Saw some purolators sa motech (parang rapide). Pde pa check kung ok?
Continuation:
They also carry GS Oil (Kixx)
Sent from my LGLS996 using Tapatalk
The "no noticeable buildup of trapped dirt" kinda worries me.
If its is a good filter, you should see some dirt because it should be filtering. If none, then maybe it has gone bypass already.
Or your engine is really clean.
Small gasoline engine (1.6L) with two big filters (Baldwin B2). Dirt could have been too much dispersed in the filter elements for me to notice anything. Besides, 7000kms+ pa lang.
I've also just opened the valve cover to check the valve clearances (although I cannot do adjustments, I'm monitoring the wear on the cam lobes because of stiffer valve springs). Valve train is clean --- like the way it was when it was after chemical bath last general overhaul in 2011.
Engine is really clean.
Just curious, have you tried using then opening a cheap oil filter? Will we see the same physical attributes?
^sir, what brand of bypass filtration did you use? care to share some photos?
It is not a bypass filtration system... Tamang dual oil filter relocation kit lang.
https://www.summitracing.com/int/parts/sum-g4986-1
...I'm using that relocation kit, though I changed the NPT to barb fittings and hose (leak kasi nang leak) to NPT to AN push lock fittings and hose.
Price update sa Volmax...
Baldwin B2 - P225 (was P200 nung July 2013, last na bili ko).
Baldwin BT223 - P290 (was P275 nung July 2013, last na bili ko).
Sorry, nagmamadali ako... di ko na natanong current prices ng ibang common oil filters.![]()
Manipis naman talaga ang filter element ng VIC since dati pa kaya nga inferior ang grade sa quality ng VIC, mukha lang maganda ang appearance ng paint finishing at packaging pero yung filter element ng VIC ay manipis talaga hindi gaano na fifilter ang dumi mismo VIC distributors nagaadvertise na up to 91% filtration lang kaya ng filter nila compared to China, Taiwan, Thailand, Malaysia, Indonesia & etc... filters.
Pero if cocompare mo ang VIC sa mga top class filters katulad ng japanese brand na Nippon Micro and KS filter malayo agwat ng quality in terms of filtration and oil pressure. VIC vs. European brands like MAHLE, Mann-Hummel, Bosch(High-end filter blue box or black box hindi yung yellow box galing Vietnam) talo din ang VIC, US brands like Fleetguard, Donaldson, Baldwin & etc... kulelat din ang VIC, since yung mga upper quality brands ay standard filtration ay DAPAT 96% filtration at 40 microns of dirt/pollutants ang VIC filter ay bagsak nasa 87% lang after 5 minutes of engine running after 10 mins bigla ang lakas ng bagsak ng filtration efficiency ng VIC to 81% dahil sa nipis and low quality filter media compared sa other better brands na after 5 minutes of engine running lowest standard is 96% after 5 mins then after 10 mins at 94% isipin niyo after 10 mins lang from 87% naging 81% ang bilis 5 minutes interval lang 6% na ang nabawas na filtration capacity ng VIC brand. Tandaan niyo ang VIC papogi lang ang appearance at mukhang madami ang tupi ng filter media pero in the end mahinang klase at manipis lang ang filter media nila.
Remote bypass oil filtration?
You mean mag iinstall kau ng isa pang oil filter?
If yes, i can provide oil centrifuges..
^ Double filtration na din ba ang bt223?
sa facebook dami scammer nagpopost about shell products magpagkunyari na tatanong kung ok ba langis eh tinadtad lahat ng groups tapos may cocombo sa comment na magtatanong-kuno yun pala magkakuchaba. Shell products are overrated and overprice. Lalo na fuel jan gasolina nung leaded days grabe sobrang pigil.
nagiing big 3 shell kasi malaki worldwide Same sa caltex. But si petron ang magaling sa gasolina. Diesel I dont know its a 3rd world fuel wapakels ako jan
you mean pinipilit ko fuel station? Hindi na kailangan piitin kasi wala pa ako post jan eh pinipilahan na yan uno. But hindi na ako nag uno kasi mas gusto ko feel ng gasolina ni phoenix.
Hindi naman kelangan ng Low Ash oil kung walang DPF ang kotse mo. Most cars in pinas, wala nun.
