Page 102 of 390 FirstFirst ... 252929899100101102103104105106112152202 ... LastLast
Results 1,011 to 1,020 of 3899
    Dec 2007
    #1011
    Your really killing yourself on short oil change intervals, the WIX filter is good on just about any gas engine for around 12000km. And as far as oil goes if your using CH-4/SL or CI-4/SL Rated oils then there is abolutely no reason to be changing it till around 10000km to 12000km and that's the dyno stuff. If you use a synthetic (Group III and up) 12000km is what you should look for.
    CH-4/SL or CI-4/SL oils will have a high TBN that will still be perfectly good at that oil change interval and still have plenty of the additive package left in it. Now if your using low end SL or SM oil that's a different story.
    With the proven source of availible engine oil anylisis you can look up you can clearly see there is no reason to run your oil or filter for such short durations. Changing oil based off of common schools of though are just not accurate.
    WIX is a higher end filter so feel good with going 12000km with it.
    #1012
    Update
    Bf7534 still out of stock * volmax, went there today to get 2 pcs of bd28
    #1013
    Quote Originally Posted by zix888 View Post
    Update
    Sir zix888 next paki-ask naman if they have bd7028.
    Jan 2011
    #1014
    ako I used BF7534 on my 4m41 2k kms na....still kicking like a horse hehe....I think hindi siguro match yung BF7535? or probably faulty yung nakuha mong filter....
    Just installed BF7535 over the weekend, doing good so far...this is indeed the direct replacement of 1770A053 as per all the cross-referencing done, even using the Denso P/N at times. Even checked and measured the thread pitch. BF7534 can fit but do not know how tight it can really hold...
    #1015
    Quote Originally Posted by tuazon7 View Post
    Good to know that 7534-35 can fit our monty
    Jun 2007
    #1016
    its holding tight alright.....
    I'm just wondering why sir nelz is experiencing stalling with the 7535 then after it was replaced with an OEM the stalling went away....
    #1017
    dvldoc would you know any oil filter relocator for a M26x1.5?
    #1018
    Alright sir Ry_Tower, will put that in my list.
    Dec 2007
    #1019
    Quote Originally Posted by edtf View Post
    Not that are made in the US, the kits come in 3/4"-16, 13/16"-16, 1"-12, M18x1.5, M20x1.5 and M22x1.5 thread patterns.
    #1020
    YUP been researching on them and that is what I got. Thanks! I might have to go the fabricated way
Remote bypass oil filtration
