Originally Posted by
crazy_boy
dvldoc, how about this top1 diesel oil, can I use this in both 2nz-fe and 1tr-fe gasoline engines? this is the semi-synthetic diesel oil.
SAE Grade 15W-40 CI-4 <-------------------Not S rated
API Gravity 29.1
Viscosity
SUS * 100º F 503
SUS * 210º F 76
cSt * 40°C 116
cSt * 100°C 15.6
Viscosity Index 140 <------------- is this still too low?
Flash Point, C° (F°) 238 (460)
Pour Point, C° (F°) -39 (-38)
Total Base Number 11.8
Ash, Sulfated, wt% 1.37
Phosphorus, wt % 0.127
Zinc, wt % 0.137 <---------------- not sure if this is ok for cars with cat-con
Foam Test Pass
As for the filter, with the Vios, im just worried that if its too long, it might hit potholes, which might cause problems. as for the size, the important thing is that they have the same size(3/4-16UNF) right? . the Oring gasket size(54x62rnd) is not important?
