its seems that caltex don't have srp for their lubricant products. kanya kanya silang presyo.
yung sample ng oil analysis na nadownload ko (CRE lab corp Lubecheck on cummins diesel using delo 400) eh ganun eh. can't remember if downloaded yun via this forum. mas mataas yung current vs the previous. i doubted also the results kasi afaik dapat nacoconsume nga. but the TBN decreases kaya hindi ata magtugma.
Meron na bang Baldwin/Fleetguard/Bosch/Wix distributor within Rizal province? Anlayo kasi ng volmax.
bosch siguro meron yan sa mga auto supply diyan sa area mo... pero kung baldwin at fleetguard medyo need mo talaga sadyain... itaon mo na lang pag bili pag punta ka manila o QC...
OT:
We all know that VIC made cheap oil filter. How about their fuel filter element specifically part number F-193 for D4-D engine. Is this equally as cheap as the oil filter as well?
just checked with Volmax. still no stock of BD28. sa July pa daw or August. and the guy who answered seamed irritated already with people asking about BD28 haha!
also, the filter of Honda and Mitsubishi's 4G63 engine seem to have the same part number for Baldwin. B179. is it correct?
i was checking, the vic c304 is for 4g63. vic 307 for Honda.
B179
Descriptions: Full-Flow Lube Spin-on
Contains: Anti-Drainback Valve
8 PSID By-Pass Valve
Thread: M20 x 1.5
O.D.: 3 (76.2)
Length: 2 27/32 (72.2)
B141
20 PSID By-Pass Valve
Thread: M20 x 1.5
O.D.: 3 11/16 (93.7)
Length: 3 7/8 (98.4)
dvldoc, would you happen to know how many micron are the fuel filter of Baldwin?
^^^huwag maiirita ang tiga volmax na yan sa dami ng tanong baka diyan din sila babagsak. dahil sa "poor customer service". hehe
The honda filter ranges from 12psi to 20psi for the bypass valve. You can also use the B227 or B1400. The B1402 is the better filter to use because it is oversized. Always go big.
The B166 will probably not work, It's gasket and outer diameter will not fit. It is however the filter you would use for the Crosswind. I tried to put the B166 on my Altima which uses the B1402 and it was a total no go due to the lip on the filter mounting base. and it was just to big.
You'll still be out of luck for the BD28's price wise they are cheaper there than here in the US. Same for the 1kzte oil filter, there size and price kinda makes them a pain deal with. I'll think about a few cases between now and when I get there sometime in July.
