Page 311 of 425 FirstFirst ... 211261301307308309310311312313314315321361411 ... LastLast
Results 6,201 to 6,220 of 8497
    Jun 2006
    #6201
    parang magkasinglaki lang. Mukha lang malaki ang CRDI because of the turbo and the intercooler.
    #6202
    Quote Originally Posted by LadyRider View Post
    Good day Sir Kimika! Musta na po? By the way malapit na tuluyang mabuo ang SF Club natin! Meron na tayong Sticker design saka malapit na rin ma-up ang website natin! We will have a grand EB para sa launching ng SF Club! See you there!
    wow! galing mam LD!
    btw, to some guys who upgraded their stock tires and thinking to sell them, no rims just tires, please pm me, i'm interested.
    #6203
    Quote Originally Posted by ghost recon View Post
    less restriction air filters mounted inside the engine bay...
    meron ako suggestion sa set-up na to but it's up to you to decide...
    it's nice to look but it doesn't perform as what everybody thinks as it is.
    there is more oxygen in cold temperature than in hot temperature. that is why some engine specially those equipped with turbo have intercoolers mounted in them to have a constant cold or ambient temperature. more oxygen means more combustion when mixed with fuel therefore more power. this set-up is only good when the temperature inside the engine bay is cool which happens during start-up (this is when you feel your engine is kicking). however, after prolong driving the power will diminish as hot air comes in because there is now less oxygen needed for combustion. the result, less power and more fuel.
    enthusiasts who wanted to have a continuous engine power but with less money to burn usually fabricate scoop somewhere in the front bumber to catch more cold air as their speed rise.
    bottom line is more oxygen, more power.
    I got mine july of 08. I guess mali yung kinabit nilang engine cover after I had it repaired. I will post more pics para makita ko kung ano pang mga differences. Thanks
    Nov 2007
    #6204
    Hi guys!!
    Sir tidus is correct kasi kung i post natin tung mga ka comparo natin eh baka ma ulit uli yung dati na under attack ang forum natin..apat yung tinest ko na makers...but for the choke?? i dont think so i can hear their engine roaring...pero Idol ko pa din si sir TFR pag dating sa star toll speed di ko kaya yun..and share ko lang po kasi last year nasagi ako ng truck sa may buendia makati and na damage yung front tire ko lacerated sya..nag pa repair ako sa casa then pinalitan nila yung tire ko ng hankook..* first ok lang sa akin kasi ginawa kong spare tire but unfortunately nag karoon ng konting damage sa tirewall yung nasa front ko which is kumho..now the problem is its not covered by the warranty because its my fault ( na gutter kasi) so i cant use my hankook kasi different thread pattern sila so what i did is to place it at the rear na lang..hope this wont happen to you guys..but when it happens insist to replace it with the same brand and same thread pattern
    Jan 2008
    #6205
    this is the result of my chip upgrade...
    increase is not much. if some SF users want to have this upgrade, be sure to remember how your SF's react when your a/c's are shut-off. because you will experience the same even if your a/c's are engage with this chip installed to your engines.
    this is where i noticed also that our SF is applying more torque on the front wheels (4x4 models only) at the normal driving condition because during my test the car tries to swerve on my right as i put more gas.
    Jun 2007
    #6206
    Sir GR, Pls expound on the testing with a/c switch off... do you mean to say that w/o chip installed:
    Our SF will be faster (feel faster) with A/C off than with A/C on?
    with the chip installed.
    The SF will feel the same whether the a/c is on or off?
    thanks
    Jan 2008
    #6207
    Quote Originally Posted by coolman View Post
    thanks
    it simply means that your SF will be more responsive with the chip installed.
    i made that statement so that anyone who thinks of chip upgrade will start to observe how their units behave and run when their A/C is switch off before the chip upgrade so that they'll have their comparison and satisfaction.
    with the chip upgrade (upon my observation), my SF is very responsive even when the A/C is engage. it feels like the A/C is off although the A/C is engage.
    that is the closest thing of observation i could share since there's no dyno here to prove.
    #6208
    alam ko na ibig mo sabihin GR, nata-timing kasi na minsan pag apak ko ng accelerator e off ang a/c (on automatic) e parang umaalma ang santa fe, like feeling racer siya. parang 3/4 ang apak sa gas e in fact slight lang naman. many times na ko napagalitan ng aking kumander dahil dyan, bakit ko daw binibigla apak sa gas e normal lang naman apak ko. then after a few minutes mag-kick in ang a/c maririnig mo yung click ng a/c clutch so naka-off pala yung a/c nuon. big difference yan GR, lakas ng torque. but then i can just turn the a/c off
    postpone ko na muna, buti di ko pa nabigay $ kay romanian. lights upgrade muna, malabo ang low beam e. legal naman mag-HID sa santa fe since naka-projector di ba, as in kahit wala law against HID sa Pinas e di naman nakaka-offend sa other motorists kasi properly mounted sa projector housing?
    Jan 2008
    #6209
    lakas nga ng torque. ever since driving my SF ngayon ko pa lang napansin na nag-swerve sya sa sobrang lakas.
    pero balik na ako sa normal driving ko na pa-inday-inday lang:smiley:
    Apr 2005
    #6210
    Natawa ako duon ah hahaha!
    Thanks anyway GH!
    Jan 2009
    #6211
    Hey Goldrush please share some of the photos of your new Santa Fe. And congratulations on your new purchase!
    As requested...
    Ganda ng pagkakuha, kaya sinama ko.
    May 2007
    #6212
    Congrats ulit Sir sa SF ninyo! We have the same color of SUV!
    Quote Originally Posted by GoldRush View Post
    As requested...
    Apr 2005
    #6213
    congrats goldrush!
    Enjoy your new ride
    *Mam LR, may I suggest sa SFclubPhilippines magkaroon ng kanya kanyang folder ang member? the member can upload their photos on upgrade and maybe some information on DIY or anything with their SF?
    #6214
    Saludo sir goldrush for your Santa Fe pics. Ganda ng pagkakuha dun sa kambyo!
    May 2007
    #6215
    Quote Originally Posted by trackers888 View Post
    Ask natin kay Sir Allan para dun na lang sa website natin yun ilagay!
    #6216
    I keep my Santa Fe where ever I go, yes even in my bed before I sleep
    Nov 2007
    #6217
    As requested...
    nice ride bro.
    #6218
    uy PS3.
    Nalaro mo nb Killzone 2 Demo. ASTIG
    #6219
    *nels76
    OT: Nope bro XBox 360 fanboy ako eh Pero sige nga madownload nga... Anyway sa Videogames anyone thread na lang natin ituloy ang usapan. Ayos! May Sta Fe member pala na videogamer din maliban sakin...
    #6220
    Pareho talga kami neto ni sir trackers magisip .
    Magkakaroon po tau nun - "post by members"
Hyundai Santa Fe (Gen. 2) Thread
