Page 192 of 390 FirstFirst ... 92142182188189190191192193194195196202242292 ... LastLast
Results 1,911 to 1,920 of 3899
    #1911
    Quote Originally Posted by doy View Post
    Sir, check ninyo din kung golden pa din ang oil color after 500kms lalo na with Baldwin BD28. Still got a golden oil color after 500kms with Fleetguard LF3564. Panalo talaga ang price at performance ng ZIC UP.
    actually checked it right after oil change. but it was a bit dark agad. probably cause the previous oil i use was really really dark when we drained it. but its ok since i know im using a good oil + filter combo. will drain the oil after probably 5-6000km and have it analyzed.
    Miko, can you PM me the contact of the company with used oil analysis? thanks!
    Sep 2010
    #1912
    :hieveryone:
    Good Day to all!
    i discovered this ttttthrrrread and have rrrread thru it for moooore than a WEEK... :sweat: :sweat: :sweat:
    and this thread is looong hehe :arms:
    but the looong read thru was very much worth it!
    #1913
    Quote Originally Posted by SpeedDzel View Post
    :hieveryone:
    Good Day to all!
    Kudos to you for taking the time to read it. Dami mo talaga matututunan through the backread.
    Sep 2010
    #1914
    thank you sir VINJ! i feel like my brain got toasted.. overheated trying to absorb everything :boom: hehehe
    i did an Oil & Oil Filter Change last 18April, settled for a...
    Bosch OM 037 oil filter to replace a Vic C-503
    and
    Mobil Delvac MX 15W-40 CI-4 replacing Castrol CRBTurbo
    purchased at Bionicwheels in Aurora, Cubao. (listed as an authorized Bosch Repair Center).
    1pc Bosch OM 037 . . PhP 280
    1L Mobil Delvac MX . .PhP 250
    5L Mobil Delvac MX . .PhP 1,250
    they also have
    Top1 SDO . . . . . . . .PhP 320? (if i recall right)
    LiquiMoly Lubes etc
    will upload & share photos of the items.
    will also break open the used VIC filter...
    coming soon!
    #1915
    and
    they also have
    LiquiMoly Lubes etc
    coming soon!
    their mobil delvac mx is a little expensive. i think its only around 200 sa mga DIY stores. as for Top1 SDO, price in auto supplies is around 260-290pesos.
    Oct 2011
    #1916
    and
    they also have
    LiquiMoly Lubes etc
    coming soon!
    Sir! any significant changes on your engine after shifting to Mobil Delvac MX? Does it accelarates faster or engine becomes more quiet?
    Sep 2010
    #1917
    that's correct, mahal nga si Bionicwheels sir CB but i was pressed for time na. sila lang alam ko na may Bosch na malapit. as i Had to travel up Up UP north right after the OCI.
    initial observation; i think lumuwag / nakahinga ung makina. medyo tumaas ang idling (engine). :detective:
    #1918
    what we do for our fleet is to buy in bulk/wholesale so you will get it at a lower price. before we used to buy Top1 SDO for our diesel engines. now trying Zic UP. Ok naman Top1, hindi mausok as compared to Shell Rimula. For our gas fed engines, we're using Zic A naman.
    Sep 2010
    #1919
    roger that sir. ZIC has indeed caught my attention. I'm eyeing it for the next OCI.
    also, very much would like to use a Baldwin. But it seems the B104 is very HARD to find or source
    #1920
    ^ have you tried Volmax already?
Remote bypass oil filtration
