Originally Posted by
number001
Just a tip for Innova, Fortuner, Hilux with non-VGT 2KD-FTV (no hoodscoop on bonnet) only. 1KD-FTV, i have not seen nor tried yet.
Its possible to fit a bigger oil filter (ie. B2, LF3487, etc..). I asked the mechanic to try this. It fits or shoots right in. But you might have a hard time removing the filter later on your next oil change bec. there is little, to no wiggle room to maneuver. Of course take note he uses a chain to remove filter so that requires wiggle room. But if you have other method of removing the filter then using a bigger filter is possible.
