Page 74 of 195 FirstFirst ... 246470717273747576777884124174 ... LastLast
Results 1,461 to 1,480 of 3899
    Oct 2004
    #1461
    is it the same with miko101130?
    BTT: RT, please let me know if volmax has stock of BD28 already. I will buy already before maubusan ulit ako hehe
    Oops! miko101130 pala.
    http://www.**************/index.php/...ARDAHL+and+ZIC
    Dec 2009
    #1462
    Tsikot at pajeroclub.com.ph lang ang member ako... haha..
    bsta interested kayo sa Zic,Bardahl,gulf, meron ako....
    Im setting up a store nang complete filter and engine oil line up sa province namin, from low end to high end para meh choices ang buyers...
    Curious lang ako.... ang dami daming heavy equipment at mga PUV na hindi man lang nakatikim ang sasakyan ng matinong langis at filter pero hangang ngayon buhay at umaandar pa din naman... nyahaha..
    Feb 2003
    #1463
    *dvldoc and Rocko24...Thanks much
    Jan 2011
    #1464
    Dvldoc, can you help advise on this? TIA.
    From the cummins/fleetguard website, LF3564 has a thread pattern of 'M26 X 1.5-6H INT'. Does the 6H indicate the number of holes?
    Quote Originally Posted by tuazon7 View Post
    Fleetguard Cummins Lube filter LF3564 products, buy Fleetguard Cummins Lube filter LF3564 products from alibaba.com - looks like it means 6 holes indeed.
    Another pic from our guys here from page 42.
    * dvldoc: what do you think of this site. USAFilterStore.com: Shopping Cart Contents
    Is this reliable? My cousin is contemplating on buying from this site and have it shipped here via balikbayan box as well.
    Dec 2007
    #1466
    Pretty sure that has nothing to do with the holes it's part of there system of measurement for thread size all there metric filters have that 6h after the number. Only the China and Malaysian ones seem to have 6 holes. The one made in Argentina and the US have 10.
    http://catalog.cumminsfiltration.com...&currentPage=1
    But 6 is all the stock filter has so it should not be a issue.
    *Ry_Tower
    Yes that site is legit they have some good prices. But a limited stock selection, but I guess that depends on what filter your looking for.
    Jun 2007
    #1467
    Hi dvldoc. Just want to clarify that the oil filter being offered to me in replacement (the ones with open and close parenthesis)of certain filters at Volmax is ok to use? I guess there is still OOS of BD28 and BD7028.
    Checked the BD7028 and the suggested replacements and this came up in my research. My concer is the PSI difference and slightw weight difference.
    baldwin b7045, lube spin-on
    baldwin bd7028, dual-flow lube spin-on
    B7004(BD7141)
    B1422(B7033)
    BD7159(BD7169)
    B337
    B7045(BD7028)
    BD7095(BD28)
    bro, gano difference nung length nung ibang filter sa BD28? with the case kasi nung 4m41 nasa ilalim ung filter....My worry is baka kung masyado na mahaba yung filter kahit na mas efficient yung filtration eh baka sumasayad na pala especially on the trails hehe....
    Sir LR yung difference is 148.4mm yung (bd7028 at B7045) while BD28 is 136.5mm or 11.9mm or about 1/2 inch. Maliit lang naman difference, not much to worry. B7045 lang available sa Volmax ngayon eh. Kaso hindi siya dual flow so not more than 10,000kms if ever ito gagamitin with a good oil as per dvldoc.
    baldwin bd28, dual-flow lube spin-on
    Jan 2011
    #1469
    http://catalog.cumminsfiltration.com...flag=0¤tPage=1
    *Ry_Tower
    thanks doc, ry_tower! this what I got from W&L...
    Sir am I right to say that markings on the 2 filters are different in orientation? Do you have a 360 degree view?
    Dec 2009
    #1471
    Doc, is it Ok to use mobil delvac mx 15w40 on a gas engine?
    Dec 2007
    #1472
    Yes it's perfect for any gas engine, It has less than 1200ppm zinc in it so catalytic converter safe.
    Jan 2011
    #1473
    *Ry_Tower, the marking is the same for both. The marking orientation direction is going to the thread on one side and going to the top on the other side. Noticed also the numeric markings at the bottom, just not sure what these stands for. There is also a COO on the main 12-pc box, it came from France...
    Dec 2007
    #1474
    If you go to the cummins site you can view the filter 360, Some of their filters now have the Fleetguard on both sides on is reverse.
    Thanks sir tuazon7 & dvldoc.
    Oct 2004
    #1476
    The locally available LF3564 filter has 2 marking orientations, 1 in front & the other at the back (shown by Tuazon07). It's what I am currently using together with FF5160, which also has 2 marking orientations.
    Dec 2009
    #1477
    i already removed my catalytic converter so i can use all the Zinc there is..haha... another thing DOc, im currently using fully synthetic 5w40, if i use the delvac 15w40 will there be any significant change in fuel consumption? or too little to notice?
    Dec 2007
    #1478
    Quote Originally Posted by miko101130 View Post
    Higher ZDDP will give you better fuel economy, but 40 weight oil is 40 weight oil, it's not going to make any measurable difference in 5w40 and 15w40. Whoever got the much ZDDP and moly will have the best fuel economy between the two.
    If you have no cat would be looking at just about any heavy duty diesel oil, Like ZIC, Delo, or Top1 all will last a very long time in a gas engine.
    Dec 2009
    #1479
    Monarc in Libis (sole cummins engine distributor in the Philippines) is conducting Oil analysis (complete elemental/wear/VI/TBN analysis) i called them up and their oil analysis cost 1,024.80 pesos... cheaper than others... their also conducting Virgin oil anaylsis
    Address:
    150 E. Rodriguez Jr. Ave., Libis,
    Quezon City, Metro Manila
    Tel: 635-0901
    im planning to have my used oil analyzed.. haha..
    Dec 2009
    #1480
    now we'll know which of the oils are really performer rather than marketing B.S... we'll know whats in their oils...
Remote bypass oil filtration
