Page 115 of 195 FirstFirst ... 1565105111112113114115116117118119125165 ... LastLast
Results 2,281 to 2,300 of 3899
    #2281
    The current real! LF3564 for the 4M40 engine (Baldwin BD28) upgrade. Please compare to what they are selling locally, it's not even close in quality. They by the way are only produced in Argentina if it's not from there it's going to be a low quality reproduction.
    The low quality locally sold vs which is claimed to be made in Malaysia
    thanks dvldoc for confirming my lf3654 is real.
    #2282
    Zix, where did you buy yout fleetguard?
    Dvldoc, any suggestions on a good aftermarket water separator brand for the 4d56/4m40 engine?
    Thanks
    Jun 2007
    #2283
    doc, did you already send it here? or you coming in together with it?
    #2284
    Thanks
    local autoshop in sanfo bro, nag iisa nga lang, hirap pala hanapin nitong lf3564
    Dec 2007
    #2285
    On the way, Probably here in Aug.
    * Crazyboy
    Baldwin makes the best fuel filters hands down. They use the BF7535 and BF7533
    #2286
    * Crazyboy
    Dlvdoc, i mean the aftrmarket water separator with the clear bowl. I"ve sen one here before. So that yiu can see the trapped ditt inside. Thanks!
    Dec 2007
    #2287
    Oh you want a CAV filter then. Berrima diesel sell a adapter that lets you turn your stock fuel filter housing into a CAV filter. The elements themselves like Baldwin and Fleetguard are cheap and they are 2 microns. It's a simple spin on adapter they have it for your engine. They are a little bit messier to change but the filter great. I'm happy with the Baldwin's 5 micron rating so I am just going to stick with it since I have so dang many filters for my ride.
    I don't know the cost of the set up you will need to email them. But the filters you can get for like 200P each.
    http://www.diesel.asia/filtration.html
    There is not a spin on for your thread patter to directly replace the OEM filter with one with a glass bowl you will always need a adapter.
    #2288
    dvldoc,
    this is the CAV filter?
    Dec 2007
    #2289
    Yes.
    You can replace your stock filter with one but you have to get a filter head with a primer. Or you can run it inline before the factory filter.
    #2290
    If I'm not mistaken it - 12k sa Berrima.
    May 2005
    #2291
    Doc, did your LF3564 come with shrink wrap? By the looks of it, if it came with the box then probably no shrink wrap. Does it have the julian date on top?
    Also, some filters from Fleetguard (ie. LF3665) and even after perusing on their website's 3D model spin, does not have the printed country of origin on the side.
    May 2005
    #2292
    Silly question: Does " Lube Spin-on " and " Full-Flow Lube Spin-on " mean the same thing ?
    Dec 2007
    #2293
    Yes mine came wrapped in plastic. Sometimes you will find one that someone has taken it off. And yes mine has a julian date at the top. That's how I tracked down when and where it was made. The one from Argentina is the newer one mine are like 8 year old. I think yours might be stratapore media and note microglass. I'm going to call Fleetguard tomorrow and find out. Mine also did not have a country of origin on them that's why I used the code to find out where it was made. With a fake you won't be able to do that.
    Same thing. The only time it won't be a full flow is if it says dual flow or bypass.
    Got an email from sulit guy selling Purolator. Kaso there are no pics.
    Sent: Thursday, 28 June 2012 9:26 AM
    Subject: Re: Purolator
    Ryan,
    for you the Purolator Oil filter would cost P375 and Fuel Filter P312
    Oil filter L34750 (306) MD069782
    Fuel Filter F60222 (321) MB220900
    Sir the bigger purolator L45262 (313 / 109) ME 215002 / ME013307 is for the pajero fieldmaster 4m40, price is P405.
    Please advice ahead of time and allow 1 to 2 days before meet up. May i ask where are you located?
    thank you.
    Dec 2007
    #2295
    Ryan,
    thank you.
    FYI US made Purolators have a specific date code on them.
    Will check before buying.
    Thanks a lot.
    Oct 2011
    #2297
    Yes.
    I have seen fuel/water separator in genset. Could this also be placed in car engine before the fuel filter?
    Poor filtration from unknown china-made genset. You would be better off buying quality replacement filters IMO.
    #2299
    bd28 * 12000kms , mobil 1 TDT
    ^ wow, ang linis pa ng filter mo, seems like 15,000kms is easily achievable!
    How's the oil? Sandy feeling or still smooth to the fingers when touched and grinded together?
Remote bypass oil filtration
