Results 1 to 20 of 3899
    What is the Baldwin oil filter for Fortuner 2016 Diesel? What about for Innova 2008 gas? Pareho lang ba?
    ^ 1KD/2KD, 1GD/2GD, 2TR engines use the tiny BT233. You may want to cross-ref OE PN#s at Baldwin site just to be sure.
    Sir, I read that Baldwin B2 a bigger oil filter may also be used. Is this so?
    What about MANN W940 High Performance, is this also a good filter for Toyota Fortuner and Innova?
    Erratum to my previous, should be BT223.
    Quote Originally Posted by attyallanlatras View Post
    Yes you may as long as the thread,gaskets are the same and it fits in the engine, and bypass valve is within specs. Basic principle is the bigger the better because of larger filtering media surface area, filtration is a straightforward/exact science.
    Toyota 90915-YZZD2
    Baldwin BT223
    Donaldson P550335
    Baldwin B243^
    Donaldson P550400^
    Baldwin B1405
    Baldwin B178^
    Donaldson P554770^
    ^ long version
    Got the above from my back reads here. How would I be able to verify if the above reference number would fit or be equivalent to toyota oil filter for fortuner?
    BT223 or similar-sized should fit without problems, but if you will upgrade- buy some samples or measure the actual vertical clearance to determine if it will fit in the engine without hitting any hose/accessories.
    Sometimes the thread of the spin-on adapter has stand-pipe that you need more clearance for the ing/egress of the filter. Or the diameter won't fit because the spin-on adapter has a lip or the oil cooler does not allow you to go bigger than the OEM. Try backreading more for 2KD who upgraded to bigger filters.
    May 2009
    saan na kayo nabili ng baldwin or fleetguard filters nyo mga sirs/mams?
    balak ko kasi uli bumili yung nasa cebu.....si t***s....
Remote bypass oil filtration
