[size=6]go trooper>>>>>>>>>[/size]
Hi Val,
Kung EFI na yan bighorn mo pwede mong kabitan ng performance chip see this link http://cgi.ebay.ph/Performance-Chip-...3A1%7C294%3A50
Regarding sa convertion most nilalagay sa bighorn ay yung pang pajero gearbox yung gearbox okay naman ang problema yung pitman arm weld yun mostly minsan hindi mo halata ang pagkawelding. Yung pitman arm yun ang madalas bumibigay. I've seen once at marami na naka experience niyan kaya better check mong maigi at much better palitan mo kasi ikaw ang nakasakay dyan. Hindi mo alam kung kailan bibigay better gastusan mo nalang.
I would like to second Nap's thoughts on ensuring the conversion was done right. iwas ka sa welding kung pwede. kakatakot yan. else palitan mo dapat ng orig power steering gearbox at pitman arm. I also drive one and its good for keeping. ave ko is 7.5km / liter mixed city/hi-way driving.
sir.. saan banda sa blumentrit?.. i'm also lookng for a cyl head ng 4jx1. u mean sariwa? as in bago? nasira din ung cylinder head kasi overheat ung isuzu tooper namin.. ung 40k? how much is the labor?
tanong lang po.. eh.. kasi nag ask ako sa kakilala ko. sabi nya if u plan to change the cylinder or the engine - may setting pa daw.. computer setting? totoo ba yan.. or kung cylinder head hindi na kailangan?
any updates or news where can i buy cylinder head or 4jx1 engine?
thank u sirs..
Your 2003 Trooper is using a 4JX1-TC engine.
As for the 'setting' required, I'd say any major repair (specially if change engine), you'd need to use the Tech 2 gadget. From my knowledge, only authorized ISUZU dealers have this. Maybe some guys who had major repairs on their Trooper's 4JX1-TC engine could validate this.
I am still at a loss where you could buy a cylinder head or whole 4JX1-TC / 4JG2 engine. Blumentritt may have the cylinder head (40k according to SQ). And whate he meant as "SARIWA", would mean used but still in very good condition.
ung 40k? mayroon pa silang stocks? is it reliable? cylinder head? how about the engine? kasi i ask sa banaue. the least i can get is 55k? i didnt ask discount.. sir, kilala mo naman ung doon ZERCOM? Trusted naman po? hindi sira ung benta?
what do u mean by ECU? no idea po.
Hi guys,
thanks again sa advise.. noted na un pitman arm.. experienced man un tao k kausap and i discussed it with him na. pag ma turn over sa akin i'll have it check by other person.
maaus nman un kausap ko and sanay sya sa convetered kya ayus din. re sa EFi na kit, kakausapin ko pa din sya. di nman siguru mhirap ikabit.. ask k na lang kayu uli about it.
syanga po pla. ipapa re paint ko kasi... anu b mgnda, black or gold? gustu ko ksi un me pagka elegante
val
aus!.. nsagot n nman sir katanungan ko, now i have no doubt sa kulay. actually, black sya sa pics o dark blue. me nkita kami niche color pero nun mkita in person ni mrs ung unit nag suggest sya n i black daw.
nga pla sir, i have been readding threads with regards to "change oil" anu ba sir advisable na brand (Besco, Shell, Petron)? sa cavite ako, kya consider ko din un layo ng bibilhan. of course, 3rd n ang un layu. 1st ko is quality, 2nd sympre price. any suggestion? san b mgnda bumili filters.
i'm trying to get inputs as much i can pra ma implement ko lhat bago ma turn over sa akin un trooper.
Naadict n yta ako sa trooper. dati aso, ngayun bighorn n. aus to.. dream ko kasi tlga.
thanks
Nga pla sir, i have been reading threads with regards to "change oil" anu ba sir advisable na brand (Besco, Shell, Petron)? sa cavite ako, kya consider ko din un layo ng bibilhan. of course, 3rd n ang un layu. 1st ko is quality, 2nd sympre price. any suggestion? san b mgnda bumili filters. BESCO. As to sourcing parts like filters et al, JAYSON mura daw.
For 4jg2 bighorn engine hindi naman mapili kahit anong oil like castrol, shell etc. okay lang for oil filter yung pang for 4jb1 bilihin mo since yung bighorn is different from trooper local 4jg2 oil filter kahit VIC brand oks na only for 300- 350 pesos ayus na sa suking auto supply. 6 liters of oil ang change oil ng bighorn syempre palit din ng oil filter. every 5KM or 6 months which ever first.![]()
Need help for all Trooper Expert...
Problem on Overdrive pag long run na di na nag shift sa 4th gear
pero pag malapitan lang takbo nag shift naman..
may mga forum ako nabasa na possible TPS da..
Already done change Tanny fluid ang cleaning of Filter..
Any shop na malapit in laguna area?
Thanks
