A good sign is low power and unusual smoke.
di yata sq(not sure). magkaiba sila ng piping at element/housing for sure.
di ba naka K&N ka na?
hi,
i'm just new on this thread.
i am planning to acquire a bighorn. ang offer sa akin is 330 maayus n lhat.
i asked about the version and it says BIGHORN 96 MODEL, 4jg2 Engine, 4x4, dual aircon. na stock lang kasim dami sasakyan un me ari. turbo daw problem. sa 330k is this a fair deal na ba? by the way, subic po ito.
i would like to ask more about this bighorn...
consumption
maintenance... anu anu b dapat ko tingnan,, (e.g. change oil, anu pa)
with regards to power, i read that mas mlakas sya sa pajero.
wala po kasi ako first hand idea.
kindly give more inputs re specs na din. pros and cons
thanks
val
Sir if problem yung turbo ang mahal nyan...
Better wait pa natin comment ng mga experts
Hi Val,
With regard sa bighorn kung totoong model 1996 yan, okay yung deal nyan for 330K. Check mo nalang yung conversion, I suggest kung kukunin mo gastusan mo. You replace the whole steering column, pitman arm etc.. with regard sa steering. I owned 1993 bighorn still run okay and I will say I have no regret. For 1996 ang advantage nyan EFI nayan pwde mong i tweak para lalong bumilis by buying a chip ang disadvantage lang yung syempre more electronic na yan. Kaya pag nasira yung fuel pump mo bili ka ng surplus I dont know kung mafix pa yan kasi nga electronic pump na. Sa parts naman dont worry you can buy most part sa walco or jason auto supply.
Goodluck sa bighorn, Okay yan kung okay ang pag convert and go for it.
hi guys,
thanks so much sa mga reply ninyu. malaki nbawas sa agam agam ko.. one more concern is fuel consumption... how is it pag dating sa makina na ito?
sa 330 maayus n maayus n po iyon. i just need to road test and pag me dipresenya is aausin pa.
blak ko sana ipa road test sa tgaytay. ok na po ba ito. nga pla di k kbisado kambyu nito dahil sa automatic.. nkapag manaho n ako ng automatic e alang k lang "D" yta as in drive.. any tips pra ma orient nman ako dito pra din ma use ko sya to the max.
thanks again!!
val
