (VIC-507)?
    it should be VIC-207 for manual with turbo, you can also use the purolator brand found on Ace hardware.
    Jan 2011
    #667
    Here I am again guys..
    Tanong lang ako if possible ba na palitan ng steering wheel ng trooper yung sportivo ko? Malaking trabaho kaya ito or simple modification lang? Ganda kase ng sa trooper eh..
    Magkakano kaya ganito sa surplasan?
    Thanks again!
    Feb 2005
    #668
    Quote Originally Posted by tata_ismael View Post
    Pwede. Plug and play. I have some friends who were able to source a black version of the Trooper's steering wheel somewhere (please don't ask me where, i don't know) even with an airbag hornpad (of course, non working when installed to their Crosswinds)
    Nov 2007
    #669
    Quote Originally Posted by doo View Post
    so para saan po yung VIC-512? i thought ito yung para sa crosswind MT then iba for the AT. need pa palang iconsider if turbo or not...
    Jan 2011
    #670
    Thank you sir benz..
    Good to know na plug 'n play.. Try ko na maghanap..
Isuzu Crosswind Owners Thread [continued]
