Page 189 of 195 FirstFirst ... 89139179185186187188189190191192193 ... LastLast
Results 3,761 to 3,780 of 3899
    Oct 2004
    #3761
    Vic C-110 had its gasket leaking, so I decided to change oil & filter (car acquired last mid-May, at sabi ng previous owner last oil change was just March). I only have Baldwin B2 in my stash (kasi yun ang gamit ko sa isang sasakyan with dual filter relocator).
    si liit at si laki...
    Kasya naman pala. :D
    Lapit nga lang talaga sa exhaust manifold pipes (about 8mm clearance to closest pipe). Kapag nag-discolorate yung paint ng Baldwin B2 sa tapat nung pipes, alam na. :D but so far after 2 weeks ayos pa rin sya.
    Aug 2013
    #3762
    ^^ nice rev happy engine sir.
    Jan 2012
    #3763
    Wow! Big difference talaga. Anong engine to sir? Laki ng filter location clearance.
    Apr 2012
    #3764
    ang laki nga nung b2 compared sa dating filter. bigger filtering medium, better filtration. malapit nga lang sa exhaust pipe, dapat may heat shield
    Oct 2004
    #3765
    *bayen: 4A-GE 20V.
    *monty_GTV: I'm planning to put thermal wrap nga dun sa exhaust pipes. :D
    Jul 2015
    #3766
    Sulit talaga baldwin
    Jan 2014
    #3767
    Sa mga gusto maghanap ng equivalent filters found this website. Mukhang ok naman magcross reference. type nyo lang yun product number lalabas na yun mga equivalent for oil, fuel, air, and cabin filter.
    JS Filters :: Product Catalogue
    http://www.js-filter.com/catalogue
    #3768
    Higher end synthetic fiber filters which are great for a bypass filter set up
    #3769
    Just an observation. I started using the Baldwin BT223 on our 22-year old Sentra with 130,000kms on the odo. It's still using the original timing chain amd tensioners and I noticed that the slight cold start-up chain clatter went away after a couple of thousand kms with the BT223 and Delo.
    #3770
    San pb makakabili ng baldwin un mura? May ibā pa bang importer?
    May 2009
    #3771
    nawala naman yung sinok (parang nalalagutan ba ng hininga) around 2.5 to 2.7k rpm nung makina nung gumamit ako ng baldwin oil and fuel filter atsaka mobil mx engine oil....ngayon, kaya na umabot ng 3k rpm ng walang drama.
    Apr 2012
    #3772
    Pag gumamit ba ng slightly bigger in size na oil filter nagkaka problem ba sa engine?
    May 2009
    #3773
    hindi naman..mas maganda pa nga iyon dahil mas marami ang magsasala nung dumi sa langis. atsaka walang babanggain na ibang pyesa yung mas malaking filter lalu na kung umandar.
    Oct 2004
    #3774
    Both on two cars with stock oil filter size B37 or BT223, I used a B2 sa isa, then sa isa naman ay dalawang B2 (with remote dual oil filter re-locator kit) --- na-notice ko sa cars ko mas matagal mawala ang low oil pressure warning lamp mula nung nag-upsize ako especially at cold start (difference of around 2-3 seconds, at kita rin talaga sa oil pressure guage na medyo matagal sya tumaas especially when cold)...
    ...but I don't think it will do significant wear kasi di ko naman patatakbuhin agad while low oil pressure warning lamp is still on.
    The bigger filtration area (so less restriction) and more contaminant holding capacity ang advantage.
    Jan 2016
    #3775
    Hi Tsikoters, I'm planning to have my change oil outside casa. nakabili na ako ng oil, mitasu 5w30. Hindi ko lang alam kung anong klaseng oil filter ung bibilhin ko. by the way altis 2010 ung tsikot ko. reading from this thread maganda ung Baldwin. san ba ako makakabili nun near marikina area. thanks.
    Sent from my SM-G900F using Tapatalk
    #3776
    Quote Originally Posted by AngelTin View Post
    Gen 10 Altis uses a Baldwin BT223. Try checking online (olx) as there's a seller who can do deliveries to that area if i recall correctly.
    As for me, I'm keeping my fingers crossed that the new Hilux 2.4 also uses a BT223. :D
    Jan 2016
    #3777
    thanks vinj
    How much kaya ung Baldwin BT233? Anyway may nakita na ako sa OLX, 300 petot. legit ba un?
    Jul 2014
    #3778
    thanks vinj
    Sa Mr Liempo ako bumili ng BT223 *P300. You can send the date code of a particular filter to baldwin website to verify if it is genuine.
    Apr 2012
    #3779
    Quote Originally Posted by Mask Rider Blac View Post
    May number ka niya bro? Pabulong naman
    Mar 2005
    #3780
    +1 sa Mri Liempo! Sobrang traffic nga lang sa Araneta ave.
Remote bypass oil filtration
