Page 104 of 195 FirstFirst ... 45494100101102103104105106107108114154 ... LastLast
Results 2,061 to 2,080 of 3899
    Jul 2011
    #2061
    Quote Originally Posted by miked View Post
    Masyado malayo pagkakaiba ng delo 400 prices ah. P295/liter bili ko dati eh.
    mahal pala delo 400 sa inyo mura pala dito, makabili na nga kahit sa next year ko pa gamitin baka magtaas din dito.
    Aug 2010
    #2062
    its seems that caltex don't have srp for their lubricant products. kanya kanya silang presyo.
    Oct 2011
    #2063
    Quote Originally Posted by trucker111 View Post
    Inquire ko ung Caltex dito sa Macapagal pag napadaan ako. I'll check kung magkano dito and update ko kayo.
    May 2009
    #2064
    Quote Originally Posted by miko101130 View Post
    sir miked, those additives you mentioned DECREASE as you use the oil because it gets depleted... as the oil is performing its functions those elements which primarily is the detergent/ dispersant component of the oil is surely but slowly decreasing, kaya as time goes by, the TBN becomes low which indicates it time to change the oil....
    what might increase in oil analysis is the acid number/ the metal elements like copper/iron/aluminum/ tin... (if there is wear/ normally these metals are very minimal)
    yung sample ng oil analysis na nadownload ko (CRE lab corp Lubecheck on cummins diesel using delo 400) eh ganun eh. can't remember if downloaded yun via this forum. mas mataas yung current vs the previous. i doubted also the results kasi afaik dapat nacoconsume nga. but the TBN decreases kaya hindi ata magtugma.
    Feb 2007
    #2065
    Meron na bang Baldwin/Fleetguard/Bosch/Wix distributor within Rizal province? Anlayo kasi ng volmax.
    Dec 2009
    #2066
    bosch siguro meron yan sa mga auto supply diyan sa area mo... pero kung baldwin at fleetguard medyo need mo talaga sadyain... itaon mo na lang pag bili pag punta ka manila o QC...
    Oct 2011
    #2067
    Quote Originally Posted by freeloader View Post
    ung purolator maganda din. sa rapide ka nga lang bibili.
    Oct 2011
    #2068
    OT:
    We all know that VIC made cheap oil filter. How about their fuel filter element specifically part number F-193 for D4-D engine. Is this equally as cheap as the oil filter as well?
    Aug 2010
    #2069
    will you take the risk?
    #2070
    just checked with Volmax. still no stock of BD28. sa July pa daw or August. and the guy who answered seamed irritated already with people asking about BD28 haha!
    also, the filter of Honda and Mitsubishi's 4G63 engine seem to have the same part number for Baldwin. B179. is it correct?
    i was checking, the vic c304 is for 4g63. vic 307 for Honda.
    B179
    Descriptions: Full-Flow Lube Spin-on
    Contains: Anti-Drainback Valve
    8 PSID By-Pass Valve
    Thread: M20 x 1.5
    O.D.: 3 (76.2)
    Length: 2 27/32 (72.2)
    B141
    20 PSID By-Pass Valve
    Thread: M20 x 1.5
    O.D.: 3 11/16 (93.7)
    Length: 3 7/8 (98.4)
    dvldoc, would you happen to know how many micron are the fuel filter of Baldwin?
    Oct 2011
    #2071
    Sir cb, meron din bang fuel filter sa Volmax?
    May 2009
    #2072
    speaking of volmax, may new arrivals na ba ng bd28?
    May 2009
    #2073
    ^^^huwag maiirita ang tiga volmax na yan sa dami ng tanong baka diyan din sila babagsak. dahil sa "poor customer service". hehe
    Oct 2011
    #2074
    out of stocks pa daw.
    Oct 2011
    #2075
    wala na bang ibang dealer ng baldwin aside from volmax.
    May 2005
    #2076
    Generally, AFAIK, Honda uses B1402.
    4G63 is compatible with B1402, B166, B179, B7167. They all share a common thread (ie. Thread: M20 x 1.5 ). Difference in PSID filtration, length, and diameter.
    #2077
    im also trying to know what is the correct PSID for both Honda and 4G63.
    Dec 2007
    #2078
    The honda filter ranges from 12psi to 20psi for the bypass valve. You can also use the B227 or B1400. The B1402 is the better filter to use because it is oversized. Always go big.
    The B166 will probably not work, It's gasket and outer diameter will not fit. It is however the filter you would use for the Crosswind. I tried to put the B166 on my Altima which uses the B1402 and it was a total no go due to the lip on the filter mounting base. and it was just to big.
    Apr 2012
    #2079
    Just wait for dvldoc na lang. Next month he will be retiring. We can get supply from Him.
    Dec 2007
    #2080
    You'll still be out of luck for the BD28's price wise they are cheaper there than here in the US. Same for the 1kzte oil filter, there size and price kinda makes them a pain deal with. I'll think about a few cases between now and when I get there sometime in July.
Remote bypass oil filtration
