Need help for all Trooper Expert...
Problem on Overdrive pag long run na di na nag shift sa 4th gear
pero pag malapitan lang takbo nag shift naman.. Hmm, what is your speed when you notice that the tranny does not shift to 4th? What is the RPM reading?
Already done change Tanny fluid ang cleaning of Filter..
Any shop na malapit in laguna area? Is the "shop" you are referring to is other than an ISUZU dealer? Why not bring it to an ISUZU dealer and get there evaluation based on test drive or use of Tech 2? Baka lang kasi mas mapalakit ka pa ng gastos if a generic shop assess your Trooper (without using a Tech 3 gadget) and make a wrong evaluation....
My 2¢
ganun po ba sir..
