Mgo brod, pwede pa bang i-lift or taasan ng 1 to 2 inches ang Crosswind XUV?
Mga Sirs question po ulit.
May alam po ba kayong gumagawa ng seat cover yong maganda and maraming selection ng colors? sa cavite area po.
TIA mga sirs
sirs newbie po ako. bought a 2013 isuzu crosswind. maganda araw/gabi po sa lahat!
Good day!pwede po bang malaman kung saang casa ng isuzu ang ok for PMS? Metro manila po location ko. Thanks in advance!![]()
KUng saan mas malapit at convinient sau at wala ka naman naririnig na bad reviews sa casa na pupuntahan mo dun ka, tapos makipagkaibigan ka sa nagrrcv sa service at saka sa mechanic para sya palagi gagawa. Abutan mon na lang ng "tip" para d ka nya makalimutan. Although lahat ng casa may flaws, just be friendly, it helps. Sa Manila meron dyan sa may otis, quezon ave meron din dito ako nagpapagawa ok naman.
if on running then saka nag- ilaw yon check trans, yon ang malaking problema., read the manual.
May nakasubok na bang bumili ng bulb ng foglamp tapos pinakabit sa casa?papayag ba sila sa ganito?bumili kasi ako nung all season ng osram tapos 55w naman sya,gaya ng recommended.
Sir, if kaya niyo, you could place the bulbs yourself.In our 2003 Crosswind, I just turned the wheel hard right to work on the left foglamp, twisted the plastic covering off, removed the metal pin by pushing on it (for the left fogs, it's hooked on the left side, while right naman sa kabila) and pulled the bulb out. Did the reverse to put in the new bulbs. Just be careful not to touch the bulbs with your bare fingers, as the oil in your hands would destroy your reflectors.
The seatbelt (front driver-side) on our 2003 Crosswind does not fully retract anymore. Im guessing the springs are worn out already. Any quickfix you can suggest or, dapat palitan na yung buo. Thanks!
Hi guys,
Meron na ba sa inyo nakapagpalit ng AC button light? Yung maliit na button with green light to indicate that the AC is on. Not a big deal, pero curious lang ako kung pano palitan yun. Pundi na ata kasi akin. Thanks guys
That's sales talk in action. Making it sound complicated so that they can charge higher for a very simple job. Buti sana kung hard to reach yung sedimenter/water separator tsaka yung fuel filter. Kaso ni hindi mo kelangan kumembot or yumuko man lang para i-replace yung fuel filter and drain the sedimenter/water separator ng crosswind eh.
ang problema niya nabili na niya yang underpowered unit na yan na tulad nitong underpowered unit ko na ilang taon ng bumubulwak ng langis, hindi masira sira!
ang nakakabadtrip pa nito nauuna pang bumigay yung baterya at binanyahe pa ng north luzon at south luzon ng hindi ko na mabilang na pagkakataon!
at ang masama pa niyan, sinagip oa namin yung sister inlaw ko sa masarap sakyan at dalhin at hindi underpowered na innova!
tumirik bigla ng walang sabi-sabi!
kasi daw inilusong sa baha. sus!
tapos sasakyan ko ipinalusong sa halos ga-bewang na baha?
ano ba?
please naman, masira ka na ng makabili nako ng innova!
