Page 312 of 425 FirstFirst ... 212262302308309310311312313314315316322362412 ... LastLast
Results 6,221 to 6,240 of 8497
    Apr 2005
    #6221
    Quote Originally Posted by allanctan View Post
    Pareho talga kami neto ni sir trackers magisip .
    Magkakaroon po tau nun - "post by members"
    Ang daming upgrade na natatabunan agad kasi
    I'm sure kilala mo na kung sino ang top poster kung sakali
    May 2007
    #6222
    Quote Originally Posted by trackers888 View Post
    May bago akong ginawang modification just today! (hehehehe) Secret muna! (nyahahha - joke lang po)
    Post ko later sa Modifications/Upgrades later po!
    Nov 2006
    #6223
    Quote Originally Posted by LadyRider View Post
    O later na..........
    posts mo na Mam LR
    Apr 2005
    #6224
    My lonely SF
    I hope someday makatikim din sya ng upgrade
    #6225
    Oh surely once naupgrade mo na Santa Fe mo talbog kaming lahat kasi upgrades mo all in one go
    Jun 2007
    #6226
    Got my RaceChip PRo today (Thanks Sir C190). Had it installed at Maspro (took about 25 minutes). It can be done DIY style but you have to remove a lot of screws, the intercooler, and the engine cover before you can reach the plug. Sir Benjie tie the chip on a metal bracket which made it look real clean.
    As for the performance;
    Sir Ghost Hunter was right, the idling rpm went up to 800rpm. Acceleration has improved. with the racechip installed, you'd thought the stock engine management felt "sakal". its like putting on free flowing filter. Acceleration is acheived faster because the engine revs easier.
    Is it worth it? i'd say "yes". but pls note that this is a plug n play device, no setting of any kind. that means that you can't tune it with a laptop.
    I was not able to take pictures during the actual installation.
    these pics were taken when i got home;
    racechip installed on passenger side engine bay.
    View of the engine bay my unit is 2.2 4x2. arrows denotes things that have to be removed before racechip could be installed.
    Will update on the FC of this setup in the future.
    PS. I would like to thank Ma'am LR for letting have her racechip unit and Sir C190 for buying this unit for me.
    #6227
    Ah yes kanina pumunta din ako sa Maspro pinakita nga sakin yan ni Sir Benjie eh... May kukuha daw nyan, ikaw pala yun...
    Jan 2008
    #6228
    Quote Originally Posted by coolman View Post
    hehehe dalawa na tayo malalakas na SF dito
    anyhow, it took so much time for the chip installation. the way to do it is just unscew two bolts at the front. remove the oil dip stick. pull the back portion of the engine cover upward, this should unplugged this from the two rubber socket. then pull the engine cover sideway. no need to remove the intercooler. saves lots of time.
    btw, i have discussed with my german friend about this chip upgrade and he told me that this type of upgrade should come with less restriction air filters. so, let's buy K&N drop-in filters.
    also guys, i explain this before about filters. that is why i specify the drop-in filter because some might think that K&N cone type will work. sorry guys, it simply won't work unless the suction area of the cone filter will be isolated from the air inside the engine bay.
    drop-in filters are the same filters installed on your SF but it's made by K&N.
    Aug 2004
    #6229
    nice.... have u thought about your response to Hyundai if they void your warranty due to this MOD? for sure u wouldn't be removing it everytime u have to go for casa service right?
    Jan 2008
    #6230
    Quote Originally Posted by parakitoJDM View Post
    no need, they're simply naive.
    May 2007
    #6231
    You are very much welcome! See you sa Grand EB natin!
    Feb 2007
    #6232
    congrats...sir... hmmm excited na rin ako ipakabit yung racechip ko...hehehe thanks sir c190
    Apr 2005
    #6233
    Mag dilang angel ka sana Tidus Sir! Wait ko pa email add ni Sir Benjie, apply ako lay away plan
    Nov 2006
    #6234
    Sir coolman baka gusto mo pa dyno test sa speedlab
    naka K&N filter ka na ba?
    testing natin SF sa quarter mile kung talagang mabilis yan
    Jun 2007
    #6235
    Quote Originally Posted by ghost recon View Post
    Sir Ghost Recon, The engine cover have 4 retaining screws. only 3 can be accessed without removing the intercooler. one is right under the intercooler. Maybe next time, i will do as you said and i might be able to get to the screw just by lifting the intercooler assembly.
    Thanks for the drop in filter advice, will look around for those.
    but i think Sir Benjie have some KN filters on stock....
    May 2007
    #6236
    [SIZE=3]Sorry po medyo OT. Konting Announcement lang po.[/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3]Guys malapit na matapos ang stickers! Habol na sa listahan!!! [/SIZE]
    [SIZE=3]Follow this link:[/SIZE]
    Jun 2007
    #6237
    i was planning to remove this everytime i go for my PMS. its not really hard to install or uninstall....
    Jun 2007
    #6238
    Quote Originally Posted by Mnmg_2000 View Post
    Sir Mnmg, Its really worth it. the only down side (besides that its untested) is that with all that torque, we'd need better brakes. hehe
    Jun 2007
    #6239
    Quote Originally Posted by C190 View Post
    I'm stll using stock filters and will consider an K & N drop in filter....
    Thanks
    Aug 2008
    #6240
    Thanks
    How much is the chip again?
Hyundai Santa Fe (Gen. 2) Thread
