Page 192 of 195 FirstFirst ... 92142182188189190191192193194195 LastLast
Results 3,821 to 3,840 of 3899
    Feb 2012
    #3821
    Quote Originally Posted by EssB View Post
    Price update sa Volmax...
    Baldwin B2 - P225 (was P200 nung July 2013, last na bili ko).
    Baldwin BT223 - P290 (was P275 nung July 2013, last na bili ko).
    Sorry, nagmamadali ako... di ko na natanong current prices ng ibang common oil filters.
    Napamahal ba ako, or talagang nasa P350 na ngayon ang presyo ng mga Baldwin BT223 at Donaldson P550335? Kahit sa Facebook or OLX kasi yan na din ang presyo.
    Jun 2005
    #3822
    Quote Originally Posted by gearhead000 View Post
    Kay volmax ba yung 350 ang bt223
    Feb 2012
    #3823
    Quote Originally Posted by sirkosero View Post
    Sir Sirkosero, hindi po. Online ko lang po nabili. Ang mura lang pala kay Volmax? [emoji21]
    Sent from my LG-H962 using Tapatalk
    Mar 2012
    #3824
    P550335 can be bought for around 200 pesos.
    Dec 2013
    #3825
    [/QUOTE]
    JHF FILTERS Korean
    Fil filters (Korea) (Label says Toyota)
    OKIYA filters (CHINA)
    Sakura filters (Japan)
    Ryco (Austraila)
    VIC (Japan)
    Ginza (Japan)
    Power Long (Korea)
    Your oil is only as good as the filter your using.[/QUOTE]
    Just to make things clear
    Ginza is not a Japanese brand its from China or Taiwan (One of the worst filters in the market)
    Sakura is also not a Japanese brand
    It's an Indonesian manufacturer using a Japanese name
    Power Long is not from Korea it is from China
    Jun 2005
    #3826
    Ah kaya pala... dati tanda ko 290 lang isa nund December 2016. Once a year lang ako bumibili ng filters sa kanila. Hoarding na for the entire year for all of the family's cars
    Bibili na pala ako uli for 2018 na supply haha
    Jul 2014
    #3827
    Manageable pa rin ba pumunta ng Divisoria area kapag ganitong season? Saan kayo nagpapark? Last time sa Lucky Chinatown Mall ako nagpark. Almost an hour inantay ko para makapark.
    Sent from my SM-G7102 using Tsikot Forums mobile app
    Jun 2005
    #3828
    Quote Originally Posted by Mask Rider Blac View Post
    Pumupunta ako dun early morning para may parking pa sa lucky chinatown. Or sa tutuban ako pumaparada. Half day lang ako sa divi kasi di ako nagtitingin tingin. Alam ko na what i want to buy.
    #3829
    Quote Originally Posted by Rocko24 View Post
    Where can i buy donaldson at 200 pesos?
    Aug 2017
    #3830
    Would a Donaldson P550335 or a Baldwin Bt223 filter last for atleast 15,000kms when paired with a very stout oil like a Mobil Delvac 1 5w40?
    Pretty much everywhere I've read consistent UOAs online that it maintains its TBN at 10,000miles (15~16k kms) and since its also the most expensive diesel oil out there it just feels wasteful to change it out early since I racked up 10,000kms in under 7 months.
    Quote Originally Posted by leoblack9 View Post
    Yes pwede if not so polluted or dusty or the driving is not rated as severe. If it is, best to keep it at 10,000kms between OCI.
    #3832
    good day! can someone kindly confirm that using this oil / oil filter combo, Mobil Delvac MX 15W40 and Baldwin B113 can be used up to 10,000 kms as OCI? Thanks. Also, is Donaldson a good fuel filter? my engine is Isuzu 4JH1-TC.
    Thanks!
    May 2017
    #3833
    Jan 2009
    #3834
    He lost all credibility when he said he’s comparing between the “least expensive conventional oil filter to the most expensive fully-synthetic oil filter”.
    #3835
    What is the Baldwin oil filter for Fortuner 2016 Diesel? What about for Innova 2008 gas? Pareho lang ba?
    #3836
    ^ 1KD/2KD, 1GD/2GD, 2TR engines use the tiny BT233. You may want to cross-ref OE PN#s at Baldwin site just to be sure.
    #3837
    Sir, I read that Baldwin B2 a bigger oil filter may also be used. Is this so?
    What about MANN W940 High Performance, is this also a good filter for Toyota Fortuner and Innova?
    #3838
    Erratum to my previous, should be BT223.
    Quote Originally Posted by attyallanlatras View Post
    Yes you may as long as the thread,gaskets are the same and it fits in the engine, and bypass valve is within specs. Basic principle is the bigger the better because of larger filtering media surface area, filtration is a straightforward/exact science.
    #3839
    Toyota 90915-YZZD2
    Baldwin BT223
    Donaldson P550335
    Baldwin B243^
    Donaldson P550400^
    Baldwin B1405
    Baldwin B178^
    Donaldson P554770^
    ^ long version
    Got the above from my back reads here. How would I be able to verify if the above reference number would fit or be equivalent to toyota oil filter for fortuner?
    #3840
    BT223 or similar-sized should fit without problems, but if you will upgrade- buy some samples or measure the actual vertical clearance to determine if it will fit in the engine without hitting any hose/accessories.
    Sometimes the thread of the spin-on adapter has stand-pipe that you need more clearance for the ing/egress of the filter. Or the diameter won't fit because the spin-on adapter has a lip or the oil cooler does not allow you to go bigger than the OEM. Try backreading more for 2KD who upgraded to bigger filters.
Remote bypass oil filtration
