Page 64 of 195 FirstFirst ... 145460616263646566676874114164 ... LastLast
Results 1,261 to 1,280 of 3899
    Dec 2007
    #1261
    Quote Originally Posted by miko101130 View Post
    dOC have you heard of LUBEFINER?? some other store carry them here? any thoughts, its USA brand tough
    Yes Luberfiner is a quality filter, I use them as well. I'm using there imperial XL series as part of my dual bypass system they are 5 micron filters, I replaced my other side with the LF9028 fleetguard Venturi bypass filter which is about as good as it gets.
    Luberfiner are for fleet service just like Baldwin and Fleetguard, they are not over the counter filters you can get in a autoparts store.
    The black ones are my Luberfiners
    Here's a 4M40 filter from Luberfiner.
    #1262
    The BT223 fit perfeclty with all 4cly gas Toyota engines there is no way your getting a B2 oil filter on a 1.3 Toyota engine. Not sure where you did the cross reference from. But here you can see it's the B33 JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C110J You can use the B33 but I prefer the BT223 because it's just a little bit bigger.
    Top 1 diesel oil is great for gas and diesel since it's additive package is not to aggressive with the Zinc 1200ppm is perfect. Diesel oils have higher detergents as well so they will keep your engine cleaner so you can use that in all your vehicles.
    You defiantly do not want to use the 20w50 oil in your engines unless it's a older worn out diesel. If the oil is the new API SJ rated oil you don't want that stuff it's weak sauce there zinc is around 850ppm to 900ppm and Phos way down in the 600ppm range. They do put in around 40ppm moly and some boron to make up for it a little. Not really the best oil out there.
    Don't know about there diesel oil I would have to dig up a spec sheet the MSDS do not state the exact formulation but a range.
    dvldoc, how about this top1 diesel oil, can I use this in both 2nz-fe and 1tr-fe gasoline engines? this is the semi-synthetic diesel oil.
    SAE Grade 15W-40 CI-4 <-------------------Not S rated
    API Gravity 29.1
    Viscosity
    SUS * 100º F 503
    SUS * 210º F 76
    cSt * 40°C 116
    cSt * 100°C 15.6
    Viscosity Index 140 <------------- is this still too low?
    Flash Point, C° (F°) 238 (460)
    Pour Point, C° (F°) -39 (-38)
    Total Base Number 11.8
    Ash, Sulfated, wt% 1.37
    Phosphorus, wt % 0.127
    Zinc, wt % 0.137 <---------------- not sure if this is ok for cars with cat-con
    Foam Test Pass
    As for the filter, with the Vios, im just worried that if its too long, it might hit potholes, which might cause problems. as for the size, the important thing is that they have the same size(3/4-16UNF) right? . the Oring gasket size(54x62rnd) is not important?
    #1263
    Hi dvldoc just wanna ask if this is the real deal LF3564, if its not is this still worth using? especially compared to a VIC-313 filter for my 4M40... Thanks
    I guess this is what you meant with the combo filter... hehehe
    #1264
    Malamang Top1 SDO & BD28 bilin ko, kung hindi lang me nag Solo ng Bili nung 6-2 kami na Montero dyan eh! hehehe di ba Zix? ehehehe...
    Hehehe, gusto mo ba, may spare pa ako. Wala ka naman nabanggit nung magkakwentuhan tayo eh
    #1265
    Ayus lang paps malay mo orig ung lf3564 eh di un na muna gamitin ko... Kung fake man tong fleet guard ko mukhang maganda ung construction and material nya. Hehehe... Sayang din, muntik ko na makalimutan. Hehehe
    #1266
    Alright, update na lang tayo, if pupunta ka volmax, pasabay na din ako, or kung ako naman mapasyal balitaan kita
    Nakuw fake yan bro, tignan mo nalang glue, out of place and there are no crimps. Just poor construction inside.
    #1268
    Quote Originally Posted by zix888 View Post
    Wala bang nagtitinda ng baldwin sa caloocan or banaue area? Volmax is kinda hard to go to...
    #1269
    Sa volmax kasi sure tayo na baldwin talaga. So far wala pa infO kung saan pa may stores na nag carry na baldwins
    Dec 2009
    #1270
    Doc, are fleetguard and baldwin's recommended to be extended up to 8k to 10k of use on truck engines?
    Dec 2007
    #1271
    Running it under 12000klm is a waste of money.
    Dec 2007
    #1272
    Yes that's a total fake filter, look at all that loose glue, and poor filter elements, What a total piece of crap! Let me guess you got it at Pacer?
    Jun 2005
    #1273
    API Gravity 29.1
    Viscosity
    SUS * 100º F 503
    SUS * 210º F 76
    cSt * 40°C 116
    cSt * 100°C 15.6
    Foam Test Pass
    i use bt233 for the 2 vios with 1NZFE 2NZFE engines and corolla with 2e engine. fits well. no leaks.
    i wouldnt worry about it hitting potholes. malayo pa yung oil filter. unang tatamaan yung oil pan. besides bt223 is only about an inch longer and the metal casing seems sturdy enough
    Dec 2009
    #1274
    where did you bought that LF3564 blue_gambit?
    i don't think fleetguard's are constructed that way...
    Dec 2007
    #1275
    That's because that filter is a fake. I'm also sure it has no country of origin, was not wrapped in plastic and did not have the proper date code on the top of the filter.
    #1276
    Quote Originally Posted by sirkosero View Post
    ok. will buy the bt233 later. thanks! how much is it?
    and can i know what oil are you using for your vios?
    Jun 2005
    #1277
    BT223 Costs P215 sa volmax. dont bother asking about the b33 wala sila stock nun. hehehe
    its a perfect filter in terms of cost imho. a replacement vic costs 180. An original toyota cost 315 sa casa. a baldwin bt223, which is superior than any one of the 2 costs only 215. at 3k kms, my oil still looks fresh
    im using regular toyota oil or idemitsu oil. mineral lang.
    #1278
    ok thank sir. will buy that later today. mura lang pala. as for the regular toyota oil, its viscosity is too thick i think at 20w50
    Dec 2007
    #1279
    That's the big difference between a 40 micron filter vs one that well down to 12 microns, you will really notice a difference over a VIC filter the oil pretty much stays a nice golden brown vs black on a gas engine.
    #1280
    API Gravity 29.1
    Viscosity
    SUS * 100º F 503
    SUS * 210º F 76
    cSt * 40°C 116
    cSt * 100°C 15.6
    Foam Test Pass
Remote bypass oil filtration
